RickyZ Report post Posted August 25, 2012 See below, I have personally done this on my 2002 (on 02 plate) 330Ci Sport so can prove it works (pics can be supplied if needed). 1) ignition off 2) push & hold in left button (daytrip reset) 3) while holding in, turn ignition key into pos.1 4) keep holding button pushed in while "test 1" appears in display 5) after a further appr. 5 seconds oil service/inspection will appear (whichever is due) 6) release button when oil service/inspection are displayed 7) pushing and holding in the button for appr. 5 secs will reset the service interval 8) release button and switch off ignition. When restarting interval should be reset For the brake fluid follow points 1) to 6) accordingly and then proceed as follows: 7) when oil service/insp. is displayed one short push of the "day trip" button will change the display to "brake fluid" 8) when "brake fluid" message is displayed, push in and hold button for appr. 5 secs, which then will reset the brake fluid interval. 9) release button and switch off ignition. On restart the brake fluid clock symbol should be gone. 2 Ragamuffin and Tymm reacted to this Quote Share this post Link to post Share on other sites
PSYCHOPHIL Report post Posted August 25, 2012 Will be trying this first thing in the morning Quote Share this post Link to post Share on other sites
RickyZ Report post Posted August 28, 2012 Post back to let me know if it works (it should do as it did on mine) Quote Share this post Link to post Share on other sites
PSYCHOPHIL Report post Posted August 28, 2012 Not had time to do this yet but will post back asap. Quote Share this post Link to post Share on other sites
Raj24v Report post Posted August 30, 2014 How can you reset the lights if the pins on the dash are broken/not working? :/ Quote Share this post Link to post Share on other sites
TriggerFish Report post Posted August 30, 2014 INPA or PA Soft can do it I think if you have either. (Not 100% sure on INPA, but I know PA soft can) Quote Share this post Link to post Share on other sites
Chimp Choker Report post Posted August 30, 2014 Actually a good thread revival. Well done for searching. Yes as explained if your pins are not working you will need a 3rd party solution like inpa or similar www.bobsbmw.co.uk Quote Share this post Link to post Share on other sites
daveo132 Report post Posted August 31, 2014 I can confirm that the options are in inpa. 1 TriggerFish reacted to this Quote Share this post Link to post Share on other sites
