shabir
rear spring pad part numbers
Hi guys, wondering if i can get the part numbers for the 10mm and 14.5mm spring pads, thinking of using thicker ones as currently with the 5mm it sits very low. Also would you guys know how much they are roughly
Thanks for that, checked real oem 1st, and with my car details only found the 5mm pads, tried some other ones just know and got the 14.5mm, but cant seem to locate the 10mm.
Hi guys, just nudging this to save making a new thread.
Are the standard spring pads for a 330ci sport 5mm front and rear??
Need to level off mine so want to make sure I am getting the right replacements
thank you
JD
Guys
still trying to find confirmation on the stock Spring pad size? Either that or I I'll have to sandwich new ones on the existing ones on the drivers side.
Thanks
20 hours ago, jd26 said:
Guys
Thanks
According to realoem the stock ones are 5mm
http://www.realoem.com/bmw/enUS/showparts?id=BD52-EUR-05-2004-E46-BMW-330Ci&diagId=33_1025
