ian1001
E46 330cd convertible 2005 weird electrical glitches
Hi my 330cd has a few electrical niggles.
The outside air temperature sensor reads -40
the obc not working (stuck on time, won't scroll through)
window washer bottle is illuminated even though its nearly full
passenger mirror not adjusting.
Rear parking sensors not beeping at all (no clicking)
I ran diagnostic on the pdc and theres no fault code and no issues with the instrument cluster. Also the pdc beeper works when I activate it with my diagnostic, the mirror moves with the diagnostic and no fault code for the outside air temperature!
I've left the battery disconnected for 2 hours and still I have these issues can anyone suggest anything?
kindest regards
do a needle sweep,and try and change temp through same hidden menu.
The temp sensor control module is housed in the dash I believe. I had the same issue with an E60 and had to change the dash then get the vin changed and mileage matched to the car.
What did you use to read the codes? I found INPA not up to scratch where as DIS would allow you to run individual tests on each module.
Hi I have INPA and I also have a delphi ds150e clone scan tool I got from china.
The only thing I can think of is I had the origional battery for 11 years and it was starting the car but not holding the right voltage so I got a new battery I thought all the glitches were due to the old battery dieing however they are still there!
Not for the outside temperature - that's in one of the wheel arches. (Passenger side, IIRC)
The sensor will be, but the module to control it is built into the dash.
                            Faulty ign switch will give odd reading and stop things working,My
                        horn ,radio and mirrors started playing up as well.
thanks is there anyway to test the ignition switch. The car operates fine starts first time etc.
Weirdly I even get a beep when it's under 3° which suggests the sensor is working, however I get the fault code outside air temperature on my delphi tool. I clear it and it comes back.
Also I cannot scroll through the on board computer anymore.
Edited by ian1001
