jayartibee
suspension clonk
After 800 miles on Irish rural roads last summer - and a few thou since - one side of my rear suspension is making a clonking noise over small bumps - getting worse. Is this most likely a shock absorber bush?
Jeremy
mine got steadily worse,i had noticed a leaking rear shocker,mine was hopping at rear when taking left handers at a decent pace and wallowing all over,£80 for meyle full damper/shock kit and i got charged £40 to fit it...
Could be a few things from a broken spring to a worn bush, only way to tell is to get under the car and inspect the springs and use a lever bar on the arms to check the bushes and spherical bearings on the hubs.
subframe bush?top mounts on shocks?
Edited by rasa
