aterro Report post Posted June 2, 2012 It used to come on after 30 mins of driving Then once turned off and started again it wasn't on Now it's always on I've checked brake fluid it's full What else could it be? Cheers Quote Share this post Link to post Share on other sites
Wash Report post Posted June 2, 2012 ABS sensor Quote Share this post Link to post Share on other sites
mjn Report post Posted June 2, 2012 Yep, sounds like ABS sensor. Quote Share this post Link to post Share on other sites
Individual 330ci Report post Posted June 2, 2012 It will be one, or both of the DSC pressure sensors which bolt onto the side of the brake master cylinder. Had the same problem on mine, I changed both the sensors, £100 each from BMW. Get the fault codes diagnosed if you can just to make sure as faulty ABS wheel speed sensors and steering angle sensors, either the internal or external one can throw up the same lights. However my monies on the DSC sensors- common problem!! Quote Share this post Link to post Share on other sites
Chiffs Report post Posted June 2, 2012 Had this on mine last week, came on two days in a row. Not been on since but have ordered pa soft to do a diagnostics check. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Individual 330ci Report post Posted June 2, 2012 Had this on mine last week, came on two days in a row. Not been on since but have ordered pa soft to do a diagnostics check. Sent from my iPhone using Tapatalk Mine were on, then off quite infrequently in the beginning but after a while they came on every time I used the car! I have pa soft and it's a great bit of kit! Diagnosed my issue no probs!! Quote Share this post Link to post Share on other sites
aterro Report post Posted June 2, 2012 One fault was steering angle sensor. What is this? Didn't see any abs codes But my computer went down Quote Share this post Link to post Share on other sites
Matt_S Report post Posted June 2, 2012 One fault was steering angle sensor. What is this? Didn't see any abs codes But my computer went down Not being funny mate, but can you not put two and two together? Steering Angle + Sensor.... Hmmmmm. Maybe the sensor that detects the steering angle? Nah. Cant be..... Quote Share this post Link to post Share on other sites
steve320cd Report post Posted June 2, 2012 mines done this before, i cure it by turning on the cruise control for a bit activating and accelerating and decelerating with the controls and then turning off, next and the next time i switch the car on, no warning lights, my moneys on steering sensor Quote Share this post Link to post Share on other sites
rickzsingh Report post Posted June 2, 2012 I've got this problem too, Put it on a little scanner and the errors said se20 and se24 pressure sensors?? Quote Share this post Link to post Share on other sites
aterro Report post Posted June 2, 2012 Thanks Matt s Brilliant answer Where is the steering sensor located.... Thanks for all the advice! I'll try the cruise trick! Quote Share this post Link to post Share on other sites
Matt_S Report post Posted June 2, 2012 Here's a pic... Looking at it, Id say its an internal bit of kit, so probably on the steering column. Ill find out for you. Gimme 5. Quote Share this post Link to post Share on other sites
Matt_S Report post Posted June 2, 2012 http://www.realoem.com/bmw/showparts.do?model=ET56&mospid=47644&btnr=32_0943&hg=32&fg=30 Quote Share this post Link to post Share on other sites
Individual 330ci Report post Posted June 3, 2012 I've got this problem too, Put it on a little scanner and the errors said se20 and se24 pressure sensors?? These are the dsc pressure sensors that I mentioned earlier and the same problem I had. Quote Share this post Link to post Share on other sites
edber Report post Posted June 3, 2012 The steering sensor is located on the steering coloum and to calibrate it you will have to go full lock to full lock and then centre your steering wheel while on diagnostics. Quote Share this post Link to post Share on other sites
zigzagsky Report post Posted June 13, 2012 It will be one, or both of the DSC pressure sensors which bolt onto the side of the brake master cylinder. Had the same problem on mine, I changed both the sensors, £100 each from BMW. Get the fault codes diagnosed if you can just to make sure as faulty ABS wheel speed sensors and steering angle sensors, either the internal or external one can throw up the same lights. However my monies on the DSC sensors- common problem!! As an aside, I have the same problem with one of my pressure sensors, when you changed them and bled the system did you have to go through the ABS bleeding procedure using the diagnostic software or just a straight bleed? Quote Share this post Link to post Share on other sites
