Cannockwolf Posted December 4, 2013 Report Share Posted December 4, 2013 Im thinking about putting an AFR Gauge in to monitor the mix, don't want to run it lean/rich again after all this work, is there a gauge thats not going to look horrible on the dash? so far I've only seen huge 2" dials, m looking for as discreet as possible, any ideas? Quote Link to comment Share on other sites More sharing options...
Rich_D Posted December 4, 2013 Report Share Posted December 4, 2013 You need one with a wideband lambda for a start, ones that run off the original lambda sensors are gash. You also want one that gives you an actual AFR number, not a load of coloured lights flickering away. There are a few options, assuming you want something oem looking with amber illumination? Defi (if you have deep pockets), Innovate or AEM, all do gauges that would be suitable IMO Blair 1 Quote Link to comment Share on other sites More sharing options...
L333JSA Posted December 4, 2013 Report Share Posted December 4, 2013 Zeitronic is a good option......and it can also do egt and monitor other functions too as well as data log Quote Link to comment Share on other sites More sharing options...
Cannockwolf Posted December 4, 2013 Author Report Share Posted December 4, 2013 from what ive been reading a wideband afr would need an extra lambda welding into the exhaust yeah? Quote Link to comment Share on other sites More sharing options...
Rich_D Posted December 4, 2013 Report Share Posted December 4, 2013 from what ive been reading a wideband afr would need an extra lambda welding into the exhaust yeah? Yes Quote Link to comment Share on other sites More sharing options...
Blair Posted December 4, 2013 Report Share Posted December 4, 2013 Avoid innovate they are gash sensors burn out frequently on mine & at £60 a go it ain't funny. NCK make a nice unit that is simple LED display & it uses a widely available Bosch sensor, techedge are also well spoken off BUT the reality of forced induction is by the time you see a big enough change in AFR reading your mota will already be toast. Intake temps & EGT are prob as if not more important but again unless linked to your ECU all your going to be doing is picking up the pieces. Quote Link to comment Share on other sites More sharing options...
stickboy Posted December 4, 2013 Report Share Posted December 4, 2013 i am running an innovate afr on my car and must say have had no probs with it at all yet Quote Link to comment Share on other sites More sharing options...
Cannockwolf Posted December 4, 2013 Author Report Share Posted December 4, 2013 Avoid innovate they are gash sensors burn out frequently on mine & at £60 a go it ain't funny. NCK make a nice unit that is simple LED display & it uses a widely available Bosch sensor, techedge are also well spoken off BUT the reality of forced induction is by the time you see a big enough change in AFR reading your mota will already be toast. Intake temps & EGT are prob as if not more important but again unless linked to your ECU all your going to be doing is picking up the pieces. I have the intake temp showing through my torque app, wouldnt it be useful to know if its running lean again through a vacuum leak, then i would know something was up as it was running fine even though it was lean and the dash didnt light up Quote Link to comment Share on other sites More sharing options...
andreyb Posted October 27, 2017 Report Share Posted October 27, 2017 Hi mate, did you manage to install afr gauge? I am thinking to get latest "pro sport" -around £200 for it. Also where I am supposed to plug it in? We have two pipes for bank 1 and bank 2... Quote Link to comment Share on other sites More sharing options...
Cannockwolf Posted October 27, 2017 Author Report Share Posted October 27, 2017 hi, i had to decat so had a spare flange on the evo headers anyway so thats were i put the extra sensor Quote Link to comment Share on other sites More sharing options...
andreyb Posted October 27, 2017 Report Share Posted October 27, 2017 So it's kinda connected to only one of 2 banks right? Btw was it hard to install evo headers? I couldn't find rhd header unless you ready to pay 1k+ Quote Link to comment Share on other sites More sharing options...
Cannockwolf Posted October 27, 2017 Author Report Share Posted October 27, 2017 I didnt install anything im useless at that stuff, the evo headers are difficult and expensive to do btw, they need custom flanges made to fit the block, sorry i cant be any more help Quote Link to comment Share on other sites More sharing options...
