Steve330ci
Front hub 330ci
Hello,
New member with a question. just swapped the front hub and bearing over on my 330ci. I have read to tap it onto the stub axel then use the nut to wind it on then torque the nut upto 290nm.
My question is by doing this will the bearing have been pushed up the stub far enough and seated properly by torquing the nut. The Outer face of the nut ended up flush with the end of the stub axel so you can seal the nut on.
just want to make sure it is on correctly etc.
many thanks.
Edited by Steve330ci
1 hour ago, Steve330ci said:
Hello,
many thanks.
