Nef
BBS Split rim bolts not tightening
After having my genuine BBS splits for about a month now and have noticed that a large number of the bolts are simply spinning in there holes and not tightening.
Only noticed after one bolt actually came out whilst cleaning them, so checked each bolt and heres what i found.
These are the number of bolts that are loose;
Front Left 11 and right 2
Rear Left 4 and right 7
Not really sure what to do, but i can see this costing a fair bit of money to fix :censored:
Any help would be great, Thanks
Edited by Nef
what BBSs do you have again? kinda hard to say much when they are all different
i though they were nut and bolted using a special tool something like a 12 point spline bit
no mate, just bolt straight into the alloy.
has someone refurbed them? or are they as they left bbs
the person i bought them off had them refurbed before they sold them to me, could this be part of the problem?
Obviously someone has messed them up whilst refurbishing them, i have had my fair share of building bbs splits there's only one way of saving them which is to re tap each hole going 1 or 2 size up and buy new bolts with that larger thread pattern. The last option is get shoot of them, but I wouldnt fancy driving on them like that.
Normally does say it on some of the genuine bolts, best advise is when doing it seriously take your time it would be a shame to see these rims go to waste. Save them dude.
They look diff to 704s on Google... might just not be much info.
I'd check what model / bolt size they take first.
Do the bolts fix into the wheels themselves then rather than using nuts?
Ah right that sucks. is it the bolt thats stripped then or the wheel?
Its the wheels that have stripped, all the bolts are fine.
Edited by Nef
Helicils would bs best bet just make sure they are perfectly straight else the bolts wont go in properly
Does this suggest that they have been over tightened at some point. I've got two of my BMW splits apart at the moment and it occured to me as i was undoing the bolts that i have no idea what the torque setting should be when tighening them back up. :unsure:
