Ashley_r84 Posted September 15, 2015 Report Share Posted September 15, 2015 My washer jets have started to fail on me for some reason, they are very very weak (to the point where I thought I was out of screenwash). This started about 3 weeks ago and doesn't seem to be getting any better. The wash barely reaches the windscreen and as far as I can tell the headlight jets have stopped working too but I cannot confirm this just yet. Would any of you know what could be causing this and would it be an easy fix? Any help is appreciated. Thanks Ashley Sent from my D6603 using Tapatalk Quote Link to comment Share on other sites More sharing options...
TriggerFish Posted September 15, 2015 Report Share Posted September 15, 2015 There's a filter in the tank, stage attached to the pump. I bet it's blocked momo, StuBeeDoo and daddyo 3 Quote Link to comment Share on other sites More sharing options...
X-Man Posted September 15, 2015 Report Share Posted September 15, 2015 (edited) Do you have headlight washers? Are they OK?Check the filter in the washer bottle. Pull the pump and there's a little mesh filter under there that gets gunked up.Also, the jets themselves get blocked. I cleared mine by disconnecting the hose and blowing them throughEdit: Must type faster Edited September 15, 2015 by X-Man Quote Link to comment Share on other sites More sharing options...
Larry D Posted September 15, 2015 Report Share Posted September 15, 2015 Look at the feed hose for the jets, crimped because the bonnet ruins it? Quote Link to comment Share on other sites More sharing options...
dooge Posted September 15, 2015 Report Share Posted September 15, 2015 Out of curiosity how often do the headlight washers spray? Is it every 3rd cycle of the windscreen washers being used? Quote Link to comment Share on other sites More sharing options...
TriggerFish Posted September 15, 2015 Report Share Posted September 15, 2015 It can be altered with ncs. 3 or 5 is default though (5 springs to mind) dooge 1 Quote Link to comment Share on other sites More sharing options...
Ashley_r84 Posted October 2, 2015 Author Report Share Posted October 2, 2015 Cheers guys, just got back from America so will try and clean it all out over the next few days..hopefully it'll work:-) Sent from my D6603 using Tapatalk Quote Link to comment Share on other sites More sharing options...
StuBeeDoo Posted October 2, 2015 Report Share Posted October 2, 2015 There's a filter in the tank, stage attached to the pump. I bet it's blocked This ^^^ I had to do mine again today. That's the 4th or 5th time in just over 2 years. I've been told Renault pre-mixed screenwash fluid could be the answer, so I'm giving it a try. Quote Link to comment Share on other sites More sharing options...
daddyo Posted October 2, 2015 Report Share Posted October 2, 2015 There's a filter in the tank, stage attached to the pump. I bet it's blocked This ^^^ I had to do mine again today. That's the 4th or 5th time in just over 2 years. I've been told Renault pre-mixed screenwash fluid could be the answer, so I'm giving it a try. Jesus, what do Renault pre mix with? raw sewage? Quote Link to comment Share on other sites More sharing options...
quackers Posted October 3, 2015 Report Share Posted October 3, 2015 I think it's just any screen wash that causes it. It just congeals into a glob of soft gel right where the filter is. Pluck it out of there and start again :-) Quote Link to comment Share on other sites More sharing options...
Trevor Posted October 3, 2015 Report Share Posted October 3, 2015 Just cleaned mine. Been done before but had noticed the washers weren't as powerful recently. Needs doing annually I reckon. Quote Link to comment Share on other sites More sharing options...
StuBeeDoo Posted October 3, 2015 Report Share Posted October 3, 2015 Needs doing annually I reckon. Judging by my own experience, I'd say double that - every Spring & Autumn. Quote Link to comment Share on other sites More sharing options...
Rob- Posted October 3, 2015 Report Share Posted October 3, 2015 I always got the problem of a gunged up filter when using premixed 5 litre bottles of blue screenwash (holts for example). Once i started using halfords concentrate and mixing my own it stopped. Quote Link to comment Share on other sites More sharing options...
StuBeeDoo Posted October 4, 2015 Report Share Posted October 4, 2015 (edited) I always got the problem of a gunged up filter when using premixed 5 litre bottles of blue screenwash (holts for example). Once i started using halfords concentrate and mixing my own it stopped. My own experience is using the blue Holts concentrate (ie dilute-it-yourself). I always stuck to a 10% (1 part concentrate to 9 parts water) mix, irrespective of what the label on the bottle said. It's only just occurred to me as I'm typing this, but maybe using demineralised water rather than tap water would help. Edited October 4, 2015 by StuBeeDoo Quote Link to comment Share on other sites More sharing options...
Tewkes Posted October 4, 2015 Report Share Posted October 4, 2015 How does the filter pull out and where from? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
StuBeeDoo Posted October 4, 2015 Report Share Posted October 4, 2015 How does the filter pull out and where from? Drain the tank, disconnect the plug(s) from the motor(s) and the level sensor. Undo 1x 10mm bolt in the top on the tank and lift the tank slightly. Pull the motor(s) from the tank. Lift the tank fully out of the car. The filter(s) is/are part of the grommets that seal the motors to the tank. Carefully prise the grommet(s) from the tank. Make sure you thoroughly decontaminate the tank before refitting. Ashley_r84 1 Quote Link to comment Share on other sites More sharing options...
Ashley_r84 Posted December 7, 2015 Author Report Share Posted December 7, 2015 Still not got round to sorting this out as I was in America when I posted but thanks for the help. Thanks for the walk-through stubeedoo, much appreciated. I may get around to doing it on Monday:-) Sent from my D6603 using Tapatalk Quote Link to comment Share on other sites More sharing options...
bushn19 Posted December 8, 2015 Report Share Posted December 8, 2015 Mine aren't working at all, how do I drain the water out so I can do the above procedure? Quote Link to comment Share on other sites More sharing options...
mjn Posted December 9, 2015 Report Share Posted December 9, 2015 Pull the washer motor for the headlights out. Quote Link to comment Share on other sites More sharing options...
Ashley_r84 Posted December 16, 2015 Author Report Share Posted December 16, 2015 Just did this finally, so easy and everything works a treat. I would normally have paid a garage to sort it cos I'm useless with cars but thanks to you guys it's all sorted:-) Thanks again Sent from my D6603 using Tapatalk Quote Link to comment Share on other sites More sharing options...
jlnewland Posted July 15, 2017 Report Share Posted July 15, 2017 Yeah, thanks to those who posted on here. Had the same problem for the first time and fixed in 20-30 mins. Cheers! mjn 1 Quote Link to comment Share on other sites More sharing options...
