DJ Syxx
***SOLD D2 Coilovers to fit all E46 coupe/touring/saloon***
1 post in this topic
DJ Syxx
I have for sale a full set of D2 coilovers to fit the E46. I bought these new for my M3 and have covered around 5000 miles and approx 2 years old. These are really decent coilovers and you have 36 point control of dampening from soft to hard along with front camber adjustable pillowball plates. The spring rates aren't harsh at all and are 9kg front and rear.
Only reason I have removed these is because the M3's use offset top mounts and these are normal central ones which are perfectly fine for the normal E46 but not for the M3 as the M3 has a higher castor angle. D2 don't sell M3 specific offset top mounts so for that reason is why they are off.
Condition wise they are really good and haven't been taken on the track or mis-used and were all in working order prior to removal.
Everything is there to fit on the car it comes with its own top mounts as mentioned only thing you will need is rear shock mount gaskets and potentially spring pads depending what yours are like along with drop links.
Pics as below:
24224448570_3fc1a5c8db_c.jpgIMG_0866 by DJ Syxx, on Flickr
23891817024_fa21daee59_c.jpgIMG_0869 by DJ Syxx, on Flickr
24224445590_4a9ae210fc_c.jpgIMG_0870 by DJ Syxx, on Flickr
23893184113_e1569700c8_c.jpgIMG_0871 by DJ Syxx, on Flickr
24224442430_feacf4605a_c.jpgIMG_0880 by DJ Syxx, on Flickr
24411708042_b415206d43_c.jpgIMG_0883 by DJ Syxx, on Flickr
Edited by DJ Syxx
