TriggerFish Posted June 3, 2013 Report Share Posted June 3, 2013 (edited) Solved in Post 7 Hi all, Not too sure how well I'll get on with this here, but I know some of you get NCS well. Anyway, I'm trying to get the BFD to work on my facelifted saloon as per this thread: http://translate.google.com/translate?sl=auto&tl=en&js=n&prev=_t&hl=en&ie=UTF-8&eotf=1&u=http%3A%2F%2Fe46.bmwklub.cz%2Fviewtopic.php%3Ff%3D17%26t%3D20401%26start%3D0%26st%3D0%26sk%3Dt%26sd%3Da&act=url I've got an LSZ version of C32 and KBM of C07 both of which are high enough. The dash/KBM is coded properly according to the thread. The LSZ I think should be OK, but it doesn't seem to be working. Full trace attached below to prevent unneeded scrolling I'm not too sure what's wrong. The main BFD bits I've found and altered are: PIN38_20_BFD aktiv PIN49_37_BFD aktiv BFD_MINDEST_GESCHW wert_02 BFD_STUFE_2_VERZOEG wert_02 BFD_STUFE_2_MAX_EIN wert_02 BFD3_ASC_TIMER wert_02 BFD3_ASC_AKTIV nicht_aktiv BFD_BLINK_EINZEIT wert_02 BFD_BLINK_AUSZEIT wert_02 PIN5_10_BFD aktiv BFD_ON aktiv BFD_ST3_ON aktiv (Not sure what's up with the code spacing there though!) If any one's got any help I'd be happy to give it a go. Thanks! Joe Edited June 5, 2013 by TriggerFish Link to comment Share on other sites More sharing options...
TriggerFish Posted June 3, 2013 Author Report Share Posted June 3, 2013 (edited) Oh crap, just realised I checked that the options exist in the dash, not if they were turned on or not! It could be I've just forgotten a stage. If so, this can be deleted! Yeah, OK, I've forgotten to change those things and they're all set to not-active. My dad (tester) is watching TV now and I doubt the neighbours will appreciate me doing more emergency stops at this time of night. I'll make those changes tomorrow and Edited June 3, 2013 by TriggerFish Blair 1 Link to comment Share on other sites More sharing options...
JasonK Posted June 4, 2013 Report Share Posted June 4, 2013 Interested to see if you get this working.....keep us updated! Sent from my Windows Phone 8X by HTC using Board Express - excuse the typos! Link to comment Share on other sites More sharing options...
TriggerFish Posted June 4, 2013 Author Report Share Posted June 4, 2013 Will do. I've got some running around to do later, but will have a go this evening and update Link to comment Share on other sites More sharing options...
bungers Posted June 4, 2013 Report Share Posted June 4, 2013 I thought BFD was only on the LED rears ie facelift coupés & convertibles? On these it lights up the outer 'brackets' of LEDs, interested to know how it works on cars with bulbs? Link to comment Share on other sites More sharing options...
TriggerFish Posted June 4, 2013 Author Report Share Posted June 4, 2013 (edited) Nope, I thought so too at first. The bulbs are dual filament so they can run at either 'side light' mode or brighter for use as fogs/brake lights. As there's 4 bulbs per side on mine facelift you can have one or two acting as normal brake lights and then call in the other three or four under hard braking. In ABS situations they then start to flash. There's a link to a video in the last line of the first post, not too sure why it didn't embed though. Before messing around with this I had the fog lights acting as brake lights too as they're the same brightness as the normal brake lights as they both use the same dual filament 4/21w bulbs. The video above shows it working on a pre-FL touring too, so I guess it must be possible on them all. That said, this diagram suggests that it may not be possible on the pre-FL saloon due to a lack of two sets of 21w bulbs. http://e46.bmwklub.cz/download/file.php?id=39021&sid=a10e25c329f8b0e5c2fa9c0e0a1dd8a6&mode=view Edited June 4, 2013 by TriggerFish Link to comment Share on other sites More sharing options...
TriggerFish Posted June 4, 2013 Author Report Share Posted June 4, 2013 (edited) Right, an update on this - it now works (almost)! In normal operation the top 2 brake lights come on. Under hard braking, the 'lower bar' (my dad's words) come on too. I think I coded it to be all three of the lower lights, but I'm not sure yet. The stumbling block is the flashing mode. I guess it could be that my car doesn't support this, or I've coded it wrong, or the ABS/trigger inputs aren't working. On braking hard from 40-50 on a dusty road it feels as though the ABS is working, but the lights don't flash. The tyres give off smoke too (which they'll do from 20 in an e. stop). I'm not sure if that's due to the ABS not working, or the ABS leaving the brakes on a long enough for them to get hot. It doesn't sound or feel like they're locking up, so I assume it's the latter. Anyway, what needs coding? Most of this comes from the Czech thread linked above, but hopefully my English is better than Google Translate's, although that's debatable! Apparently you need at least KBM versions of c07 or higher, and LCM of C32 or higher. The exact options might be different for each of the different versions might vary though, but the principles should carry. KBM I've set all of these too active. From what I can gather, these allow the dash to send the braking rates to the LCM so that it can work out if BFD is needed or not. FZG_VERZOEGERUNG activ GRENZWERT_GRUND_SCHWELLE activ GRENZWERT_VERZ_SCHWELLE_1 activ GRENZWERT_VERZ_SCHWELLE_2 activ That's it for the dash module. Without these, it doesn't work (as I found out). LCM This is where things might differ from different versions/body types. I've attached my trace files so you can see the full break down, but in short: BFD_ST3_ON aktiv BFD_ON aktiv These are quite easy to guess. BFD_ON is self explanatory. BFD_ST3_ON is, I think, the flashing feature when the '3rd stage' of BFD kicks in. (1 = normal braking, 2 = hard braking, 3 = ABS/'panic' braking) PIN5_10_BFD aktiv PIN29_30_BFD nicht_aktiv PIN49_37_BFD aktiv PIN38_20_BFD aktiv These are different for each of the body types and relate to the pin outs of each of the light clusters. This is for a facelifted saloon. In short, each entry determines in the BFD is active on that pin out. On mine, I've set it so all three lower lights come on with BFD and the normal brake lights (not sure why I turned this on, they're on by default when braking!). See here for the different pin outs: http://e46.bmwklub.cz/download/file.php?id=39021&sid=a10e25c329f8b0e5c2fa9c0e0a1dd8a6&mode=view BFD_BLINK_EINZEIT wert_02 BFD_BLINK_AUSZEIT wert_02 BFD3_ASC_AKTIV nicht_aktiv This I don't claim to understand, but is taken from the original thread. I'm wondering if the BFD3_ASC_AKTIV is why my ABS/flashing mode doesn't work as it's set to off. I'll change this and update accordingly. BFD_MINDEST_GESCHW wert_02 BFD_STUFE_2_VERZOEG wert_02 BFD_STUFE_2_MAX_EIN wert_02 BFD3_ASC_TIMER wert_02 Again, these I don't get. If anyone knows, please feel free to let me know and I'll update. Hopefully this helps someone, but if not I've learned something doing it anyway! Joe dash after bfd.txtlight with bfd.txt Edited June 4, 2013 by TriggerFish Link to comment Share on other sites More sharing options...
