vtidaz
Auto gearbox occasionally hesitant to engage drive
Hi guys,
As above, occasionally (only after a start up, sometimes the engine is already warm sometimes not) after selecting drive the gear doesn't engage for sometimes upto a miniute...or sometimes it does, but then a few yards down the road it drops out of gear for a few seconds (the gearbox stays in drive mode).
I remember reading somewhere about it being a safety system and drive doesn't engage until the gearbox oil has circulated enough...is this a common occurance? Should I be concerned about it? I will be changing the tranny oil at the end of the month (as part of routine service, I dont think its related).
Thoughts?
do you have the limp mode sign on dash? I would get it check on diagnostic system before oil change. Get the filter changed aswell
No limp mode and no errors through diagnostics, I had it scanned just the other week. A while ago I did get a (!) come up under the "D" on the little screen that shows your current drive and the car went into limp mode, I pulled over and restarted the engine and it hasn't been on since... That was around a year ago though!
Sent from my HTC One_M8 using Tapatalk
Change the gearbox oil.
