Craig330
Convertible roof stopped working
Hi my roof stopped working at the weekend and I had the red flashing light by the switch.  Reading the forums everybody said the culprit was likely to be the loom where the first bend is above the passengers head.  As per the photo that’s exactly what mine was.  Carefully open up the loom and I soldered the brown wire together. Wrapped it in insulating tape (needs a better long term fix).  And it works ! Apologies if this hasn’t been posted before but I read so many forums where the solution isn’t posted. Cheers Craig
Following on from this is there any preventative maintenance that can be done on the roof
Sorry to jump on the post
Thanks, that's a useful bit of info.
My red light was flashing too when I put something big in the boot and it pushed up against the roof storage box, the part you can raise and lower. I thought the roof had gone kerput but I just needed to raise and lower the box with the lever and it was fine again.
