Reset BMW E46 airbags via Creator C110 code scanner
Hand-held Creator C110 OBDⅡcode scanner is designed to troubleshot BMW vehicle from 2000 to 2012, including read DTCs, clear DTCs, display live data and clear adaptation. The new updated V3.8 software adds the active test function for BMW MINI models. Here is the example of resetting 3-serie E46 airbags/SRS light with C110.
Step-by-step instructions:
Well install Creator C110 OBD2 software
Plug the code scanner with vehicle via OBD socket
Select DIAGNOSE function form main menu
Select BMW series: 3 Series
Select the detail BMW model: 3-serie E46
Select Body control module
Pull down the drop-list and select SRS (Air bag), click OK
Select Read trouble code
The system will automatically read error code information stored in Body module, press OK
Select Erase trouble code.
The reason for the airbags light was on the dashboard. It needs to be disconnected.
Once reconnected, go back to C110 BMW code reader program, select Erase trouble code again.
The system will display Trouble code is erased message.
Airbag light will start to flash. If the light does not stop flashing, turn ignition off and then turn it on.
