Pnesshead
Vibration from steering wheel when braking
Hi , I’ve got slight vibration coming through the steering wheel , only when braking from high speeds
it’s not there when braking hard  at low speeds
any ideas ? Thanks
Get your front wheels off and have them balanced but also checked for damage to the alloy wheel. Also check the tyres for any damage.
After that try re-bedding in of your discs-pads - read this (proper guide is towards the end of the article) - http://powerbrake.co.uk/tech_info/tech_02_bedin.htm
This all assumes of course that your calipers/pistons are sliding freely and the hub-disc-wheel faces are clean and flat when fitted.
Edited by Jim27
Sounds like warped discs to me.. It'll be more pronounced at higher speeds. They're probably not that warped to notice at lower speeds.
Hi thanks for reply , when I bought the car the front alloys were  very badly curbed , the vibration  when braking from high speeds  was really bad . I had the car looked at by mechanic and he had good look around car and said everything looked ok , but noticed drivers front control arm had been replaced
i asked him to balance the front wheels , that’s when he noticed the drivers front  alloy was badly buckled , so looks like previous owner has hit a curb hard!!
I have just bought a good set or refurbed alloys  with good tyres ,  hoping this would sort the problem , it’s a lot better than it was but there’s still slight vibration  at high speeds the guy I bought the alloys from had a look at my brakes, he said the discs looked a little thin, but everything looked ok but my rear pads are low and only have roughly 1000miles left , so these will be replaced next week, I’ve also noticed the handbrake needs adjustment as not holding on hills
it’s a 330ci Conv by the way
cheers
any ideas ? Thanks
Have the suspension mounts checked
