Ian.H
Convertible Coilover Fitting
Hi all..
Although the car's now gone.. I took some pics a few weeks ago whilst I was fitting the JOM coilover kit to my 330 vert as the info I managed to find previously on the 'net seemed to relate to coupes etc, which after removing some of the boot trim and finding nothing, decided it was a different story for the verts.. so here's a quick set of pics that others hopefully, might find useful.
Rear suspension
Locate rear jacking points and jack up car and remove wheel
Undo and remove bottom shock bolt
Lean on the hub / disc and pull the spring out form its locators
Semi-lower the roof, using the back edge of the roof to support the roof cover
Remove the plastic grommets (2 each side)
Remove the 2 nuts whilst steading the shock and remove completely
Remove the top mount nut if you're not fitting new top mounts as they need to be transferred to the new shocks
Fit the adjuster and rubber ends to the new spring
Note: adjuster sits at the top of the spring
Wriggle the new spring back into position and bolt up the new shock starting at the top. A 2nd jack is handy to be able to lift the hub to align the bottom bolt.
Front suspension
Locate jacking point, jack up car and remove wheel. Would also suggest soaking the bolts and joint where the shock goes through the hub clamp with WD40 and leave for 5 mins to act
Undo and remove hub clamp bolt
Undo top drop link nut
Undo bottom drop link nut and remove drop link
Give the hub some downwards pressure and it should separate from the shock
Remove the 3 top mount nuts. Steady the shock whilst removing the last one so it doesn't juts drop out
Remove the shock and attach the spring compressors, assuming you're not replacing the top mount as this needs to be transferred to the new suspension
Be careful at this stage.. as removing a spring can be dangerous.. just take your time and all should be good
Once the spring is compressed enough, undo to the top mount nut
Attach the top mount to the new suspension leg and tighten the top mount nut ready to re-fit
Bolt the top 3 nuts up under the bonnet first, but don't tighten them right up.. and mount the bottom of the shocik back into the hub clamp
Attach the new, shortened drop links (I used 2004 Fiat Coupe rear drop links)
Make sure everything's tightened up, replace wheel. Allow to settle for a couple of days / weeks. I had mine on the lowest setting and within 2 days, my fronts were rubbing the arches slightly when cornering under load. I adjusted these ~1" of adjustment on the threads at the front and this cured the problem running standard 225/40 18 tyres and 15mm spacers.Final result20121202-DSC_4834.jpg
Cheers..
Ian
Edited by Ian.H
11 hours ago, Beemermarc said:
So adjusters go at the bottom he claims they go at top which cant be as you cant get to them to adjust them
I definitely fitted mine at the top back when I had the motor (I _think_ I tried at the bottom and failed, hence I added the note to fit them at the top).
You should be able to access the adjusters once the car's jacked up. I had to raise mine to the highest setting when I part-ex'd it and don't remember having any issues.
Cheers..
Ian
PS: I've fixed the image loading now so you should be able to see them again
2 hours ago, Beemermarc said:
Wicked thanks ian did you fit the rubber bump thing back on or leave off
I put them back in Marc.. the plan was to have it back to how it should be (I fitted the coilovers after I found a broken rear spring and decided I'd drop it a couple of inches at the same time).
I only had it for a couple of weeks after I did this as I part-ex'd it, but it drove great (once I raised the front a bit to prevent arch rubbing!).
Despite loving my current motor, I do miss my E46 and still think they're the best looking verts of the 3-series range.. definitely aged gracefully! :)
Cheers..
Ian
Thanks mate i redone the rears this afternoon exactly as you done yours did you have spacers on rear i had to remove my 12mm spacers as when kids was in back the tyres were rubbing well bad
and im thinking of doing fronts myself the only thing i worried about is undoing the top mount nut as the centre spins i believe
mark
Glad you got it sorted mate :)
I had 15mm spacers on the front and I think lesser ones on the rear (maybe 5mm or 6mm  IIRC.. been a long time since I had it so can't remember exactly). Kids was sadly the reason I got rid of mine as my littlen was due and I couldn't fit a car seat in the back.. but IIRC, I chose smaller spacers for the rear to prevent any rubbing or arch mods being required.
The fronts are easy enough.. you should find an allen key hole at the top of the shaft. I used a deep-reach 19mm (think it was 19mm anyway) ring spanner and an allen key to undo mine. If you struggle with that, you can always use a pair of molegrips or a monkey-wrench to hold the shaft as it won't matter if it gets damaged (assuming you ain't going to try and sell the old shocks :) ). IIRC, the coilovers either had an allen key hole or a rounded rectangular stub that you can use something like an 8mm or 10mm open-ended spanner on to keep the shaft from spinning.
Safety note: If you do do the fronts, just take your time and compress /uncompress the springs gently as you certainly don't want one flying off or having the compressors spinning around to one side of the spring.. I've seen a spring take off before in a workshop and it makes a right mess of brickwork! Likewise, always work with the top cap facing away from you (I normally sit cross-legged on the floor and put the bottom of the shock in my lap and have the top cap at ~45 degrees away from me so that _if_ something goes Pete Tong, there's a bigger chance it won't take your teeth with it ;) ).
Cheers..
  Ian
Edited by Ian.H
There was always quite a staggered difference between the spacing front and rear. I think with the 15/5 combo, it kind of just evened the look out (the fronts were miles too far in IMO).
No probs at all mate... glad the guide was useful.. just wish I'd noticed the images were screwed up before now (I moved my server recently and blocked off access to some parts due to abuse and didn't realise I'd blocked access to these pics too).
Good luck with it mate :thumbsup:
Cheers..
Ian
On 02/04/2019 at 07:27, Beemermarc said:
Can you remember if you used longer wheel nut bolts on back for your spacers ian as iv tried 5mm with standard nuts the do up ok but some rekon you should use longer ones
mark
Don’t even dare to try and use standard bolts, even with a 5mm spacer. It’s very bad practice. Just get longer bolts.
