AIDAN TORBAY 320 Ci
Angel eye fires?
Ive had my CCFLS in for about 3 months now and never had a problem, just make sure you insulate the wires correctly at the connections and you will be fine.
Fires caused by CCFLs are fairly well known, but mainly in the states, where they wire them up
with a harness and connect them to the accessory wire in the ECU so they're always on.
Because of this, I gather, the ballasts tend to fail quite often and melt their connectors, causing fires
and charring wires and sometimes headlamp housings etc.
Wouldn't let it bother you, but be prepared to have problems with the ballasts at some stage. I went
and bought LED array angel eyes because I didn't want any of the associated issues. Alot dearer, but
they look 100 x better and brighter.
going to add some extra heat-shrink on just for added safety!!
They should have some in the kit...mine had extra on the wires...
Never heard of them setting fire! As said the only problem you will have with them is the ballasts at some stage will fail. Make sure you purchase from a reputable seller ie Teddy @ SSDD Motorsport or BM Styling as they can supply replacement ballasts whenever you need them.
back in the days of HTR (some may know what i mean) i was in the office with Joe when a guy bought a set back which had caught fire in his car, luckily he had caught it straight away. that was in the early days of ccfl's and is the only time I'v ever heard of it in th uk.
I had ccfl's in my e36 for three years with no problems atall...
I have had Angel Eyes in my car for 12months now, my invertors are in my headlight literaly, I have no wires at all on show, mine are fine.
I have had to have new invertor packs in both headlights but thats it.
Go & fit em, you'll luv em.
Colin. :(
