JayP07
How to undo these condenser connectors?
4 posts in this topic
JayP07
Afternoon all,
I have a bad water leak and just wanted to get some pointers before I start sorting it after work.
Just want someone to confirm - How does this connector come off? the leak is coming from the top one....
standing at the front of the car they plug into the condenser on the right hand side.
Much appreciated!
Jason
you can get a special tool for those connectors, I forget what it’s called though, looks like a little cube that fits over the connector. it’s a quick release connection, you have to press the black plastic inwards while keeping it flat so even pressure all the way around which releases the tabs inside allowing you to remove the hose. I attempted this with spanner’s on my power steering hoses and one came off and I had to cut the second one.
CTA Tools 3466 BMW Power Steering and Transmission Line Disconnect Tool https://www.amazon.co.uk/dp/B009VI9P62/ref=cm_sw_r_cp_api_30ooAbND71SJ6
if you search for diy’s on power steering hoses that may help.
Edited by incredirog
updates
JayP07
Thanks for the reply mate and pointing me in the right direction :) What a pain in the butt tool... Think i'm go to have to try some small screwdrivers first.
JayP07
Just to update this topic... the round black plastic bit at the front of this connector is supposed to be the release tool for a spring in side the connection and by pulling it back evenly you release the spring and can pull off the hose.
Create an account
Register a new account
Sign in