rickzsingh Report post Posted June 13, 2012 Do you have that tyre pressure button fitted? I sorted my tyre pressure out and the button hasn't come on since.. Quote Share this post Link to post Share on other sites
Guacks Report post Posted June 22, 2012 Similar thing has just come up with mine today .... 330CI 2003 DSC central indicator ORANGE Brake Light RED Reading through, would it be fair to assume this is the same as Orange / Orange? Came on today while pottering slowly down to a roundabout, car has been parked for a few hours, just started her up and the lights are still on! I'd assume, get her wired up and diagnose before having the ABS sensors replaced ...... I am in Brighton if there is anyone close by who can plug and diagnose? Quote Share this post Link to post Share on other sites
cvn25 Report post Posted July 16, 2012 (edited) Hi all, New here and to BMW ownership. Picked up my 2004 330ci convertible on Saturday ( test drive 2 weeks previously with no problems). Guy drove it out the garage for us, and straight across to the tyre fitter as DSC and brake lights orange - he said probably just tyre pressure where car had sat for 2 weeks. They checked these and we drove away lights still on, assured they should go out or will do so after restarting the car. we pulled over up the road and restarted but still one. Went back Saturday afternoon, balanced front wheels ( we had complained of wheel wobble 60+mph), left with warning lights still on. Back of car now vibrating/skipping , think wheels need balancing on rear as apparently they didn't do these at same time. They are convinced that one of the rear tyres is slightly more worn than the other, although well within legal limits and that this is causing the DSC fault. I have been back to them with other suggestions, we know someone who has tracking issues and had to take car back to be re-tracked which solved the issue. They are suggesting they change the slightly worn rear tyre for a new one, balance the wheels and this will solve the problem. Is this possible ? I am extremely unhappy that my introduction to BMW ownership has been nothing but hassle for the last 3 days ! Edited July 16, 2012 by cvn25 Quote Share this post Link to post Share on other sites
aterro Report post Posted July 16, 2012 no, you need to get it on a fault coder and see what it is. as it could be a abs sensor or something else.... Quote Share this post Link to post Share on other sites
Chiffs Report post Posted July 18, 2012 Mines come back on again now. Pa soft. Says pressure sensor 1 which is the rear sensor of the two on the master sensor. How have people changed this as it does not look easy to get too with all the brake pipes around it. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
sixel Report post Posted September 28, 2013 Just to bump up the thread I ve had the same lights come on yesterday after removing the front wheel to replace the front wheel arch liner and after fitting the wheel back while driving the dsc and hand brake light came on. could it be some thing as silly as the wheel badly fitted. Not sure if its possible , or i messed up something in the tracking? Quote Share this post Link to post Share on other sites
Oliverald Report post Posted October 2, 2013 Mine came on today (DTC light and amber brake light). I was driving down a typical Edinburgh road - bumpy in other words - at the time, at no more than about 10mph as I was approaching lights and hadn't used the brakes at all. Tuning off and on again didn't cure it. I haven't done anything to the car/wheels. I once had some warning lights come on indicating that my tail lights weren't functioning when they were - they went out by themselves and haven't come back: I attributed that to it being a hot summers day combined with not having been driven for a couple of weeks while I was on holiday. I posted here before about my parking distance sensors not working - after that same spell of 2 weeks in the airport car park which threw up the false light alarm, they briefly worked again and then, just as mysteriously, stopped. I'll try the trick with the cruise control and, if the fault persists, will take it to a garage; but I'm starting to wonder if there could be a fault with the electrics and, if so, what it could be. Any thoughts would be most welcome. Quote Share this post Link to post Share on other sites
Trevor Report post Posted October 2, 2013 Mine came on a good few weeks ago. Stayed on through several journeys. Reset them with pa soft and they've never come back on so far. Quote Share this post Link to post Share on other sites
