dunk1
LSD Oil
I've had a search but thought i'd get your input on what oil you use in the lsd diffs
2004 330 Ci M sport
Not sure there's many LSD owners left on here tbh..
Have you tried Opie for a suggestion?
I'm just on Opie's site now and it doesn't mention LSD's, i've popped my
reg in and its come up with my car and lists one option of Motul Gear 300 synthetic 75w90
Edited by dunk1
Give them a call - was much easier when you could just message Guy directly! :lol:
He always seemed to know his stuff..
Think i'll just call BMW and see if they can sell me it without raping me
Just spoke to my local BMW dealer and its £35 for 1 litre !!! the diff holds 1 litre
He's just told me its sealed for life set up on those so should i bother changing it ?
That'll be standard open diff oil, not LSD oil.
Standard diffs are supposed to be sealed for life but most people replace the oil anyway as the fill/drain plugs are relatively accessible.
I would imagine LSD oil would be different to standard crappy diff oil.
He got the oil from my chassis number so i can't see that being wrong, i'm not
paying £35 a litre for it thats for sure. i'll speak to Noel at NCB Autokraft and see
what he recommends
Ok, so to confirm - you have a standard, open diff or an aftermarket LSD (Quaife/Gripper etc..)?
No E46 comes with an LSD apart from the M3 from factory.
If it's the standard diff then this should do - it's what I put in mine.
https://www.opieoils.co.uk//p-737-castrol-syntrax-longlife-75w-90-fully-synthetic-car-gearbox-oil-formerly-saf-xo.aspx
Edited by momo
2004 330 Ci M sport
Hi,
Has your E46 got the factory fitted LSD option or have you fitted an aftermarket LSD? The 330Ci M Sport does not come as standard with an LSD.
Regards
Jack
Unless you’ve swapped an m3 diff and subframe into your 330 it will be very unlikely you have an LSD. Ive added a quaife into mine and it runs fully synthetic 75w-90 differential oil. Clutch type LSDs run different oil where as helical gear’d ones use standard open diff oil. Hope that helps [emoji106]
Sorry for my late reply, its an open diff in my car so ignore the question but thanks for the
responses guys
