chris
E90 on to E46?
IIRC these will go on, but ive seen 19" BMW wheels on a E90 coupe, and want them now :rolleyes: Are the offsets ok??? Will post some pics when i find them somewhere ;)
The E90 uses a lower off set, around 13mm lower, so it depends on which E90 wheels you are looking at,if they are 17's with 225/45/17 all round using a 34mm off set they should just go on with no arch problems,if they are with are a 8.5 wider rear with a 255/40/17 then you will have alot of rubbing as i tried a set with a 245/40/17 and they still rubbed,had to run a 225/45/17 on the rear so they did not rub.This is going to be the same sort of case with the 18's,if they are a wider rear then they a probably going to rub.Hope this helps :rolleyes:
This is straight from Mark @ BMAutosort (posted on E36coupe.com)
HTH.
pooooooooooooo ;) well i want 19" so thats that gone :D ACS type 4's it is then :D Or CSL's maybe :rolleyes:
What the **** does IIRC mean, I see it all the time and its doing my head in being "outside the circle of trust"
TELL ME DAMMIT!!
Forget it.......just googled it and IIRC this means I'm thread jacking now.
SOZ!
IIRC = If I Remember Correctly :rolleyes:
Yes, YES YES YES YES
lol
(laughing out loud)
Thanks.
I tried it a while ago with some e92 335i wheels...
Fronts were ok but rears stick out to far. Not that obvious in the pics.
ACS Type 4's all the way for me, CSL 19" too common now !!!! :D:mellow: (The Diddler prepares himself for some serious flaming !!!! :P;) )
Only kidding both types will look the doggys!!!!, i.d have both, but i,m greedy!!!
What about ACS type 4's on one side, and CSL's on the other :D:mellow:
Hi Ian, another familiar name :D
Nice to see you here.
