bennno2005 Posted December 16, 2015 Report Share Posted December 16, 2015 3 minutes ago, hass0250 said: yeh i dont mind the mileage is just that this is this is the only one available at the time, im in two minds of getting it know, what also puts me of is the fact that its a 2004 model What model are you hoping to get? Quote Link to comment Share on other sites More sharing options...
hass0250 Posted December 16, 2015 Author Report Share Posted December 16, 2015 i mean the fact that it is a 2004 plate car would prefer newer plate not model sorry Quote Link to comment Share on other sites More sharing options...
330CDT Posted December 19, 2015 Report Share Posted December 19, 2015 FFS Hass lol. I just found you the perfect one! Seems a bit cheap though! Quote Link to comment Share on other sites More sharing options...
hass0250 Posted December 20, 2015 Author Report Share Posted December 20, 2015 Just my luck lol its an auto, saw that one aswell lol hopefully more manuals come up in the near year Quote Link to comment Share on other sites More sharing options...
hass0250 Posted December 20, 2015 Author Report Share Posted December 20, 2015 Found a bmw 330cd 06 plate mileage 125k But the problems are as follows quoted by the seller "when the clutch is half pressed it makes a rattling when fully pressed it goes away, and when driving along changing gear it doesn't rattle, the car drives perfect clutch is fine gets every gear no problem with no noises I have been told thrust bearing. Recent a Few times the traction control light has came on, couples times a week not sure why when lights out traction control is fine stops the car spinning back wheels no problem, I when lights on traction control is off" Quote Link to comment Share on other sites More sharing options...
hass0250 Posted December 20, 2015 Author Report Share Posted December 20, 2015 Is this going to cost alot to repair? Quote Link to comment Share on other sites More sharing options...
Melv1958 Posted December 21, 2015 Report Share Posted December 21, 2015 (edited) The rattle sounds like flywheel and the traction light coming on every so often wil be a sensor, normally DSC sensor, so while the flywheel needs replacing its common sense to change the clutch aswel while it's all off. oe clutch and flywheel fitted I'd say approx £900 DSC sensor £100 ish it won't be the thrust bearing as that doesn't rattle when the clutch is half way in that will still make a noise when the clutch is fully out. either or it's still going to cost a fair bit of money but any manual you buy could have this problem. Edited December 21, 2015 by Damo88 Quote Link to comment Share on other sites More sharing options...
rasa Posted December 21, 2015 Report Share Posted December 21, 2015 (edited) deffo sounds like dmf,but i would suggest more like £700 for clutch,dmf kit fitted,depends on wheer you live though,£450 in parts and £200-£250 labour,my two indis who i go to charge £25-£30 per hour Edited December 21, 2015 by rasa Quote Link to comment Share on other sites More sharing options...
Craig_09 Posted December 21, 2015 Report Share Posted December 21, 2015 I would say 100% the flywheel.. I recently had mine replaced for the reason above. Price the clutch kit and flywheel up on Eurocarparts. I paid around £350 in LUKparts and £150 labour. Quote Link to comment Share on other sites More sharing options...
rasa Posted December 22, 2015 Report Share Posted December 22, 2015 (edited) that sounds cheap for luk clutch,last time i looked it was over £300 for the dmf.and £130 or more for clutch kit,although this was at buypartsbuy.yep its nearer £500 for the whole kit at ecp,sure its cheaper at buypartsbuy,just checked Edited December 22, 2015 by rasa Quote Link to comment Share on other sites More sharing options...
Craig_09 Posted December 22, 2015 Report Share Posted December 22, 2015 Sorry I should of said for my 320cd I paid£350 and checked today it's £359.50. 330cd - £415.13 on Eurocarparts using discount code xmas. I paid £150 labour at my local BMW Specislist for fitting but factor in around 5 hours at whatever rate is in your area Quote Link to comment Share on other sites More sharing options...
hass0250 Posted February 8, 2016 Author Report Share Posted February 8, 2016 Hi guys, Finally got a 330cd black and black leathers Quote Link to comment Share on other sites More sharing options...
330CDT Posted February 8, 2016 Report Share Posted February 8, 2016 Pics required! You happy with it? Quote Link to comment Share on other sites More sharing options...
hass0250 Posted February 8, 2016 Author Report Share Posted February 8, 2016 Only issue is that when booting it in high gears rear rumble you have to drop it a gear and it goes away, seller said could be to the 240bhp remap? Quote Link to comment Share on other sites More sharing options...
rasa Posted February 8, 2016 Report Share Posted February 8, 2016 1 hour ago, hass0250 said: Only issue is that when booting it in high gears rear rumble you have to drop it a gear and it goes away, seller said could be to the 240bhp remap? could be dmf ,propshaft doughnut/bearings ,or is it an auto,and is it just the 184 bhp model with that remap. Quote Link to comment Share on other sites More sharing options...
hass0250 Posted February 8, 2016 Author Report Share Posted February 8, 2016 (edited) its a manual 330cd 204bhp stock - 240bhp remapped is it going to cost a lot to repair? Edited February 8, 2016 by hass0250 Quote Link to comment Share on other sites More sharing options...
Melv1958 Posted February 8, 2016 Report Share Posted February 8, 2016 (edited) It won't be because of the remap lol that's bull talk, it will more than likely be the diff and if so yes then yes very expensive diff,propshaft, propshaft bearing,DMF but that won't rumble from the rear Edited February 8, 2016 by Damo88 Quote Link to comment Share on other sites More sharing options...
hass0250 Posted February 8, 2016 Author Report Share Posted February 8, 2016 so it's defo the diff roughly what the cheapest i can get the parts and labour Quote Link to comment Share on other sites More sharing options...
Melv1958 Posted February 8, 2016 Report Share Posted February 8, 2016 I would say so yes it's the only thing that rumbles along with propshaft but if the propshaft rumbled it would do it all the time, you can't do it cheap, I believe it's in excess of £750 + for the diff Quote Link to comment Share on other sites More sharing options...
hass0250 Posted February 10, 2016 Author Report Share Posted February 10, 2016 apart from that car is in very nice condition, will post pic tomorrow. Quote Link to comment Share on other sites More sharing options...
scott-o Posted February 10, 2016 Report Share Posted February 10, 2016 Probably just the noise it makes when you're over loading it, i've never put my foot flat down below 2-2.5k rpm in any gear, its not good for any of the drive line. Glad you found one, it took me ages to find mine too, gave up on heated seats and HK for a 54k mile example, although its now got 88k on it! Keep getting tempted by the e90 335d's but really cant be chewed to sell mine at all! Quote Link to comment Share on other sites More sharing options...
hass0250 Posted February 10, 2016 Author Report Share Posted February 10, 2016 Yeah, thanks for the postive feedback been looking for around 7-8 months now this one was probs the best spec just has that issue, then again not easy to find a 11year old car that has no issues whats so ever. Quote Link to comment Share on other sites More sharing options...
hass0250 Posted February 12, 2016 Author Report Share Posted February 12, 2016 PICS!!! 330CDT and The Laird 2 Quote Link to comment Share on other sites More sharing options...
hass0250 Posted February 12, 2016 Author Report Share Posted February 12, 2016 Time for the mods, any ideas guys??? Quote Link to comment Share on other sites More sharing options...
Craig_09 Posted February 13, 2016 Report Share Posted February 13, 2016 Blank the swirl flaps Twin Tip blackbox like the petrol models (thinks there's one for sale on the forum) Remap Ebiach Sportlines Nice set of 19's hass0250 1 Quote Link to comment Share on other sites More sharing options...
