.Si. Posted March 28, 2015 Report Share Posted March 28, 2015 cars been of road since last september..so decided to take it for a spin the other day. got it on the motorway and hit cruise control button..which lit up on the dash...but it wouldnt work. not since its been in hibernation,its had new stainless brake pipes with a full flush. new rad,waterpump,stat,headertank,puls system flush.. car runs sweet like it always has done..no lights on anywhere. done some searches but nothing comes up for the 330d. any ideas?? thanks Quote Link to comment Share on other sites More sharing options...
Rob- Posted March 28, 2015 Report Share Posted March 28, 2015 Sounds daft but did you press the up button? Failing that sometimes a failed/failing MAF can cause issues with the cruise control. .Si. 1 Quote Link to comment Share on other sites More sharing options...
DEVIL 666 Posted March 28, 2015 Report Share Posted March 28, 2015 Fuse/ MAF check. .Si. 1 Quote Link to comment Share on other sites More sharing options...
.Si. Posted March 28, 2015 Author Report Share Posted March 28, 2015 surely fuse must be ok as i have the light on the dash. Quote Link to comment Share on other sites More sharing options...
.Si. Posted March 28, 2015 Author Report Share Posted March 28, 2015 Sounds daft but did you press the up button? Failing that sometimes a failed/failing MAF can cause issues with the cruise control. yes mate..i did...kept switching it off and on...always got the light up on dash...but nothing else...and i was going over 30.lol Quote Link to comment Share on other sites More sharing options...
DEVIL 666 Posted March 28, 2015 Report Share Posted March 28, 2015 Have you tried to press the + button after the light was on? Quote Link to comment Share on other sites More sharing options...
.Si. Posted March 28, 2015 Author Report Share Posted March 28, 2015 Have you tried to press the + button after the light was on? i tried it every different way...after id switch it off and try again...nothing Quote Link to comment Share on other sites More sharing options...
The_Judge_ Posted March 28, 2015 Report Share Posted March 28, 2015 All the other buttons (volume etc) work ok? Quote Link to comment Share on other sites More sharing options...
.Si. Posted March 29, 2015 Author Report Share Posted March 29, 2015 All the other buttons (volume etc) work ok? Yes mate.. All radio ones work fine Quote Link to comment Share on other sites More sharing options...
.Si. Posted March 29, 2015 Author Report Share Posted March 29, 2015 Do I go buy a new Bosch maf? Quote Link to comment Share on other sites More sharing options...
Aamir Posted March 30, 2015 Report Share Posted March 30, 2015 (edited) Try MAF cleaner spray first. Not sure if it helps, but on my other car, the cruise control stopped working when I had an ABS fault, diagnosed & sorted that, CC started working again. Edited March 30, 2015 by Aamir Quote Link to comment Share on other sites More sharing options...
shafz Posted March 30, 2015 Report Share Posted March 30, 2015 get the car scanned for faults before you chuck money at replacing parts... Quote Link to comment Share on other sites More sharing options...
.Si. Posted April 12, 2015 Author Report Share Posted April 12, 2015 Well I bought a brand new genuine Bosch maf ... And it's still don't work. Could it be brake or clutch switch related? Just a thought .. Brake lights work ok btw Quote Link to comment Share on other sites More sharing options...
Trevor Posted April 12, 2015 Report Share Posted April 12, 2015 As shafz said, get the codes read. Quote Link to comment Share on other sites More sharing options...
Ragamuffin Posted April 12, 2015 Report Share Posted April 12, 2015 Wheel speed sensor? Quote Link to comment Share on other sites More sharing options...
.Si. Posted April 12, 2015 Author Report Share Posted April 12, 2015 I dont have any lights on dash so will codes show? Quote Link to comment Share on other sites More sharing options...
Trevor Posted April 12, 2015 Report Share Posted April 12, 2015 You can have codes that don't show warning lights. shafz and .Si. 2 Quote Link to comment Share on other sites More sharing options...
.Si. Posted April 12, 2015 Author Report Share Posted April 12, 2015 Ok. Thanks , I'll get it checked out. It goes into BMW on Friday for its airbag recall and a service, so may get them to do it Quote Link to comment Share on other sites More sharing options...
.Si. Posted April 13, 2015 Author Report Share Posted April 13, 2015 Had it on my mates snap on ethos code reader today.... Nothing untoward came up Swirl flaps even tho car font have them lol Egr .. Don't have that either Apart from that .. All clear. Nothing in abs Any thoughts Quote Link to comment Share on other sites More sharing options...
shafz Posted April 13, 2015 Report Share Posted April 13, 2015 this chap seems to have to same issue as uhttp://forums.m3cutters.co.uk/showthread.php?t=50240&page=2 clutch switch.... .Si. 1 Quote Link to comment Share on other sites More sharing options...
.Si. Posted April 13, 2015 Author Report Share Posted April 13, 2015 thought it maybe one of those...clutch or brake. yet the brake lights work so id have thought i could rule that out Quote Link to comment Share on other sites More sharing options...
TriggerFish Posted April 14, 2015 Report Share Posted April 14, 2015 INPA can show you what position it thinks the clutch is in, if you've got access to it? Quote Link to comment Share on other sites More sharing options...
.Si. Posted April 14, 2015 Author Report Share Posted April 14, 2015 No access to that at all mate I'm afraid Quote Link to comment Share on other sites More sharing options...
.Si. Posted April 17, 2015 Author Report Share Posted April 17, 2015 Well just got home from Fairfield BMW and it's been plugged in. Nothing coming up at all.. Not fault codes etc.. Said I need to book it in for a full test etc and that's £115. Any other ideas ? Quote Link to comment Share on other sites More sharing options...
RickyZ Posted April 17, 2015 Report Share Posted April 17, 2015 Si, I have INPA set up if you want to meet and have a look I will warn you though, I have a Corsa now LOL B0B and .Si. 2 Quote Link to comment Share on other sites More sharing options...
