bachu
Style 162
You should be OK. Try looking around/asking on E46Fanatics or Bimmerpost - a quick look on Google Images came-up with several pics from both of them.
Guessing it's the same 255/35/18 rear tires means your wheel will stick out a further 13mm over standard MV1/2 alloys, should be fine on your car as you've already rolled the arches.... should fill the arch without need for further spacers.
For future reference have a look on the below site to check fitments
http://www.willtheyfit.com/index.php?width=255&aspect=35&diameter=18&wheelwidth=8.5&offset=50&width2=255&aspect2=35&diameter2=18&wheelwidth2=8.5&offset2=37#content
Not sure if you've seen the brilliant site listing all the OEM BMW wheels with sizes (inc tires) along with weights and offsets - http://felgenkatalog.auto-treff.com/
Edited by CharlE46
post-15254-0-59535500-1431286062_thumb.j
Fitted these style 162's yesterday, well happy but got slight rubbing on rear arches? Running 255/35x18 rear and 225/40x18 front, they really fill the arches and look so wide....
Edited by maxis740
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
