J15 CJY
Amber DSC and brake light help
Hello all
today my battery decided to fail ( I knew this was in its way out) as I had the ignition on draining it ( with radio and air con running without the engine on).. The problem is, when I got the car restarted both my DSC and brake light stay on...
Ive read that this could be to the front speed sensor going or the angle sensor.. I've tried the trick where you turn the wheel left then right again (full lock each) but doesn't fix problem... Is this the problem??? Thing is if it it why did it come up when I jump started the car??
thanks
You'll need to get the codes read.
I recently had this and it turned out to be the DSC pressure sensor which is on the bottom of the master cylinder.
Ben
