simonlpearce
BMW Wheel Hub Sizes/Hub Centre Bore Sizes and ET/Offset
Well as my wheels felt kinda small compared to Marty and Dickie i decided to look into getting some new ones and thought this may help others when looking for advice. It also displays all the other BMW's and their wheel sizes.
BMW
1 Series E81 04> 5x120 38-45 205/55/16 225/45/17 225/40/18 235/35/19
3 Series E30 Excl M3 82>90 4x100 20-30 205/55/15 205/45/16 205/40/17
3 Series E36 93>98 5x120 30-40 205/60/15 205/55/16 225/45/17 225/40/18 235/35/19
Optional Rear Upstep 240/40/17 255/35/18* 265/30/19*
3 Series E46 98>05 5x120 30-45 195/65/15 205/55/16 225/45/17 225/40/18 235/35/19 225/30/20
Optional Rear Upstep 255/35/18* 265/30/19*
3 Series E46 M3 99> 5x120 20-25 225/45/18 225/40/19 255/30/20
Rear Upstep 255/40/18 255/35/19 285/25/20*
3 Series E90 05> 5x120 30-40 205/55/16 225/45/17 225/40/18 235/35/19 225/30/20
Optional Rear Upstep 255/35/18 265/30/19
5 Series E39 96>02 5x120 15-25 205/65/15 225/55/16 235/45/17 235/40/18 235/40/19
Optional Rear Upstep 265/35/18 265/35/19*
5 Series E60 03> 5x120 15-20 225/55/16 245/45/17 245/40/18 245/35/19 255/30/20
Optional Rear Upstep 275/35/18 285/30/19 285/25/20*
6 Series 04> 5x120 15-20 245/50/17 245/45/18 245/40/19 245/35/20 255/30/22
Optional Rear Upstep 275/40/18 275/35/19 275/30/20 295/25/22
7 Series 02> 5x120 15-25 245/55/17 245/50/18 245/45/19 245/40/20 245/35/21 255/30/22
Optional Rear Upstep 275/35/20 295/30/21 295/25/22
Z3 96> 5x120 30-40 205/60/15 205/55/16 225/45/17 225/40/18 235/35/19
Optional Rear Upstep 245/40/17 255/35/18 265/30/19
Z4 03> 5x120 30-40 225/50/16 225/45/17 225/40/18 235/35/19
X3 04> 5x120 40-45 235/55/17 235/50/18 255/40/19 245/35/20
X5 00> 5x120 40-45 235/65/17 255/55/18 255/50/19 265/45/20 285/35/22 305/35/23 295/30/24
Have just found this too guys, may help a few of you when looking at the style of wheel you want.
https://www.d2autosport.com/D2_2006/06_Gall...lery_bmw_2.html
the offset is all about how far the face of the wheel is from the hub.
So as you said the smaller the offset the closer to the arch.
The larger the offset, the closer the face of the wheel is to the hub, therefor creating more space between the face of the wheel and the arch.
You also need to take into account the width of the actual rim.
E.g a 9.5" rim with and offset of 45 will sit closer to the arch than a 9" rim with the same offset.
Above courtesy of Marty & Jonny
dicky has 10" rims on the back of his car but gets away with it cos the offsets allow for the additonal width.
Simon, very good find mate, I will make this a sticky as this will help loads of people as this is a regular topic of conversation ;)
ET45 Rim with 255/35/18 rub on the inside of the rear wheel well ( not on arches ) with my KW Variant 3 coilover kit on set 3/4 low, I suspect with camber correction arms I could eliminate this, worth a mention tho
Thought i would just post some info that i found for the maximum fit alloy on my non sport saloon without modifying the arches!
As far as I've looked into it the max i can have on my saloon non sport car is:
Front: 18/19 x 8.5 with 35 Offset (ET35)
Rear: 18/19 x 9.5 with 45 Offset (ET45)
ok i`m usless at working this out.. its prob me making it more technical than it actually is!
My Question.... Will these fit with this kit ?
With The tire package 235/35/19 front and 265/30/19 rear
BBs LM Reps
Eibach Kit
Thanks in advance
OH AND I HAVE A 99 328CI NON SPORT
You may struggle with the Eibach kit to get them to fit, although im sure someone will be along to correct me. The wheels alone should fit though!
will be getting lowering springs on the 15th, and wheels beggining of next year when hopefully the weather sorts it self out abit!
will 19" 8.5J alloys with an offset of 35 fit a standard e46 saloon?
Thanks
Yes fine bud, dont go too wide on the rear tyres though :D
will 15 inch standard e46 rims fit a 323ci? the smallest they come with on a coupe is 16 inch but can i squeeze 15's on maybe from a salloon
I suppose if the 15's are on a 323i saloon then the brakes should be the same size so yes, trial and error mate, give it a go :)
Why? Your not putting 15's on are you :)
Lee does the craziest things thats why we love him B)
I am just awaiting the pics he is mad for it ;)
Oh and he loves to burn **** :)
My mate has a set of BBS LM's in 15 or 16" for a BM. I laughed and said he would never sell them, but perhaps he might :);)
How does rim width effect what offset will fit?
I currently have a set of rondell 058s which i believe are an 8 inch rim (all four are the same). I like the stance of them but they are nearing the end of their life so I have purchased a set of e36 m3 wheels to put on. I believe the offset on these is ET41 and they are 7.5 inch rims all round.
Ihave used the 'wil they fit' link above and it seems that if 8.5J ET35 rims will fit as previously mentioned in this thread then I should be ok with 7.5J ET31 rims. Firstly does this sound correct? secondly assuming the m3 rims are ET41, if i use 10mm spaces will this put the outermost edge of the rim at the same place as an ET31 without spacers would be?
REsults from willtheyfit- Old is 8.5J ET35 and new is 7.5J ET31
Old New
Diameter 616.3mm 616.3mm
Circumference 1936.2mm 1936.2mm
Poke 73mm 64.3mm
Inset 143mm 126.3mm
Speedo error 0% 0%
Reading at 30mph 30mph 30mph
Reading at 60mph 60mph 60mph
Ride height gain 0mm 0mm
Arch gap loss 0mm 0mm
Hi all,
Just had a blow out and completely destroyed the alloy and cannot get another anymore!
Looking for replacement alloys and I think I want the M3 style... namely
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...e=STRK:MEWAX:IT
or
http://www.bmautosport.co.uk/detail.php?siteid=1192
Both are 18's but have different offsets and I don't know which ones are best. Can anyone help as I have no idea about offsets.
I have a 2005 E46 Tourer
thanks in advance all.