TriggerFish Posted June 5, 2013 Author Report Share Posted June 5, 2013 (edited) Right, I'm sure by now that no-one cares, but hey ho! I've got it working properly now. As suspected, changing BFD3_ASC_AKTIVnicht_aktiv to aktiv fixed the problem. As you can see in the video, in normal braking the top and fog lights come on. When braking harder all the lights come on and the top 3rd brake light flashes too. Job jobbed! Edited June 5, 2013 by TriggerFish CharlE46 1 Link to comment Share on other sites More sharing options...
Phillloyd Posted June 5, 2013 Report Share Posted June 5, 2013 Link doesn't work kid Link to comment Share on other sites More sharing options...
TriggerFish Posted June 5, 2013 Author Report Share Posted June 5, 2013 To the video? It's set to private while I trim all the crap of me running around out. Should be there in a couple of minutes once YouTube is done. Link to comment Share on other sites More sharing options...
TriggerFish Posted June 5, 2013 Author Report Share Posted June 5, 2013 Should be live now, didn't expect YouTube to take so long to trim it down! Woulda been faster to just use Premier Pro, won't make that mistake again! Link to comment Share on other sites More sharing options...
bungers Posted June 5, 2013 Report Share Posted June 5, 2013 Nice work Trigger! I'm going to check my LCM now & see if I can get the LEDs to flash on mine as well as the outer ring illumination. TriggerFish 1 Link to comment Share on other sites More sharing options...
TriggerFish Posted June 5, 2013 Author Report Share Posted June 5, 2013 I've seen videos of it done with LEDs, so you should be alright. If you need a hand I'm happy to help, although you're better at NCS than me I think! Link to comment Share on other sites More sharing options...
bungers Posted June 5, 2013 Report Share Posted June 5, 2013 Just watched TerraPhantm's vid with the LED BFD stage 3, i'm going to turn that on plus the indicators if possible. My Alfa's indicators flash under the same conditions and I've had a quick look through my LSZ trace and there seems to be a few options available so I'll have a play! Thanks for putting this thread up. Link to comment Share on other sites More sharing options...
TriggerFish Posted June 5, 2013 Author Report Share Posted June 5, 2013 It was his video I saw too. His M3 shift light is pretty cool as well. I'd rather mine did indicators than brake lights, but the pin out option wasn't there - don't think it is on the newer models either (There's a link in the thread to a pin out diagram of the rear clusters if you've not seen it already - it should be pretty useful.) No worries - something I've wanted for a while but didn't know it was possible. Seems pointless not to share information if it'll help someone else! Link to comment Share on other sites More sharing options...
bungers Posted June 5, 2013 Report Share Posted June 5, 2013 Sure, I've saved the GIF from the link so I can do some playing when I'm next in the beemer. Link to comment Share on other sites More sharing options...
Quiksilver_TR Posted June 6, 2013 Report Share Posted June 6, 2013 Nice work Trigger! I'm going to check my LCM now & see if I can get the LEDs to flash on mine as well as the outer ring illumination. Just watched TerraPhantm's vid with the LED BFD stage 3, i'm going to turn that on plus the indicators if possible. My Alfa's indicators flash under the same conditions and I've had a quick look through my LSZ trace and there seems to be a few options available so I'll have a play! Thanks for putting this thread up. This would be a nice to have on mine too, if you get it working please let me know what to change so I can sort it when I get the car back from the bodyshop. If it will work on a pre-facelift with LED rears fitted?? Link to comment Share on other sites More sharing options...
bungers Posted June 6, 2013 Report Share Posted June 6, 2013 Will do, are they genuine facelift rears & did you upgrade your LSZ (LCM)? If its yes & yes you should be but if not it'll be more difficult. It won't be for a couple of weeks but I'll let you know. Link to comment Share on other sites More sharing options...
Quiksilver_TR Posted June 6, 2013 Report Share Posted June 6, 2013 Will do, are they genuine facelift rears & did you upgrade your LSZ (LCM)? If its yes & yes you should be but if not it'll be more difficult. It won't be for a couple of weeks but I'll let you know. Thanks. I didnt fit them as they were on the car when I bought it so I am not 100% sure if the LSZ has been upgraded. The previous owner had everything done at BMW as far as I can tell though, so Id hope so. Is there anything the NCS file that I have got a copy of on my computer that would tell me if it has been updated?? Link to comment Share on other sites More sharing options...
TriggerFish Posted June 6, 2013 Author Report Share Posted June 6, 2013 I don't have LEDs (obviously!), but I'd expect there to be an option to select them as later ones could be coded to have LEDs or not. If you post up a trace I'm happy to have a look through, see if I can find anything. Link to comment Share on other sites More sharing options...
bungers Posted June 6, 2013 Report Share Posted June 6, 2013 As above, get a trace up & state the version that NCS detects it as, C35 etc. Link to comment Share on other sites More sharing options...
