UweM3 Posted March 21, 2011 Report Share Posted March 21, 2011 (edited) I have a set of style 5's leftover from my E39. Besides the hubcentric ring issue, is ET20 doable? Tyres I would like to fit are 225/45/17 on 8x17 all corners on a E46 320d touring Edited March 21, 2011 by UweM3 Quote Link to comment Share on other sites More sharing options...
SamN Posted March 21, 2011 Report Share Posted March 21, 2011 I'd have thought you'll need more stretch on the tyres with those wheels... Being that they will be sitting at least 30mm further out that standard wheels (the spigot rings will probbaly push them out a bit more also). I'm guessing the car will be getting a decent drop on coilovers? It may look a bit silly otherwise IMO. Quote Link to comment Share on other sites More sharing options...
UweM3 Posted March 21, 2011 Author Report Share Posted March 21, 2011 I'd have thought you'll need more stretch on the tyres with those wheels... Being that they will be sitting at least 30mm further out that standard wheels (the spigot rings will probbaly push them out a bit more also). I'm guessing the car will be getting a decent drop on coilovers? It may look a bit silly otherwise IMO. no coilover, it's my daily driver and mile muncher. I figured that ET20 is maybe a bit much for a "nomal" application. 225/45/17 won't be stretched on 8J. I better stick the rims on Ebay and get something with ET35-40 Quote Link to comment Share on other sites More sharing options...
DJ Syxx Posted March 21, 2011 Report Share Posted March 21, 2011 I'd have thought you'll need more stretch on the tyres with those wheels... Being that they will be sitting at least 30mm further out that standard wheels (the spigot rings will probbaly push them out a bit more also). I'm guessing the car will be getting a decent drop on coilovers? It may look a bit silly otherwise IMO. Spigot rings won't push them out, their purpose is to centre the wheel so it doesn't wobble and sits on the hub tight. ET20 is doable but you would probably need to reduce the width of the tyre down for the rear depending on what you want to do. As you got the wheels at hand you could always trial fit them on and see how they sit before selling them off? Quote Link to comment Share on other sites More sharing options...
SamN Posted March 21, 2011 Report Share Posted March 21, 2011 Yeah i know that's not a stretch, i worded that badly, i just meant you may need a slight stretch. As Syxx says, may be worth a trial fit to see how it'd look as you have them already. Although if you're not lowering it at all, personally i'd put them on the bay or something as ET20 is a bit low for a 'normal' wheel on an E46 Quote Link to comment Share on other sites More sharing options...
UweM3 Posted March 21, 2011 Author Report Share Posted March 21, 2011 I left my wheel locking tool at the garage and can't get it before Friday. Quote Link to comment Share on other sites More sharing options...
Jorge- Posted March 21, 2011 Report Share Posted March 21, 2011 Look at Omex, he has ET20 17x8s on the back of his. I think they are on 225 tyres too. I have ET19 17x9s at the moment, used to be ET14, but put on 15mm spacers and had to remove them until I can attack the arches more. Quote Link to comment Share on other sites More sharing options...
SamN Posted March 21, 2011 Report Share Posted March 21, 2011 Both your cars are slammed on their arses though, as much as I think they both look sweet as they are, if they were on standard suspension I don't think that'd be the case Quote Link to comment Share on other sites More sharing options...
