dec74n Report post Posted October 28, 2019 Right brief historyExpansion tank exploded at 150k on original tankReplaced with behr tank, all was goodRadiator leaked, replaced Then replacement tank started to leak from the bottom, reseated many times but didn’t feel rightReplaced with new behr tankAll was good but now leaking againSo am I doing something wrong or do I need to replace the bracket that it seats on toMany thanks Any suggestions Also replaced just new cap and thermostat not long ago when stuck open Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
kirkynut Report post Posted November 2, 2019 Were you careful to lubricate the seals with something to prevent them from tearing? I use a little red rubber grease. Perhaps take it all apart and re-fit with some red rubber grease to make sure that you have it all fully seated with no sticking points. Dry seals might seem fully seated but may not be. I found coolant does not act as a good enough lubricant and could see the joints were not fully seated and have the grease, so used it with good results. Kirkynut Quote Share this post Link to post Share on other sites