Quiksilver_TR Posted June 10, 2013 Report Share Posted June 10, 2013 Cheers Guys. This is the .TRC file that I have of mine: (Sorry about the paste of the file, cant work out how to attach the file) The part I dont have is probably the part you are after which looks like this> Generated with NCS Dummy version 0.5.0.5 — copyright © 2011 revtor software Output : Module Functions Chassis : E46 Module : LSZ.C35 FUNCTION KEYWORD FUNCTION KEYWORD TRANSLATION PARAMETER KEYWORD PARAMETER KEYWORD TRANSLATION ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯ Here is the latest I have from the car when I did the dimmed blinkers> GURTSTRAFFER_FAHRER_1 aktiv GURTSTRAFFER_BEIFAHRER_1 aktiv KOPFBAG_FOND_LINKS_1 nicht_aktiv KOPFBAG_FOND_RECHTS_1 nicht_aktiv KOPFBAG_FOND_LINKS_2 nicht_aktiv KOPFBAG_FOND_RECHTS_2 nicht_aktiv GURTSCHLOSS_SPANNUNGSS_1 nicht_aktiv GURTSCHLOSS_SPANNUNGSS_2 nicht_aktiv FOND_MODUL_1 nicht_aktiv FOND_MODUL_2 nicht_aktiv SBE2_1 nicht_aktiv SBE2_2 nicht_aktiv HWL_1 nicht_aktiv HWL_2 nicht_aktiv MRS1_EMULATION_1 mrs3_modus MRS1_EMULATION_2 mrs3_modus TRIGGERSCHALTER_1 aktiv TRIGGERSCHALTER_2 aktiv ERKENNUNG_SITZBELEGUNG_1 aktiv SBE_ALT/NEU_1 alt KINDER_SBE_1 nicht_aktiv ERKENNUNG_SITZBELEGUNG_2 aktiv SBE_ALT/NEU_2 alt KINDER_SBE_2 nicht_aktiv GURTSTRAFFER_FAHRER_2 aktiv GURTSTRAFFER_BEIFAHRER_2 aktiv ZAE2_EMULATION_1 mrs_modus ZAE2_EMULATION_2 mrs_modus BAUREIHE e46 NICHT_BELEGT wert_01 BPLUS_TRENNUNG_1 aktiv BPLUS_TRENNUNG_2 aktiv BPLUS_TRENNUNG2_1 nicht_aktiv BPLUS_TRENNUNG2_2 nicht_aktiv GURTSTRAFFER_HINTEN_LI_1 nicht_aktiv GURTSTRAFFER_HINTEN_RE_1 nicht_aktiv GURTSTRAFFER_HINTEN_MI_1 nicht_aktiv GURTSTRAFFER_HINTEN_LI_2 nicht_aktiv GURTSTRAFFER_HINTEN_RE_2 nicht_aktiv GURTSTRAFFER_HINTEN_MI_2 nicht_aktiv GURTSCHLOSS_HINTEN_LI_1 nicht_aktiv GURTSCHLOSS_HINTEN_RE_1 nicht_aktiv GURTSCHLOSS_HI_MITTE_1 nicht_aktiv GURTSCHLOSS_HINTEN_LI_2 nicht_aktiv GURTSCHLOSS_HINTEN_RE_2 nicht_aktiv GURTSCHLOSS_HI_MITTE_2 nicht_aktiv SBE1_STATUS_VERZ_1 nicht_aktiv ITS_FRONTCRASH_1 nicht_aktiv SBE1_STATUS_VERZ_2 nicht_aktiv ITS_FRONTCRASH_2 nicht_aktiv BREMSLICHTSCHALTER aktiv REIFENTOL_ABGLEICH_ASC aktiv REIFENTOLERANZABGLEICH aktiv CORNERING_BREAK_CONTROL aktiv PRE_CBC_FUNKTION aktiv BREMSWARNLEUCHTE aktiv ADRESSE_AUSWERTEN nicht_aktiv PRE_VLABS aktiv EBV_LAMPE aktiv GEARMOMENTREGLER_MAX_HA wert_02 GEARMOMENTREGLER_MIN_HA wert_02 VOLUMENDURCHFLUSSPARA wert_02 LENKWINKELKENNLINIE wert_01 PRE_MSR nicht_aktiv DBC_DBS aktiv DBC_MSB aktiv CODIERWERT wert_01 HBA_DSC_5_7 wert_03 BORDNETZ e38/e39_high FERNWIRKEN_GENERELL nicht_aktiv FERNWIRKEN_POSITION nicht_aktiv FERNWIRKEN_NAVZIELE nicht_aktiv FERNWIRKEN_STANDHEIZUNG nicht_aktiv FERNWIRKEN_TELEFONLISTEN nicht_aktiv WAKEUP_GENERELL nicht_aktiv WAKEUP_ZEIT wert_01 WAKEUP_TAGE wert_01 FAHRZEUG_MMI bmw NACHLAUF_ZEIT_H wert_01 NACHLAUF_ZEIT_MIN wert_01 GAL_ANZAHL_STUFEN wert_01 GAL_KMH_STUFUNG wert_01 GAL_KMH_HYSTERESE wert_01 DSP_ACOUSTIC_PROFILE dsp_profil_1 GAL_STEPS steps_default GAL_KM/H_PER_STEP kmh_per_step_default GAL_HYSTERISIS hysteresis_default WAKEUP_BY_B-CALL no_wakeup DELAY_PWR_DOWN_INIT_DUR wert_01 BACKUP_ANTENNA nicht_aktiv BACKUP_BATTERY nicht_aktiv BACKUP_BATTERY_ENABLED nicht_aktiv SIM_IN_TELEMATIK_READER nicht_aktiv TIMER_SMS_NACK wert_01 E_CALL_COUNTD_DEL_TMR wert_01 NAD_EQUIPPED nad_equipped RAM_CHECK aktiv ROM_CHECK aktiv SOFTWARE_VERDECK e46 VERDECKKLAPPE_VORHANDEN aktiv ZKE