  • entry
    6
    1,571
Rusting away on the drive with 200k miles & counting.
MoreBHP
Hi folks, I have reposted this content again hopefully the pictures wont move around this time, not sure why that happened but the picture sequence is important to make the write up content meaningful. Hopefully it will work.
Bmw rebuild 2015-updated 19/12/15
Hi folks welcome to my BMW e46 330i touring refurb, I've owned this 330i 2001 supercharged touring for over 10years with a 200k miles on the odometer. I really enjoy the e46 chassis setup and was needing it to last at least another 10 years to have some fun for weekends and track days.
It is a fast road car setup and was not intended to be a full on track day monster but something slightly more interesting that the stock setup.
image.jpeg.d23b6deaa6814db2b123817186657
Image 1.1/ Picture taken before the restoration began. No MOT and SORN, 10months sat idle on the driveway.
The hope is this journal documents the restoration and mechanical works undertaken since May 2015, I've been lucky in that I have had the use of another vehicle which has enabled this project work to be done without any time pressure.
Over the years I've added a few mechanical upgrades but have endeavoured to keep it close to OEM aesthetically, I quite like the idea of a sleeper car and hope the final outcome will be on the mark.
I intend to also cover the existing mechanical mods and future plans in subsequent posts. I'm afraid that I am no computer wiz kid and will update via several edits over the next couple of weeks.
Journal Entry 1- Rusting away on the drive. Under Chassis rust treatment.
A trip to Rust Master to get the under chassis rust treated and sealed. They were doing a special deal at the time was about £250 irc, there were pockets of rust starting to form in all the usual places fortunately the engineer seemed to think we had caught it just in the nick of time.
image.jpeg.5b16f51caaeb47b1308b0effdc9ee
Image 1.2/ pre-clean down and treatment application. Generally tidy but small pockets of rust evident.
image.jpeg.14b8f21cffae686bdb23c89336329
Image 1.3/ surface corrosion.
image.jpeg.1c7a7021134fd09640499038a1fd4
Image 1.4/ Build in 2001 March, 14years old and the rust is on the go!
image.jpeg.0a5ed6d60ba1eec2072ef36a90012
Image 1.5/ The Rust exorcist at work, this is a rather messy unpleasant task and I don't have access to a ramp, best to get someone to do it for you as it rains waxoly literally.
image.jpeg.b6eb93843bf3fbb5805cdc5c15cce
Image 1.6/ Glad I'm not covered in waxoly like this man!
image.jpeg.dee5eae49d6a79a453d9da10ea5c5
Image 1.7/ Looking nice & shiny with rust treated the work also comes with a warranty.
image.jpeg.a1fd6d451754fdd35b7e13c922859
Image 1.8/ Lovin the shininess, won't have to worry about the chassis underside for a while.
6 Comments
Journal entry 2- Exterior rust treatment.
After the undersealing was completed and dry the next step was to remove the side skirts panels to assess the condition of the sills.
image.jpeg.49127363b32bf72776edf5573faa5
Image 2.1/ Superficial rusting & corrosion at both the bottom of all wheels arch sills which is fairly common for e46's. Both front wings will need to be replaced due to rust on the top of the wheel arches.
image.jpeg.bcf74e0b4ceee089697a5cf5bb873
Image 2.2/ Superficial surface rust on the bottom of the back wheel arches and sills.
Time to get wire wheel out, strip back and expose the bare metal ready for rust curing treatment.
image.jpeg.cd9221d14f43db92bf1aaaf3c91f9
Image 2.3/The drivers side front wheel arch sill area has seen better days again nothing too severe that a wire brush and Furtan can not resolve. (http://www.fertan.co.uk/how_to_use_fertan.htm)
image.jpeg.422801b34806a25e171d232a99401
Image 2.4/After some vigorous wiring brushing it was time for a couple coats of anti-rust gel. If you are using the green gel (A Hammerite product I believe) make sure you leave it on for longer than the instructions recommend) I discovered that the advice was to apply several coats and leave on for 24hours but did obtain much better results when leaving it on for 48hours or longer. I was in no rush and the weather was good so as the old saying goes 'patience is a virtue' especially when rust treatment is concerned.
image.jpeg.08bfaa26fb32bfeacc4e3ece53135
Image 2.5/Back lower wheel arch sill area prepped.
image.jpeg.360438a307bfa6b64157497714c00
Image 2.6/Zinc anti-rust primer left to dry for at least 24hours.
image.jpeg.476ba6e01f4d011d36702f4c3c572
Image 2.7/More zinc anti-rust primer coat.
image.jpeg.ddf949a9a4160badb6b51e2ede35f
Image 2.8/The lacquer and Stahl Grey 400 paint isn't too bad a colour match for a Flea bay spray can effort.
image.jpeg.85938c670a9fe970c4a752b1581e8
Image 2.9/Drivers side front arm with 3coats of Waxoly treatment complete. Yes that is a green bonnet it is a long story.....
image.jpeg.f8c8f4931b37081b2049fb250a85a
Image 2.10/Waxoly to sills complete, this was a underestimated job with a tendency to be messy make sure you wear old cloths and cover the ground from splashes and spills.
image.jpeg.be3520d3bd23088a4e7634134cd76
Image 2.11/Glad the waxoly is done and the AC Schnitzer side skirt panels ready to be carefully put back on.
image.jpeg.cbd7dc21755ac6ac7c2c3b90ec6d2
Image 2.12/Unexpectedly there was rust forming on the inside drivers side passenger door sill from where rain water had been discharging from the bottom of the door and was pooling under the sill guard.
image.jpeg.6717ae47d96bc9aaa2d7a4b398d43
Image 2.13/ A couple coats of Furtan later.
image.jpeg.7d8d288c9666bdb34aae7336de9ef
Image 2.14/ Another spot of rust requiring treatment included a bubbling on the drivers door just beneath the window trim, I decided to get my local Bodywork specialist to repair this since it needed to be blended into the adjacent wing panel.
