avalaugh Posted July 26, 2017 Author Report Share Posted July 26, 2017 Will do mate, still got the stock silencers so should be bad with just cats removed [emoji106] Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
RMJ Posted August 7, 2017 Report Share Posted August 7, 2017 Hows the build going? Quote Link to comment Share on other sites More sharing options...
avalaugh Posted August 18, 2017 Author Report Share Posted August 18, 2017 Finally able to log back in again to the forum. It's going well, all cats removed, exhaust really isn't loud at all, will get a video up at some point. Have been busy tuning with George Gelashvili, but unfortunately hit a few setbacks. 1st issue was the timing kept retarding, traced that back to the gearbox exhaust hanger, at high RPM only there was a vibration that was causing the knock sensor to activate. After that was sorted, 2nd issue was again at higher RPM the MAF sensor was over compensating and in turn the fueling was massively rich, that turned out to be the recirc valve was letting by and causing air to be blow back through the MAF, so fitted a FORGE recirc valve to cure that. And finally after lots of mapping sessions we've reached the limit of my 330cc injectors. So for now I'm still running 8psi but the clubby is pulling harder than ever. I'm off to the Nurburgring on Thursday so upon my return I'll throw in bigger injectors and continue to chase 400bhp [emoji106] Sent from my iPhone using Tapatalk TriggerFish and R11CH 2 Quote Link to comment Share on other sites More sharing options...
avalaugh Posted August 24, 2017 Author Report Share Posted August 24, 2017 Fitted a non armrest centre console last night.Off to the Nurburgring today, will update over the course of the week [emoji106]Sent from my iPhone using Tapatalk Markxr, TriggerFish and R11CH 3 Quote Link to comment Share on other sites More sharing options...
avalaugh Posted August 24, 2017 Author Report Share Posted August 24, 2017 Smashed it out here, got a few sighting laps in this evening, will hook up the camera over the weekend for some fast footage hopefully [emoji106][emoji108]Sent from my iPhone using Tapatalk R11CH and RMJ 2 Quote Link to comment Share on other sites More sharing options...
avalaugh Posted September 23, 2017 Author Report Share Posted September 23, 2017 Managed a sub 9 minute lap this year, pretty pleased with that [emoji106]Sent from my iPhone using Tapatalk TriggerFish 1 Quote Link to comment Share on other sites More sharing options...
avalaugh Posted September 23, 2017 Author Report Share Posted September 23, 2017 Also got a lap in an M1 and E90 M3 which was good funSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
avalaugh Posted September 23, 2017 Author Report Share Posted September 23, 2017 Anyway, moving forward now with a forged build, possibly going TURBO if I sell on the super charger kit, but time will tell. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
avalaugh Posted September 23, 2017 Author Report Share Posted September 23, 2017 So for now this will be my last post, if I end up keeping the super charger I will continue with this build thread, and if things turn towards a turbo I shall start a new thread. Sent from my iPhone using Tapatalk Markus5000 1 Quote Link to comment Share on other sites More sharing options...
R11CH Posted September 24, 2017 Report Share Posted September 24, 2017 20 hours ago, avalaugh said: So for now this will be my last post, if I end up keeping the super charger I will continue with this build thread, and if things turn towards a turbo I shall start a new thread. Sent from my iPhone using Tapatalk You know its the later one 😉hope to see a new thread soon. avalaugh 1 Quote Link to comment Share on other sites More sharing options...
Markxr Posted September 24, 2017 Report Share Posted September 24, 2017 Can you not run both or is it to much work getting them to run avalaugh 1 Quote Link to comment Share on other sites More sharing options...
avalaugh Posted September 25, 2017 Author Report Share Posted September 25, 2017 Can you not run both or is it to much work getting them to run There's really no point, a centrifugal super charger like this makes its power at the top end anyway, so any decent turbo will perform and spool up fast enough.Sent from my iPhone using Tapatalk Markxr 1 Quote Link to comment Share on other sites More sharing options...