aktiv DEBUG_SIGNAL nicht_aktiv HALLSENSOR_VSW8 nicht_aktiv VKBODEN_ERKENNUNG aktiv KOMFORTOEFFNUNG_VERDECK aktiv WARTEN_SCHEIBEN_ABGESENK aktiv KBUS_FUNKTION aktiv KOMFORTSCHLIESSEN_VERDECK aktiv HALLSENSOR_VSW72 aktiv HYSTERESE_KL_30 wert_04 ABSCHALTSPANNUNG_KL_30 wert_11 SPANNUNG_KL_R wert_06 HYSTERESE_KL_R wert_04 HALL_BETRIEBSSPANNUNG wert_02 HALL_GRENZWERTE wert_01 WINDLAUF_DREHRICHTUNG vmw1 DRUCKPUMPE_DREHRICHTUNG links LED_ANSCHLUSS vled1 LOGIK_SWBUNT nicht_aktiv LOGIK_VERDECK_SCHLIESSEN nicht_aktiv LOGIK_VERDECK_OEFFNEN nicht_aktiv LOGIK_RESERVE3 nicht_aktiv LOGIK_SCHALTER_RESERV nicht_aktiv LOGIK_VSW12 nicht_aktiv LOGIK_VSW41 nicht_aktiv LOGIK_VSW42 nicht_aktiv LOGIK_VSW71 nicht_aktiv LOGIK_VSW72 nicht_aktiv LOGIK_VSW8 nicht_aktiv LOGIK_VSW9 nicht_aktiv LOGIK_VSWHTOP nicht_aktiv UNTERGRENZE_POTI wert_01 OBERGRENZE_POTI wert_01 SEGMENTGRENZEN_HS wert_01 VERDECKINFO_SEGMENTGRENZE wert_01 DELTA_SEGMENTBREITE wert_01 SEGMENTBREITE_MINDEST wert_01 VERDECKLAUF_ZAEHLER wert_01 FEHLER_V2HAUPT aktiv FEHLER_V3SBE aktiv FEHLER_V4SBA aktiv FEHLER_MOTOR aktiv HALTEZEIT_VENTILE wert_01 POWERDOWN_ZEIT wert_01 TO_MULT_ANH_VDK_1 wert_02 TO_MULT_ANH_VDK_2 wert_02 TO_MULT_ANH_VDK_3 wert_02 TO_MULT_WLM wert_02 TO_MULT_ANH_SB wert_02 TO_MULT_ABL_HS wert_02 TO_MULT_ANH_HS wert_02 TO_ZEIT_ANH_VDK wert_02 TO_ZEIT_WLM wert_02 TO_ZEIT_ANH_SB wert_02 TO_ZEIT_ABL_HS wert_02 TO_ZEIT_ANH_HS wert_02 CHECK_BLOCK_3 wert_01 BEDIEN_ENTPRELLZAEHLER wert_02 BEDIEN_ENTPRELLZEIT wert_02 VKBODEN_ENTPRELLZAEHLER wert_02 VKBODEN_ENTPRELLZEIT wert_02 MICRO_ENTPRELLZAEHLER wert_02 MICRO_ENTPRELLZEIT wert_02 TEMP_DRUCKPUMPE wert_01 AUSSENTEMP_VERDECKLAUF wert_01 GESCHW_VERDECK_AKTIV wert_01 SPERR_VENT_TEST aktiv SPERR_WLM_TEST aktiv GESCHW_PRUEFUNG aktiv SB_ANHEBEN nicht_aktiv FEHLER_ABTAKTEN nicht_aktiv PREALARM_DRUCKPUMPE wert_01 PATCH_ENABLE_1 wert_01 PATCH_ENABLE_2 wert_01 KLA_VERR_BIS_PAUSE wert_01 KLA_VERR_PAUSE wert_01 VENTIL_HALTESTELLUNG wert_01 BYTE_3_LI wert_01 BYTE_4_LI wert_01 FEHLER_HECKSCHEIBE nicht_aktiv K_BUS_FREI_OHNE nicht_aktiv ZEIT_BIS_AUTOM_SPERREN wert_01 EWS_3_SCHNITTSTELLE aktiv FEHLVERSUCH_ZAEHLER 0_unberechtigte_zugriffe MAIN_SWITCH multifunktionslenkrad WISCHERPOTI aktiv ANLAUFSTROMBEGRENZ_MEMO aktiv SCHEIBENABSENK_OHNE_EKS aktiv FH_NACH_TUERE_AUF nicht_aktiv E52_FUNKTIONEN nicht_aktiv FENSTERHEBER_VORNE aktiv DIFFERENZ_ANLAUF_BLOCK wert_01 FH_FAHRERTUER_TIPP_AUF aktiv FH_BEIFAHRERTUER_TIPP_AUF aktiv FH_TUEREN_HINTEN_TIPP_AUF aktiv FH_ZTR_SCHALTER_TIPP_AUF aktiv FH_ZTR_SCHALTER_TIPP_ZU nicht_aktiv SCHEIBE_ABSENKZEIT wert_01 ZEIT_TUER/SCHLIESSZEIT wert_01 VERRIEGELN_AUT_AB_X_KM/H nicht_aktiv VERRIEGELN_AUT_NACH_2_MIN nicht_aktiv SOFT_ON/OFF aktiv IB_EIN_SCHLOSS_ENTRIEGELN aktiv IB_BEI_KL.R_AUS aktiv_mit_kl.58 ABSCHALTUNG_VERBRAUCHER aktiv HECKKLAPPEN_LOGIK geschlossen KOMFORTSCHLIE_FB_OHNE_SHD nicht_aktiv EINGANG_2 nicht_aktiv EINGANG_2_KONTAKT_GESCHL nicht_aktiv QUIT_AKUST_SCHAERF nicht_aktiv INNENLICHT_AN_MEHRFACH_ZV aktiv VERZUG_PANIK_MODUS_0.2_S wert_01 VERRIEGELN_XKM/H_SENDER_1 nicht_aktiv HKL_SPERREN_BEI_ZS nicht_aktiv VERRIEGELN_XKM/H_SENDER_2 nicht_aktiv VERRIEGELN_XKM/H_SENDER_3 nicht_aktiv VERRIEGELN_XKM/H_SENDER_4 nicht_aktiv WISCHER_RUECK_GESCHW wert_01 EKS_OFFEN/UNTERBRECHUNG wert_01 EKS_GEDRUECKT/OFFEN wert_01 CODIERUNG_ERFOLGT_1 codierung_erfolgt VERRIEGELUNGSSCHWELLE 16_km/h KOMFORTOEFFNEN_FB_O_FH_HI nicht_aktiv EINSTIEGSHILFE