JamieH1975
2003 E46 330ci msport Convertable - Drivers window & door issue
Good Morning,
Has anyone had this issue before? My Drivers Window has stopped the auto drop & lift when opening and closing the door, It also does not register that the door is open on the information panel on the dash, which means the alarm doesn't arm but the door does lock from the remote. The window mech works fine and I've tried the reset up and down various times but it still does the same.............
Thanks
Maybe "hall sensor" on the door lock,take door panel off and check for breaks in wiring to door lock plug,and also Check contacts in the plug itself.may find earth contact has corroded?
