Ed-B Posted May 16, 2015 Report Share Posted May 16, 2015 I'd bump the alloys to the top of the list! Where abouts is that video taken? The car park looks familiar. Quote Link to comment Share on other sites More sharing options...
HeftyDanielson Posted May 22, 2015 Author Report Share Posted May 22, 2015 I'd bump the alloys to the top of the list! Where abouts is that video taken? The car park looks familiar. Was taken from the Shadon car park, down from the golf course and the second video is in the twisties. More pictures!! Got a new OEM Msport knob, feels a lot nicer compared to the standard no weighted one. Got rid of the gloss black grill outlines but still keeping the chrome inserts. Trying a dash camera after seeing loads of bad accidents etc. £40 finest spent. Front a rear camera, all wires hidden, just need to put a 12v ignition live rather than plugging it in each time I use the car. Any guides about? Got these cheap, they're fibre glass which need a little bit of adaption to fit correctly. And snow foam soap to finish her off. Quote Link to comment Share on other sites More sharing options...
The_Judge_ Posted May 22, 2015 Report Share Posted May 22, 2015 Looks good Hefty Not quite a DIY, but this may help you - blast from my past ... http://www.e46zone.com/forum/topic/51866-brodit-install-help/ HeftyDanielson 1 Quote Link to comment Share on other sites More sharing options...
HeftyDanielson Posted August 9, 2015 Author Report Share Posted August 9, 2015 Yet another lengthy update. Boring bits first, before the technical and mapping issues. Finally got round to fitting the Msport brake ducts and ClubSport splitters. Got myself some new wheels, with a rather low ET of 20. They sit nicely but rub a little on the rears. Random picture from a day out with a few friends. Now, since day one I've always wanted to get the vehicle mapped, finally got round to getting done from a local company I've heard nothing but praise from their customers and friends. I went a long for a open day and chucked her on their Mustang Dyno, ran a healthy 179bhp and 330ft-lbs before the map was added. However things didn't go to plan, after the map was added, she was put back on the rollers and started getting strong boost fluctuations and only managed an increase of 185bhp but 415ft-lbs of torque. Investigations into the car began, looking for faults and or boost leaks whilst the map was being customised further for the vehicle, but to no avail, the issue was still there after multiple different variations. Slightly annoyed I headed home to fault find and investigate further. In this video at around 00:15 on the pull, you can hear the boost climb then back off multiple times once at full throttle. https://youtu.be/LwhW842G1Iw After a little research I began to change components over (no pictures). all vacuum hoses, apart from the one to the egr and it is fully deleted. Boost solenoid vacuum chamber MAF MAP cleaned inlet boosted tested. Also to go with these I had the engine's ECU updated from its 09/2002 date factory software to a newer one (which removed the map, but going back in a week to get it on the rollers once again to further fault find) because the new bosh maf was reader higher than the engine specified. This was then programmed to the ECU as far as I am aware. However, apart from making the car pull a lot harder (must of fixed something, or refreshed it) the issue is still there and only remaining things to change are the turbo and its actuator, which I do hope it's not. I am planning on doing the VAG technique of oven cleaner to free up the turbo vanes, as the actuator moves fine but it's a little stiff and possibly re-installing the egr pipe to eliminate that as a cause. If you've got any ideas, I am all ears as I am running out of ideas and don't fancy buying a new turbo, yet. Thanks, Dan. Quote Link to comment Share on other sites More sharing options...
The_Judge_ Posted August 9, 2015 Report Share Posted August 9, 2015 I'm sure some others might have some sensible suggestions, so I'll give you a silly one: Wynns EGR3 into the turbo .... If you may end up replacing it anyway then ..... I presume you get no error codes? Quote Link to comment Share on other sites More sharing options...
HeftyDanielson Posted August 9, 2015 Author Report Share Posted August 9, 2015 I'm sure some others might have some sensible suggestions, so I'll give you a silly one: Wynns EGR3 into the turbo .... If you may end up replacing it anyway then ..... I presume you get no error codes? I've looked at the turbo cleaning kits and guides but the oven cleaner sprayed into the exhaust side seems like the best method, before changing the turbo. I've ran it on shell nitro diesel (which is meant to clean) for the past 20k and the actuator moves fine (if a little stiff) The only error code that came up was an injector at full 250 bar (i think) on ignition prime, which suggest a dripping injector, but it starts fine all the time so it isn't too much of an issue, currently. Quote Link to comment Share on other sites More sharing options...
The_Judge_ Posted August 9, 2015 Report Share Posted August 9, 2015 ok, may be worth posting a new thread specifically on the issue, in the tech performance section as not everyone reads the photo threads. HeftyDanielson 1 Quote Link to comment Share on other sites More sharing options...
HeftyDanielson Posted November 5, 2015 Author Report Share Posted November 5, 2015 Another little update. Just changing wear and tear items for upgraded versions. Who like a 13 year old bush? Got braided brake hoses, fresh fluid (will CDV delete whilst under there and bleeding system) and rear arm bushes to change once there's a break in the weather. Only thing left to upgrade would be suspension and subframe bushes.Pictures of these items installed will be uploaded once fitted if anyone wants to see. As for previous boosting issues, I took the turbo off and gave it a good clean, was a state but no bearing play or bent/broken fins which is a bonus. Sadly no pictures of this as didn't really have time, however it helped a bit as boosts stronger but there's still the fluctuations. So going to try a new actuator a friend as laying around and if this doesn't work a new turbo as that's the only thing left to change and I'm running out of ideas. ha How she currently sits. Feedback and ideas welcome as always. Hefty. Quote Link to comment Share on other sites More sharing options...