nicht_aktiv EINSTIEGSHILFE_SENDER_1 nicht_aktiv EINSTIEGSHILFE_SENDER_2 nicht_aktiv EINSTIEGSHILFE_SENDER_3 nicht_aktiv EINSTIEGSHILFE_SENDER_4 nicht_aktiv KOMFORTOEFFNEN_FB_O_SHD nicht_aktiv IB_SPERRE_BEI_FEHLER aktiv OHNE_INTERVALLBETRIEB nicht_aktiv INTERVALLZEIT_GESCHWABH aktiv KENNLINIENFELD2_AKTIV nicht_aktiv BLOCKIERSCHUTZ_AKT_XXS 16s MIT_WISCHER_SERVICEPOS nicht_aktiv WISCHER_VOLLEND_KLR_AUS nicht_aktiv SENSOR_REGEN_N_STUFE2 nicht_aktiv WISCHEN_ERST_XXS_WASCH 300ms OHNE_WISCH_BEI_WASCH nicht_aktiv ANZAHL_NACHWISCHZYKLEN 3 ANZAHL_WASCHBET_ZUR_SRA 5 MIT_SRA_EIN_LENKSTOCK nicht_aktiv SRA_MIT_WASCH_WISCH_SW nicht_aktiv ANZAHL_SPRITZIMPULSE 2 DAUER_SPRITZIMPULSE 700ms PAUSE_ZW_SPRITZIMPULSE 1300ms MAUT_N_ABBRECH_N_TUER_AUF nicht_aktiv EKS_REVERSIERZEIT_ZUS 1000ms FH_TIMEOUT 8s KISI_N_DEAKT_IM_CRASH nicht_aktiv AUSSTELLFENSTER_ZEIT plus_0s EINSTIEG_FH_ZU_VER_SPERRE aktiv CENT_LOCK_MGL_VO_TUER_AUF nicht_aktiv HECKSCHEIBEN_LOGIK geschlossen N_VER_B_ERN_GESCHW_SCHWEL nicht_aktiv ANSTEUERZEIT_ZV_AGGREGATE plus_0s ENTR_HKL_MGL_WENN_VER nicht_aktiv ENTR_HS_MGL_WENN_VER nicht_aktiv SCHLIESSYSTEM d_schloss ENTRIEGELN_HKL 1x_tastendruck POLLING_ZEIT_L_SCHLOSS 10ms BETAET_DAUER_WIPPTASTE kurz NOTENTRIEGELN_HKL aktiv ANSTEUERZEIT_MOTOR_HKL wert_01 ANSTEUERZEIT_MOTOR_HS wert_01 IB_EIN_BEI_HKK/HSK nicht_aktiv IB_EIN_16MIN_WENN_STANDLI nicht_aktiv IB_AUS_NACH_X_SEKUNDEN 20s IB_EIN_N_KL_58G_MAX_1MIN nicht_aktiv VA1/VA2_AUS_NACH_X_MIN 16_min VA1_SPERRE_BEI_FEHLER nicht_aktiv VA2_SPERRE_BEI_FEHLER nicht_aktiv VERL_ALARMZEI_WAEHR_ALARM nicht_aktiv HEULTON nicht_aktiv OFFENE_FENSTER nicht_aktiv VERZUG_ENTR_HECKKLAPPE nicht_aktiv E85_FUNKTIONEN nicht_aktiv E83_FUNKTIONEN nicht_aktiv OHNE_FERTIGUNGSMODE nicht_aktiv OHNE_TRANSPORTMODE nicht_aktiv OHNE_SERVICEMODE nicht_aktiv OHNE_POWERDOWNMODE nicht_aktiv BETRMODI_DEAKT_KL15_EIN nicht_aktiv OHNE_IB_0 nicht_aktiv OHNE_FERNBEDIENUNG_1 nicht_aktiv OHNE_CENTERLOCK_0 nicht_aktiv OHNE_VA_ZEITEN_0 nicht_aktiv OHNE_IB_1 nicht_aktiv OHNE_FH_FA_HINTEN_0 aktiv OHNE_FH_BF_VORNE_0 aktiv OHNE_FH_BF_HINTEN_0 aktiv OHNE_SRA_0 aktiv OHNE_DWA_0 nicht_aktiv OHNE_FERNBEDIENUNG_2 nicht_aktiv OHNE_CENTERLOCK_1 nicht_aktiv OHNE_VA_ZEITEN_1 nicht_aktiv OHNE_IB_2 nicht_aktiv OHNE_FH_FA_VORNE nicht_aktiv OHNE_FH_FA_HINTEN_1 nicht_aktiv OHNE_FH_BF_VORNE_1 nicht_aktiv OHNE_FH_BF_HINTEN_1 nicht_aktiv OHNE_SRA_1 nicht_aktiv OHNE_FRONTSCH_REINIGUNG nicht_aktiv OHNE_SCHEIBENWISCHER nicht_aktiv OHNE_DWA_1 nicht_aktiv OHNE_ZV nicht_aktiv OHNE_ER_HECKKLAPPE nicht_aktiv OHNE_FERNBEDIENUNG_3 nicht_aktiv OHNE_CENTERLOCK_2 nicht_aktiv OHNE_VA_ZEITEN_2 nicht_aktiv SCHWELLE_OBEN wert_01 SCHWELLE_UNTEN wert_01 VERDECK_VORNE_E85 nicht_aktiv CODIERUNG_ERFOLGT_2 codierung_erfolgt MIT_LIN_SCHALTER nicht_aktiv MEMORY_POS_SPEICHERN wert_01 MEMORYANFAHRGENAUIGKEIT standard MEMORY_POS_ANFAHREN wert_01 ABKLAPPWERT_GM wert_01 MEMORY_SP_ABKLAPPEN_GM nicht_aktiv DELAY_MOTOR_ZV_ER wert_01 SPEED_MAPS wert_01 SPEED_ROUTE_MAPS wert_01 USER_INPUT wert_01 ANZEIGE_ANKUNFTSZEIT nicht_aktiv PHYSIOLOGIEANPASSUNG_1 nicht_aktiv PHYSIOLOGIEANPASSUNG_2 nicht_aktiv PHYSIOLOGIEANPASSUNG_3 nicht_aktiv PHYSIOLOGIEANPASSUNG_4 nicht_aktiv AUFHEIZAUTOMATIK nicht_aktiv DIMMUNG_FUNKTIONS_LEDS kennlinie MIN_WT_SOLLWERT nicht_aktiv HECKSCHEIBE_HEIZZEIT verlaengert UEBERLAUFSTEPS_BEI_100% nicht_aktiv TAKTUNG_HHS aktiv UEBERLAUFSCHRITTE_BEI_0 nicht_aktiv DISPLAY anzeige_32_grad