Simon76 Report post Posted May 3, 2017 Hi I'm new to this and the e46 ! Ive got a 330 which was running ok until it ran out of fuel Now it cranks over but no fuel getting to the rail and no pressure. Have looked around online tried recommended fuse 54 and cluster under bonnet common problem apparently. Also changed relay with horn one and checked pump there is power to it when turning over and have tested and replaced pump still nothing I'm at a loss now if anyone has any suggestions I'd be most grateful?? Quote Share this post Link to post Share on other sites
R11CH Report post Posted May 3, 2017 Most likely the fuel pump has failed. Very common problem. Mine failed a few hundred miles later after running out of fuel. Was your pump noisey before ? Quote Share this post Link to post Share on other sites
Simon76 Report post Posted May 3, 2017 That's what I thought so it's now got a new pump ??? tearing my hair out ! Quote Share this post Link to post Share on other sites
R11CH Report post Posted May 3, 2017 23 minutes ago, Simon76 said: That's what I thought so it's now got a new pump ??? tearing my hair out ! Hmmm So is the pump actually priming? Quote Share this post Link to post Share on other sites
Simon76 Report post Posted May 3, 2017 It's got power to it relay working properly pump has been dry tested all ok but no not priming nothing at all ! Do they need purging ?? Quote Share this post Link to post Share on other sites
ibrahimx2001 Report post Posted May 5, 2017 Have you checked the fuse too as well as the relay? Quote Share this post Link to post Share on other sites
