Robp2023 Report post Posted November 28, 2018 Hi guys been given this list by a local mechanic as a jobs list for mot. I've got a w reg 323i ive ordered the front control arm bushes and the intake pipes but not sure which bits to order for the upper arm bush and rose bush. Quote Share this post Link to post Share on other sites
Daz 330 Cs Report post Posted November 29, 2018 Powerflex bushes are all you need, far better than anything else. Fit and forget Quote Share this post Link to post Share on other sites
rasa Report post Posted November 30, 2018 arms etc will have to come out,,then get bushes in,,so unless your doing it yourself,,is it worth it,,depends how much mechanic is charging for labour,,ive justb changed all front arms on my e90 330d,,control arms/radius arms/drop links,,the guy i used had to use heat,,so the ball joints/knuckles were shot with the heat anyway,,good luck though,,ps arms are different shape on the e90,,,but when i had control arm(lower) rear bushes done on my e46 i remember he just cut the bush out with a grinder and replaced the bush without taking the whole arm off.. Quote Share this post Link to post Share on other sites