AUTO_LED_GEBL_MANUELL nicht_aktiv AUTO_LED/SCHRIFTZUG nicht_aktiv FERTIGUNGSMODE wert_01 KENNFELDKUEHLUNG aktiv LATENTWAERMESPEICHER nicht_aktiv KLIMATASTE_SPERREN nicht_aktiv LDA_BEI_VERBRAUCHER nicht_aktiv LDA_BEI_UNTERSPANNUNG nicht_aktiv DISPLAYANZEIGE_HIGH nicht_aktiv DISPLAYANZEIGE_LOW nicht_aktiv KENNLINIE_WAERMETAUSCHER nicht_aktiv DISPLAY_GEBLAESRAHMEN nicht_aktiv AUSSENTEMP_ABH_GEBL_ANH_1 nicht_aktiv AUSSENTEMP_ABH_GEBL_ANH_2 nicht_aktiv AUSSENTEMP_ABH_GEBL_ANH_3 nicht_aktiv AUSSENTEMP_ABH_GEBL_ANH_4 nicht_aktiv LUFTVER_AUT_B_ZUEND_EIN_1 nicht_aktiv TAKTEN_HIGH_LOW_ANZEIGE_1 nicht_aktiv LUFTVER_AUT_B_ZUEND_EIN_2 nicht_aktiv TAKTEN_HIGH_LOW_ANZEIGE_2 nicht_aktiv LUFTVER_AUT_B_ZUEND_EIN_3 nicht_aktiv TAKTEN_HIGH_LOW_ANZEIGE_3 nicht_aktiv LUFTVER_AUT_B_ZUEND_EIN_4 nicht_aktiv TAKTEN_HIGH_LOW_ANZEIGE_4 nicht_aktiv GEBLAESEKORREKTUR_1 nicht_aktiv GEBLAESEBALKEN_AUT_MOD_1 aktiv GEBLAESERAHMEN_AUT_MOD_1 aktiv BELUEFTUNGSKLAPPE_OEFF_1 aktiv KLAPPEN_OEFFNEN_1 nicht_aktiv SOLLWERT_KORREKTUR_1 nicht_aktiv KLIMABETR_BEI_ZUEND_EIN_1 nicht_aktiv GEBL_AUT_B_ZUEND_EIN_1 nicht_aktiv GEBLAESEKORREKTUR_2 nicht_aktiv GEBLAESEBALKEN_AUT_MOD_2 aktiv GEBLAESERAHMEN_AUT_MOD_2 aktiv BELUEFTUNGSKLAPPE_OEFF_2 aktiv KLAPPEN_OEFFNEN_2 nicht_aktiv SOLLWERT_KORREKTUR_2 nicht_aktiv KLIMABETR_BEI_ZUEND_EIN_2 nicht_aktiv GEBL_AUT_B_ZUEND_EIN_2 nicht_aktiv GEBLAESEKORREKTUR_3 nicht_aktiv GEBLAESEBALKEN_AUT_MOD_3 aktiv GEBLAESERAHMEN_AUT_MOD_3 aktiv BELUEFTUNGSKLAPPE_OEFF_3 aktiv KLAPPEN_OEFFNEN_3 nicht_aktiv SOLLWERT_KORREKTUR_3 nicht_aktiv KLIMABETR_BEI_ZUEND_EIN_3 nicht_aktiv GEBL_AUT_B_ZUEND_EIN_3 nicht_aktiv GEBLAESEKORREKTUR_4 nicht_aktiv GEBLAESEBALKEN_AUT_MOD_4 aktiv GEBLAESERAHMEN_AUT_MOD_4 aktiv BELUEFTUNGSKLAPPE_OEFF_4 aktiv KLAPPEN_OEFFNEN_4 nicht_aktiv SOLLWERT_KORREKTUR_4 nicht_aktiv KLIMABETR_BEI_ZUEND_EIN_4 nicht_aktiv GEBL_AUT_B_ZUEND_EIN_4 nicht_aktiv TRANSPORTMODE wert_01 FEHLERZAEHLER grundcode_var FEHLER_1_CODE grundcode_var FEHLER_1_ART grundcode_var FEHLER_1_HAEUFIGKEIT grundcode_var FEHLER_2_CODE grundcode_var FEHLER_2_ART grundcode_var FEHLER_2_HAEUFIGKEIT grundcode_var FEHLER_3_CODE grundcode_var FEHLER_3_ART grundcode_var FEHLER_3_HAEUFIGKEIT grundcode_var FEHLER_4_CODE grundcode_var FEHLER_4_ART grundcode_var FEHLER_4_HAEUFIGKEIT grundcode_var FEHLER_5_CODE grundcode_var FEHLER_5_ART grundcode_var FEHLER_5_HAEUFIGKEIT grundcode_var PRUEFSTEMPEL grundcode_var KALIBRIERFAKTOR_VERBRAUCH wert_01 CODIERUNG_ERFOLGT codierung_erfolgt OFFSET_GESAMTWEGSTRECKE grundcode_var WARN_MEDIUM_GURT piezo WARN_MEDIUM_ZUENDSCHL piezo WARN_MEDIUM_LIMIT piezo CC_LAMPEN aktiv CC_TUEREN aktiv WARN_MEDIUM_TOG piezo WARN_MEDIUM_AUSSENTEMP piezo LICHTWARNUNG aktiv WARNUNG_MOTOR_OELSTAND aktiv MOTOR_OELSTAND_PREDRIVE nicht_aktiv WARN_MEDIUM_RDKS piezo AKUSTIK_PARKBREMSE aktiv WARN_MEDIUM_PARKBREMSE piezo ANZEIGE_EML nicht_aktiv KLEMME_50_UEBER_CAN nicht_aktiv ASC aktiv FUNKUHR nicht_aktiv SAMPLE_POINT wert_01 AKUSTIK_WARNUNG_T1 wert_01 AKUSTIK_WARNUNG_T2 wert_01 AKUSTIK_WARNUNG_T3 wert_01 KUEHLMITTELNIV_FILTERZEIT wert_01 ZEITINSPEKTIONS_ZAEHLER_0 ece ZEITINSPEKTIONS_ZAEHLER_1 ece ZEITINSPEKTIONS_ZAEHLER_2 ece A_TEMP_DELTA_OFFSET wert_01 A_TEMP_OFFSET_SCHWELLE wert_01 AUSSENTEMP_ANZ_FEHLER_1 wert_01 AUSSENTEMP_ANZ_FEHLER_2 wert_01 TANK_ADC_FEHLER_UG wert_01 TANK_ADC_FEHLER_OG wert_01 TANK_FILTER_NACHTANKERK 1.1_l/sec TANK_FILTER_KL15 7_schritte TANK_FILTER_FALLEND 1.9_l/min