Djmobi Posted May 28, 2012 Report Share Posted May 28, 2012 Hey everyone, I need to sort out the fact that my roof wont close with the fob.........it opens (Although sometimes stops halfway) but it will not close at all. Same for Windows obviously. I have searched and read some of the posts i've found and can see that this needs to be done by plugging in your laptop with a special cable and using some software. My car is a 56 Plate Vert Msport so I'm thinking I should buy this http://www.ebay.co.uk/itm/NEW-BMW-INPA-Ediabas-K-DCAN-USB-Interface-D-CAN-CAN-20PIN-ADAPTOR-CABLE-/110869278110?pt=UK_Diagnostic_Tools_Equipment&hash=item19d052ed9e#ht_4500wt_982 Just wondered if someone could confirm that I am buying the right thing. Quote Link to comment Share on other sites More sharing options...
Chimp Choker Posted May 28, 2012 Report Share Posted May 28, 2012 aye that will do it, nice touch you get the pre OBDII 20pin cable also however if you cant wait as it is in hong kong, i got this, worked flawlessly http://www.ebay.co.uk/itm/BMW-USB-Diagnostics-OBD-Cable-Interface-lead-Ediabas-Inpa-GT1-DIS-/110882363672?pt=UK_Diagnostic_Tools_Equipment&hash=item19d11a9918 to code the roof you will need to get your head around NCS Expert, easy once you know how, but be warned you can cause damage if not done correctly. you need to change the following in the GM5 module to activate remote open/close both set to acktiv KOMFORTSCHLIESSUNG_FB COMFORT CLOSING WITH REMOTE (POWER WINDOWS, SUNROOF OR CONVERTIBLE TOP) 0002 nicht_aktiv not active 0001 aktiv active KOMFORTOEFFNUNG_FB COMFORT OPENING WITH REMOTE (POWER WINDOWS, SUNROOF OR CONVERTIBLE TOP) 0002 nicht_aktiv not active 0001 aktiv active job done Kagan and Djmobi 2 Quote Link to comment Share on other sites More sharing options...
havoc Posted May 28, 2012 Report Share Posted May 28, 2012 Can you not do the same coding in SSS?? Im sure I saw it when I changed the options on my car.. Quote Link to comment Share on other sites More sharing options...
Chimp Choker Posted May 28, 2012 Report Share Posted May 28, 2012 Can you not do the same coding in SSS?? Im sure I saw it when I changed the options on my car.. Dunno. Installed it once. Laughed at it and went back to ncs Ncs FTW E46 Convertible Imola Red Quote Link to comment Share on other sites More sharing options...
havoc Posted May 29, 2012 Report Share Posted May 29, 2012 Dunno. Installed it once. Laughed at it and went back to ncs whats wrong with it? yes its a bit slow getting the coding out the car, but then pretty simply select and code.. then again im no expert but its quite easy to use ( for me... ) not tried NCS though. Quote Link to comment Share on other sites More sharing options...
mit Posted May 29, 2012 Report Share Posted May 29, 2012 If I remember right post-2004 cars can't be encoded for this. Quote Link to comment Share on other sites More sharing options...
havoc Posted May 29, 2012 Report Share Posted May 29, 2012 If I remember right post-2004 cars can't be encoded for this. Mines a 2004 and has the option, it works which is nice... Not sure about newer cars as dont know anyone else with an E46 Quote Link to comment Share on other sites More sharing options...
Djmobi Posted May 30, 2012 Author Report Share Posted May 30, 2012 Cheers Siffion, I will order the one you suggested and follow your instructions Quote Link to comment Share on other sites More sharing options...
Djmobi Posted May 30, 2012 Author Report Share Posted May 30, 2012 One last thing that i'm sure has been covered a million times.......if the car has the ability to do it, why the hell isnt it just turned on for all cars all the time? Quote Link to comment Share on other sites More sharing options...
havoc Posted May 30, 2012 Report Share Posted May 30, 2012 (edited) my old E36 M3 vert had the full closure factory alarm, when it went in for a service they found that the module had a fault, so they replaced under warrenty but turned the full closure off. they said it was a BMW policy due to H&S and security of the car ( guess that if you didnt watch the car fully close, and some tea leaf pushed on the windows the system shuts down leaving your car open ) also, a couple of times in my E46, ive had the keys in my pocket and been faffing around with the alloys or simlar and ive held the button down in error.. looked up and seen the car opening its roof...wouldnt be a problem but it was raining at the time,, anyway, its more trouble than its worth sometimes.... Edited May 30, 2012 by havoc Quote Link to comment Share on other sites More sharing options...
El Turko Posted May 30, 2012 Report Share Posted May 30, 2012 The key story is why I never got mine coded. Quote Link to comment Share on other sites More sharing options...
Chimp Choker Posted May 30, 2012 Report Share Posted May 30, 2012 I agree. The fact that you have to hold the key button down for total open/close maybe the geniuses in germany saw a potential issue E46 Convertible Imola Red Quote Link to comment Share on other sites More sharing options...
Razza77 Posted June 5, 2012 Report Share Posted June 5, 2012 Can you not do the same coding in SSS?? Im sure I saw it when I changed the options on my car.. Not available in SSS im afraid. Can be coded in NCS Expert. If I remember right post-2004 cars can't be encoded for this. Have enabled this on all years of E46. Quote Link to comment Share on other sites More sharing options...
Kagan Posted May 14, 2018 Report Share Posted May 14, 2018 Thanks @Chimp Choker I just googled how to do this and your post popped up. Finally got the roof working off the key along with some other options I coded Daz 330 Cs 1 Quote Link to comment Share on other sites More sharing options...
CRZ13 Posted April 26, 2020 Report Share Posted April 26, 2020 Sorry to revive a 2 year old thread but thought it be better than creating a new one Having issues with the comfort open/close on my 03 e46 m3 convertible Coded the relevant options using NCS, however these are the issues im having: 1. Comfort Open doesn't work at all, none of the windows come down which obviously means the soft top cannot open either 2. One single press the LOCK button locks the car, rolls up all the windows and folds the mirrors. Soft top was already closed so cannot confirm if this would have closed the soft top too on a single press of the lock button As you can imagine this is quite annoying as I'd like to choose when I want the windows to all roll up and mirrows fold in by press + holding down on the lock button instead of it automatically closing everything every time I decide to lock the car Have double checked all options and gone through the list again but still the same Any ideas? Thank you Quote Link to comment Share on other sites More sharing options...
dontpannic Posted April 29, 2020 Report Share Posted April 29, 2020 That sounds like there's an additional third party module installed, I'm fairly certain that you have to hold the button down to do any comfort opening/closing. Do you have an Intravee? Am I right in thinking that these kind of options are available through that? Quote Link to comment Share on other sites More sharing options...
