Deezer-D
Climate Control Relocation Panel
5 posts in this topic
Deezer-D
Anyone got the part no. handy please? Need to order this for my Nav retrofit. I have a 2004 coupe. There appear to be 2 types, 1 with a 16mm slot for switches and the other for 18mm switch slot.
Cheers
D
mit
The only way to know is to look at yours and see if you have one big bar of buttons or individual buttons.
You can find the part numbers on www.realoem.com if you enter your chassis number.
mit
Cheers mit. I assume you can only tell if it's one big button if you pop the panel out? I'll try realoem
No you can see from the surface - if there are cracks in between the switches then you need the type with individual switch holders. If it's one big rectangle that goes across the whole thing and all the switches are on that, you have the single switch panel type ;)
Deezer-D
Cheers mit. I have the single one, ordered the part from the dealer - Part No. (based on my chassis no. is 51-16-8 230 903)
Create an account
Register a new account
Sign in