TANK_FILTER_STEIGEND 0.9_l/min TANK_VORHALT_REICHW wert_01 TANK_SCHWELLE_AUF/AB 6_l TANK_BERUHIGUNGSZEIT 10_sec TANK_MITTLUNGSZEIT 5_sec TANK_SICHERHEITSFAKTOR 1.3 KUEHLMITTELTEMP_ANZEIGEWI kennlinie_01 KUEHLMITTELTEMP_WERT kennlinie_02 AUSSENTEMP_SPERRZEIT_3 wert_01 AUSSENTEMP_SPERRZEIT_2 wert_01 MOTOR_ABKUEHLZEIT wert_01 AUSSENTEMP_DELTA_K1 wert_01 AUSSENTEMP_DELTA_K2 wert_01 AUSSENTEMP_ZEITKONST_Z1 wert_01 AUSSENTEMP_ZEITKONST_Z2 wert_01 AUSSENTEMP_ZEITKONST_Z3 wert_01 AUSSENTEMP_ZEITKONST_Z4 wert_01 KURZMITTELUNG_ANZAHL wert_01 KALTBEWERTUNG_ANZAHL wert_01 MITTELWERT_ANZAHL wert_01 WARMBEWERTUNG_ANZAHL wert_01 TEMP_SCHWELLE_WARMLAUF wert_01 TEMP_SCHWELLE_BETRIEB wert_01 SCHWELLE_STARTVERZOEGER wert_01 SCHWELLE_SIGNALAUSFALL wert_01 NIVEAU_1 wert_01 DELTA_NIVEAU wert_01 DELTA_ZEIT wert_01 GEBER_ZEIT_LOW wert_01 GAL_LOW wert_01 TANK_SCHWELLE_RESERVE 8_l SMT_RATE wert_01 TLETZ wert_01 ASC_PREDRIVE_UEBER_SG nicht_aktiv DELTA_LIMIT_GESETZ aktiv ZEIT_SITZLEHNENANZEIGE wert_01 DIAGNOSE_DELAY_ZEIT aktiv LITERGRENZ_SIA_RESET wert_01 TAGEGRENZE_SIA_RESET wert_01 SIA_RESET_KI_TASTE aktiv ANZEIGE_UHR_IM_DISPLAY aktiv WARN_MEDIUM_ASC piezo VERZ_RWGANG_WRN wert_01 AUSSENTEMP_CODIER_FAKTOR wert_01 AUSSENTEMP_CODIER_OFFSET wert_01 AUSSENTEMP_ZEITKONST_Z5 wert_01 AUSSENTEMP_ZEITKONST_Z6 wert_01 AUSSENTEMP_ABKUEHLZEIT wert_01 AUSSENTEMP_V_FILTERZEIT wert_01 AKUSTIK_WARNUNG_T1_SMG wert_01 AKUSTIK_WARNUNG_T2_SMG wert_01 SMG_S_ANZEIGE nicht_aktiv ATEMP_WARNUNG_KALTLAND nicht_aktiv KUEHLMITTEL_G_GRENZE wert_01 AKUSTIK_DSC_ASC nicht_aktiv BFD_ASC_REG nicht_aktiv BFD_AX_REF nicht_aktiv BFD_SCHWELLE wert_01 BFD_HYSTERESE wert_01 TACHO_SKALA_ENDWERT wert_01 TACHO_SKALA_ENDWERT_KOMPL wert_01 DREHZAHL_KENNLINIE kennlinie_03 KALTUEBERWACHUNG_RL aktiv KALTUEBERWACHUNG_KZL aktiv FEHLER_RUECKLICHT melden FEHLER_ABBLENDLICHT melden FEHLER_FERNLICHT melden FEHLER_SIDEMARKER melden FEHLER_BL_BLINKEN nicht_melden BL_DIMMEN aktiv BETR_STD_NICHT_LOESCHEN nicht_aktiv FEHLER_BREMSLICHT melden FEHLER_KENNZ_LICHT melden TELEGRAMM_ZEIT wert_01 FEHLER_ANHAENGER melden SCHALTER_BREMSL_SCHWELLW wert_01 SCHALTER_BREMSL_WARTEZEIT wert_01 ABSCHALTUNG_UNTERSPG wert_01 WARNBLINKER einfachimpuls KALTUEBERWACHUNG_BLK_VO aktiv KALTUEBERWACHUNG wert_01 FAHRZEUG_HERSTELLER wert_01 VERZOEG_SCHNELLE_KALTABFR wert_01 ENTPRELLZAHL_FEHLERERK wert_01 TASTVERH_KL_58G_MIN wert_01 ZUWACHS_TASTVERH_KL_58G wert_01 HEIMLEUCHTEN_AL aktiv HEIMLEUCHTEN_KZL aktiv HEIMLEUCHTEN_NSW aktiv HEIMLEUCHTEN_FL nicht_aktiv HEIMLEUCHTEN_BL nicht_aktiv ABFRAGEZEIT_AHM wert_01 MELDUNG_AENDERUNG_DIMMER wert_01 HEIMLEUCHTEN wert_02 EINZEIT_GED_BLK_V wert_01 MIN_AUSZEIT_SL wert_01 MAX_SPANNUNG_SL wert_01 ADU_UNTERGRENZE wert_01 ADU_OBERGRENZE wert_01 SCHWELLE_TAG/NACHT wert_01 ANZAHL_ABSOLUT wert_01 ANZAHL_LANGFRIST_MITTEL wert_01 DELTA_TELEGRAMM wert_01 REL_TOLERANZ_LANGSAME_REG wert_01 V_ABHAENGIG aktiv REL_TOLERANZ_SCHNELLE_REG wert_01 ABS_TOLERANZ_SCHNELLE_REG wert_01 WARTEZEIT_ZW_TEL_N_KL_R wert_01 WARTEZEIT_ZW_TEL_DIMMER wert_01 WARTEZEIT_ZW_TELEGRAMMEN wert_01 SLEEP_MODE wert_01 ABS_TOLERANZ_LANGSAME_REG wert_01 TESTBETRIEB nicht_aktiv BEWERTUNG_FEHLER_32 aktiv BEWERTUNG_FEHLER_31 aktiv BEWERTUNG_FEHLER_30 aktiv BEWERTUNG_FEHLER aktiv U_POTI_STELLUNG_0 wert_01 U_POTI_STELLUNG_1 wert_01 U_POTI_STELLUNG_2 wert_01 SCHRITTABSTAND_GRENZE wert_01 TEMPERATUR_GRENZE grad_-20 REFERENZL_SCHRITTANZAHL wert_01 