Leonrox557
Driver one-touch up not working, help?!
Hi guys,
As per the title, my drivers side window doesn't one-touch up but it does one-touch down?!
When pressing & holding the unlock button both front windows will go down... when pressing & holding the lock button, only the passenger one closes!
Now I've looked through forums and attempted to re-set the one-touch - using the suggested methods but no luck!
Any suggestions?
you have to follow the steps for this,it should be in the handbook if you have one,otherwise there is a how to in the how to section,but it goes summit like this,turn key to position 2,press window down,keep finger on button for 10 seconds when its all the way down,then wind it up,and repeat for up i think,but you better check the how to.i will have a look later to check.here it is,but in future its easier to look these type of things up instead of starting a new topic,not having a go ,just advising.....
Edited by rasa
I had to resync mine today on the 'Vert after a new battery. The passenger side window took about 10 attemps to resync, strange, but worked in the end.
The coupe's have a sensor strip at the top of the window, so if nothing else works then this might be playing up.
