I followed the advice on previous posts about PDC not working. So far I have tried the following:
Installation of new PDC Control unit
I found no fuse 5 amp fuse so installed another 5 amp in location 24 according to the diagram for fusebox.
And cleaned and replaced one broken pdc sensor.
Only things I can think of is one sensor has a lose connection or the speaker near footwell light is dead. Anything else it could be?
Do you get the long beep when you engage reverse? Or nothing at all?
Sounds like someone has removed or disconnected the speaker.
Should make a long beep if you have a faulty sensor.
Or speaker could be faulty.. Not sure how you'd test it!
I think it's on the dash panel just above the pedal box?
