avalaugh
Super Charging build thread.
Will do mate, still got the stock silencers so should be bad with just cats removed [emoji106]
Finally able to log back in again to the forum.
It's going well, all cats removed, exhaust really isn't loud at all, will get a video up at some point.
Have been busy tuning with George Gelashvili, but unfortunately hit a few setbacks.
1st issue was the timing kept retarding, traced that back to the gearbox exhaust hanger, at high RPM only there was a vibration that was causing the knock sensor to activate.
After that was sorted, 2nd issue was again at higher RPM the MAF sensor was over compensating and in turn the fueling was massively rich, that turned out to be the recirc valve was letting by and causing air to be blow back through the MAF, so fitted a FORGE recirc valve to cure that.
And finally after lots of mapping sessions we've reached the limit of my 330cc injectors.
So for now I'm still running 8psi but the clubby is pulling harder than ever.
I'm off to the Nurburgring on Thursday so upon my return I'll throw in bigger injectors and continue to chase 400bhp [emoji106]
Smashed it out here, got a few sighting laps in this evening, will hook up the camera over the weekend for some fast footage hopefully [emoji106][emoji108]
Anyway, moving forward now with a forged build, possibly going TURBO if I sell on the super charger kit, but time will tell.
So for now this will be my last post, if I end up keeping the super charger I will continue with this build thread, and if things turn towards a turbo I shall start a new thread.
You know its the later one 😉hope to see a new thread soon.
Can you not run both or is it to much work getting them to run
There's really no point, a centrifugal super charger like this makes its power at the top end anyway, so any decent turbo will perform and spool up fast enough.
