scrimja
Diy List
After Stan 24v mentioned it on another thread, I thought I'd put together a comprehensive list of the best DIY's on here. A 100% blatant copy of the one on e46Fanatics which can be found here. Hopefully it will make it slightly easier to find what you are looking for from now on. The list is currently incomplete (which is fairly obvious) but should have it all sorted in the next week or so! Feel free to post up/PM your ideas for what should make the list. More importantly, if you think that there has been a very useful thread that is of DIY quality but not in the DIY section, send me the link and I'll add it in.
If you can't find what you're looking for on e46zone, try BMW 330ci, my330i, MadRussian or the e46fanatics link above. Between e46zone and the other sites mentioned, there shouldn't be much you can't do yourself!
Exterior
Replacing BMW Badges
Interior
Heated Steering Wheel Retrofit
Instrument Cluster Removal
Carbon Fibre Wrap Interior Trim (Also useful for how to remove interior trim)
Carbon Fibre Laminating (real CF weave)
Centre Armrest Install
Suspension/Brakes/Drive train/Engine
DISA Valve Replacement
Spring Replacement/Upgrade
Front Control Arm Rear Bushes
Engine Whistle/Intake Boot
Anti-Roll Bar Links
Fan Clutch Removal & Engine Belts Change for Autos
Rear Brake Change
Lighting
Angel Eye Install (NON-Facelift Coupe)
Angel Eye Install (Facelift Coupe)
Electronics/ICE/Stereo
E46 Integrated Bluetooth with S/W Controls (Parrot Kit)
Complete Business HU upgrade - Sirius, MP3, Aux-in & iPod
Double-Din Installation
Facelift Coupe - Ski Hatch Removal
BMW Remote Key Fob Programming
How to change the battery and casing for your key
Maintenance
Handbrake adjustment
Front & Rear Brakes
N42 Air Filter Replacement
Clean EGR Valve (M47N)
Swirl Flaps Cleaned & Crank Case Breather Checked
(320d) Oil Change
General/Stuff that didn't fit into any other category
Sticky Seatbelt
Sticky Door Handle
Butterfly Valve Exhaust Mod
Occupancy Sensor Bypass Module (Airbag Light on OBC)
CDV (Clutch Delay Valve) Replace/Delete
(Saloon) Subframe Repair
Throttle Adaption Reset
Edited by Gaz
Oi, that was ME who mentioned it on the handbrake thread!!!! http://www.e46zone.com/forum/index.php?sho...3903&hl=diy
:D :D
Mate, I have no idea what you're on about. The original post CLEARLY states that it was you that said it :P.
Sorry about that pal, just got muddled up but it is now fixed!
Probably about half way through putting the list together now.