HeftyDanielson Posted January 15, 2016 Author Report Share Posted January 15, 2016 Another update, with boring mundane drivel. Finally got around to fitting the braided hoses, CVD delete and fresh ATE super blue fluid, then this was found. . . . . Made the decision there to replace the copper brake lines as so. RH side, made a little too long and broken clip. LH side, little neater. Method of joining rather than replace the whole lines as they were fine, this was the best/strongest method. With these replaced, braided lines. CDV delete and fresh fluid the car feels awesome once again. With a fresh service completed @ 164,502, new oil (5w-40 fully), filters (oil, fuel, pollen), pipercross/maf/map clean the car fees great again. Mot and tax time. Nice and clean. New turbo, suspension and more polly bushes install coming soon. Off to Auto sport this weekend, so be nice little drive up the motorway. Comments always welcome. Dan. Ruesta and The_Judge_ 2 Quote Link to comment Share on other sites More sharing options...
rasa Posted January 16, 2016 Report Share Posted January 16, 2016 had to replace my rear brake pipes both sides to centre section as the fronts were fine,the rears are a bad design and get rotten easier,i used copper also.all done by a guy i used £60 all in,bargain back in september. HeftyDanielson and Ruesta 2 Quote Link to comment Share on other sites More sharing options...
HeftyDanielson Posted August 19, 2016 Author Report Share Posted August 19, 2016 Thought I'd give a little update on how things are going. First things first, I've finally fixed the boosting issue, by replacing the turbo. recon replacement from Essex turbos. Would recommend, very quick delivery and one of the cheapest quality ones about and 2 years warranty keeps me happy till I sell the car. Here's how it sounded on first startup. Haven't got many pictures atm but I've also installed 15mm/13mm spacers and a newer Eonon android head unit. Here's how the car currently looks. Will get more/better images soon once the further upgrades arrive. The_Judge_ and Ruesta 2 Quote Link to comment Share on other sites More sharing options...
HeftyDanielson Posted November 19, 2016 Author Report Share Posted November 19, 2016 Been a while since I've updated this properly, so here's an image dump. How she currently sits next to my friends IS200 after a car show. mentioned in the last post of 13/15mm spacers, here's how they looked. Had another service, all fluids, filters etc and used 5w-40 castrol Edge Fully Diesel oil. odometer for records. (yes, oil sensor has gone) Exhaust became a little more free flowing. Will get a sound clip up later on as the one I had recorded was on a awful iPhone quality. And how she is currently, still after a good FMIC, back box and then will get her mapped once again. More pictures, videos etc can be seen below. https://www.facebook.com/Vehicularenthusiasts/https://www.youtube.com/channel/UCKiTGOGdPL7JmgY9lwEOp_ghttps://www.instagram.com/vehicular_enthusiast/ Comments, thoughts and suggestions always welcome! Ruesta, TriggerFish, TERKIN and 1 other 4 Quote Link to comment Share on other sites More sharing options...
HeftyDanielson Posted December 26, 2016 Author Report Share Posted December 26, 2016 Little sound clip of how the exhaust sounds, got a stainless steel back box on the way, will update once that's all fitted. Thoughts on the sound? The_Judge_ 1 Quote Link to comment Share on other sites More sharing options...
HeftyDanielson Posted April 17, 2017 Author Report Share Posted April 17, 2017 (edited) Been a while since I've posted, mainly using this for history picture proof purposes. Fresh service and MOT again, nice clean mot and fresh oil (5w-40w fully) fuel, oil ad pollen filter. Nice oil and filters as always. Miles slowly rising, still drives beautifully and as tight as ever. Found the engine mount vac lines weren't looking the best, so changed for fresh lines. Finally got new wheels. Real "BBS Reps" 8Jx18 ET35 at the front, 8.5Jx18 ET45 (i think) at the rear. Also found a performance back box, as you can see in the pictures, here how it sounds. a hell of a lot of images/videos can be found below. https://www.youtube.com/channel/UCKiTGOGdPL7JmgY9lwEOp_g https://www.instagram.com/vehicular_enthusiast/ Edited April 25, 2017 by HeftyDanielson Ruesta, The_Judge_ and Markxr 3 Quote Link to comment Share on other sites More sharing options...
DaveNE Posted April 17, 2017 Report Share Posted April 17, 2017 (edited) Sounds Nice with the backbox on Pic's aint working dude. Edited April 17, 2017 by DaveNE HeftyDanielson 1 Quote Link to comment Share on other sites More sharing options...
HeftyDanielson Posted April 25, 2017 Author Report Share Posted April 25, 2017 On 17/04/2017 at 15:14, DaveNE said: Sounds Nice with the backbox on Pic's aint working dude. Fixed the pictures now. Google drive being crap. Quote Link to comment Share on other sites More sharing options...
