dunk1 Posted October 6, 2017 Report Share Posted October 6, 2017 Can't find the figures for this Anyone know or can link me to them for my 330 Ci M sport vert Quote Link to comment Share on other sites More sharing options...
mjn Posted October 6, 2017 Report Share Posted October 6, 2017 I think there is a little bit of personal preference involved, especially when it comes to toe. Quote Link to comment Share on other sites More sharing options...
dunk1 Posted October 7, 2017 Author Report Share Posted October 7, 2017 (edited) I found some alignment figures on E46 fanatics and cant post it but here are the numbers i've copied from it Front toe ------------ 14 minutes +/- 8 minutes Front camber ---- 43 minutes +/- 20 minutes Caster -------------- 5 degrees 47 minutes +/- 30 minutes Rear toe ------------ 16 minutes +/- 6 minutes Rear camber -----2 degrees 4 minutes +/- 15 minutes I had my car on a recommended 4 wheel alignment and dont get why their system says my rears are out and need adjusting My figures as follows Front toe ----------- 9 minutes total Front camber ---- 1 degree both sides Caster -------------- 5 degrees 47 minutes Rear toe ----------- 16 minutes total Rear Camber -- 1 degree 41 minutes, both sides the same I had the front toe adjusted as they were out and had worn the osf tyres outer edge but the rears tyre wear wise look pretty good so i left them alone, not sure if i was being conned out of a chunk of cash or if their machine has the right figures in it or are the figures i found wrong ? Edited October 7, 2017 by dunk1 Quote Link to comment Share on other sites More sharing options...
