jayla
coolant leak please watch video clip Head gasket?
2 posts in this topic
jayla
Hello
I need some advice please regarding coolant leak seen on video clips below. 2 weeks ago I had misfire gave to  mechanic who clearly ripped me off because he told me he change ignition coil which he did not. Computer said misfire on cylinder 3. So he changed the leads and I told him to change spark plugs at a cost of 280 pounds.
Now the car is leaking coolant. I did a pressure test and saw a bit leak from thermostat even though I changed it 2 years ago. I installed a bmw one now and I thought problem fixed. Looks like it leaking from back of engine aswell. Please look at clip. I am worried that it could be head gasket :(  . While I was doing this I also did the oil change front pads and disc and anti roll bar.
https://drive.google.com/file/d/10mJrNF2BedLJ7KqyKv-veirVih13bYtf/view?usp=sharing
https://drive.google.com/file/d/1MLcF26vA-txcLk2KKfanlgrjQW0gZiUV/view?usp=sharing
The old oil looked ok but had abit of water effect on the oil maybe. Car does not misfire or never has over heated. Why did all happened after I got it back from repair with spark plug and lead repair.
I hope I don't have to get read of the car as I just spend 500 pounds and now this on the m43 engine with only 62k miles and serviced every year
Daniel G
did you have any  luck with this ?? Im contemplating using bars leaks or a headgasket repair that you add to the coolant and it binds with gaskets to repair leaks.
Create an account
Register a new account
Sign in