Edited by MoreBHP
Share this comment
Journal entry 3- Water pump & supercharger overhaul.
I have consistently read on many e46 enthusiast forums that the coolant system is the archilles heel, this said, I knew a full overhaul was due so the plan is to replace with OEM parts as much as possible but I also needed scope to upgrade the supercharger PSI at a later stage. The brief was a robust coolant setup, the existing radiator was sagging at the bottom and was on its last legs and OEM water pump didn't look good or sound great for that matter infact the deeper I looked the worse it got. By the end of the cooling system overhaul the only parts reused were the coolant level & temperature sensor.
Parts used:
1/EMP Stewart high flow water pump. (Aftermarket upgrade)
2/Radiator (Hella part no. 203111235) £73.32
3/Expansion Tank (Hella part no.205110290) £42.11
4/Upper radiator hose (BMW part no. 32416796390) £40.50
5/Lower radiator hose (BMW part no.11531436408) £30.50
6/AC Condenser (EIS part no.22110271) £59.28
7/Antifreeze  2x 1.5L (BMW part no.83512355290) £18.46
8/Water pump USC pulley metal upgrade
9/Alternator USC pulley upgrade
Image 3.1/ The saggy 200k radiator and AC condenser were on their last legs.
Image 3.2/ Electric fan housing removed.
Image 3.3/ Old radiator removed providing better access to the pulleys, belts and water pump area.
Image 3.4/ OEM Water pump and thermostat before removal. The s/c Idle pulleys look suspect too!
Image 3.5/ Thermostat off, water pump next!
Image 3.6/ Water pump finally removed, be gentle when removing so not to damage the aluminium housing.
Image 3.7/ OEM water pump with plastic composite impellar.
In the end I decided to upgrade the OEM water pump to a EMP Stewart high flow pump sourced from Bimmerbum based in the USA. I knew the pump had done 80k and running a supercharger exerts additional strain on the pump's bearing so I wanted to address the weakest link.
The last thing I need was a warp engine from a catastrophic water pump bearing failure!
Image 3.8/ The New EMP Stuart high flow water pump finally arrives, I waited 6 weeks for this bad boy to be imported from USA. Unfortunately USPS were terribly slow and damaged the first shipment thanks to Ed at Bimmerbum for his good customer service and communications.
Image 3.9/ EMP Stuart upgrade will it worth it? guess I have to wait and see.....
Image 3.10/ The weight & build feel of the pump suggests a worthwhile investment. Will have to see.
Image 3.11/ The Stewart high flow water pump claims to provide a increased 20% flow rate which can't be a bad thing. It was about £200 quid Incl. delivery & uk import tax but definitely provides the added peace of mind.
Whilst doing the water pump install it made sense to think about a new thermostat, the debate at the time, was it going to be OEM or the aluminium encased upgrade?
After a little research I discovered that based on users experiences the connecting hoses had a tendency to detach on occasion.  I presume this may relate to the plastic and aluminium material properties expanding and contracting at different rates. So a like for like OEM replacement it was down to BMW Reading I went.....I'm on first name terms with them now.
Image 3.12/ The new thermostat with old, thought since everything else on the engine coolant system had been replaced it made sense to change the Thermostat too. Maybe a false economy but at least I have a spare.
You may have noted that on the earlier picture the s/c idle pulleys were looking tired and rusty they had infact also seized in place so 2new Koyo pulleys and a supercharger belt were ordered via Hans and Asbojn at ESS Tuning.
Image 3.13/ Ess tuning bits have arrived.
Image 3.14/ With the water pump, thermostat, s/c idle pulleys installed it was time to get the AC condenser, Radiator & expansion tanks in. The Hella radiator and expansion tank were sourced from Europarts, as I was fairly confident these were manufactured by the OEM supplier so there should be no difference in quality apart from the price £££ ?
The old AC condenser was in a right poor state, as AC was a non-essential id not want to fork out £280 for the OEM part, I ended up buying a EIS condenser from Car Parts for less at fraction of the BMW list price.
Image 3.15/ All back together just as well, as it is October and winter was on its way. I ended up using a 50/50 coolant to de-ionised water mix, whilst the airbox was old it was a good opportunity to carfully drain the old power steering fluid making sure that the alternator (underneath) is protected from spills and refilled with QX ATF DX power steering fluid.
I put into the local garage for the MOT and it passed ??? .???
Edited by MoreBHP
Share this comment
Thanks Simon, hopefully this will help others out when it comes to identifying specific areas that degrade and need to be considered when undertaking a similar scale refurb. I would have done more but not having access to a lift ramp and budget limited the scope of works.
Edited by MoreBHP
Share this comment
Nice, like a bit of a sleeper. It's not an understated car but so many E46's with MV2s etc. are all show and no go, I doubt many people would expect 300bhp+(?) to be unleashed if you put your foot down.
Share this comment