REFERENZL_SCHRITTABSTAND wert_01 REFERENZL_MODE_TEIL2 wert_01 REFERENZL_MODE_TEIL1 wert_01 LWR_NEIGUNG_KONSTANTE wert_01 KENNLINIE_GESCHWINDIGKEIT wert_01 PERIODE_GED_BLK_V wert_01 KL58_HELLIGKEITSSTUFE_FLC wert_01 AUSWERT_PROP_ABWEICHUNG aktiv AUSWERT_GRADIENT aktiv EPSILON_DELTA_AV wert_01 EPSILON_DELTA_A wert_01 ANHEBUNG_175_KM/H wert_01 ABSENKUNG_10_KM/H wert_01 VMAX_BREMSEN wert_01 VMIN_BREMSEN wert_01 SCHW_GRAD_BESCHLEUNIGUNG wert_02 SCHW_GRAD_BREMSEN wert_02 SCHW_PROP_ABWEICHUNG wert_02 DIFFERENZ_MSP_DYN_STAT wert_01 DAUER_DYN_NACHFUEHRUNG wert_01 ABTASTRATE_DYN wert_01 MITTELUNGSINTERV_DYN wert_01 MIN_STEIGUNG_VZ_WECHSEL wert_01 MITTELUNGSINTERV_VZ_WECHS wert_01 MINDESTANZAHL_VZ_WECHSEL wert_01 HOEHENWEG wert_01 ABTASTRATE_TREND wert_01 MITTELUNGSINTERV_TREND wert_01 SCHW_TREND wert_01 ABWEICHUNG_TREND wert_01 GRADIENT_SCHLECHTWEG nicht_aktiv NACHLAUF_SCHLECHTWEG wert_01 SAETT_TIMER_SCHLECHTWEG aktiv SCHW_GRADIENT_SCHLECHTWEG wert_01 ABSTAND_KALTPULSE nicht_aktiv PWM_ANSTEUERUNG_BL_MITTE wert_01 PWM_ANSTEUERUNG_FERNLICHT wert_01 PWM_ANSTEUERUNG_ZUSTZBLK wert_01 PWM_ANSTEUERUNG_BIXENON wert_01 SPG_NACHREGELUNG_0 wert_01 SPG_NACHREGELUNG_2 wert_01 SPG_NACHREGELUNG_3 wert_01 SPG_NACHREGELUNG_4 wert_01 SPG_NACHREGELUNG_5 wert_01 KALTUEBERWACHUNG_BL_MI nicht_aktiv KALTUEBERWACHUNG_FL aktiv KALTUEBERWACHUNG_KZL_LI nicht_aktiv WARMUEBERWACHUNG_BL_MI nicht_aktiv WARMUEBERWACHUNG_BLK_VO aktiv WARMUEBERWACHUNG_FL aktiv WARMUEBERWACHUNG_AL aktiv WARMUEBERWACHUNG_KZL_LI nicht_aktiv WARMUEBERWACH_ZUSATZ_BLK nicht_aktiv CC_BREMSLICHT_MITTE nicht_aktiv CC_BLINKER_VORN aktiv CC_NSL_LINKS aktiv CC_FERNLICHT aktiv CC_KENNZEICHENLEUCHTE_LI nicht_aktiv CC_ABBLENDLICHT aktiv CC_ZUSATZBLINKER nicht_aktiv ANZAHL_QUICK_RUNDEN wert_01 ZEIT_KALT_RUNDEN wert_01 ZEIT_KALT_PULSE wert_01 ZEIT_KALT_PULSE_QUICK wert_01 ZYKLUS_KALT_RUNDEN_QUICK wert_01 DEF_PIN_20_DEFEKTBLINKEN nicht_aktiv DEF_PIN_37_DEFEKTBLINKEN nicht_aktiv PIN_38_RE_LI_MELDEN rechts_defekt PIN_38_VO_HI_MELDEN hinten_defekt ANHAENGERMODUL_PWM_WERT wert_01 PIN_29_30_AHM_ERS_FU_GESP aktiv PIN_5_10_AHM_ERS_FU_GESP aktiv SPG_NACHREGELUNG_LANGSAM nicht_aktiv KL58_HELLIGKEITSSTUFE wert_01 U_POTI_DIMMER_MIN wert_01 U_POTI_DIMMER_DELTA wert_01 POTI_DIMMER_INVERS aktiv POTI_LWR_INVERS nicht_aktiv LEUCHTDICHTE_EXPO aktiv TELEGRAMM_ZEIT_ZYKLUS nicht_aktiv PIN_20_ALS_FRA_LI_VO_2 nicht_aktiv PIN_37_ALS_FRA_RE_VO_2 nicht_aktiv DRL_BLK_VORN_GEDIMMT nicht_aktiv BLINKIMPULS_WARNBLK wert_02 BLINKIMPULS_CRASHBLK wert_02 DRL_BLK_VORNE_2_GEDIMMT nicht_aktiv CRASH_WARNBLINKEN aktiv CRASH_KLEMME_58G_EIN aktiv TAST_WBLKTASTER_MIN wert_01 TAST_WBLKTASTER_ZUWACHS wert_01 STEIG_KL58_T_PER_D wert_01 BIXENON_EIN_BEI_LICHTHUPE nicht_aktiv BFD_ON nicht_aktiv PHASE_AUS_GEDIM_LICHT_AUS aktiv PWM_WERT2_NSL_ZUSATZFKT wert_01 PWM_ANSTEUERUNG_BLK_VORN wert_01 SP_MOTOR_STOP nicht_aktiv PWM_ANSTEUERUNG_NSL_LI wert_01 FL_AL_AUS nicht_aktiv SP_MOTOR_F_EINTRAG aktiv TREIBER_F_EINTRAG aktiv SP_MOTOR_BEWERTEN aktiv TREIBER_BEWERTEN aktiv BLK_H_R_PICT aktiv SPG_NACHREGELUNG_1 wert_01 BLK_H_L_PICT aktiv BLK_V_R_PICT aktiv BLK_V_L_PICT aktiv XENON_TIMEOUT wert_01 XENON_TIME wert_01 BFD_ST3_ON nicht_aktiv PROGRAMMPARAMETER_LCM_10 wert_01 PROGRAMMPARAMETER_LCM_11 wert_01 PROGRAMMPARAMETER_LCM_12 wert_01 DEF_PIN_37_VOR nicht_aktiv DEF_PIN_20_VOR nicht_aktiv DAUERFAHRLICHT_EU nicht_aktiv ST3_SCHWEL nicht_aktiv PIN29_30_BL_NSL nicht_aktiv BFD_SW1_STUFE3 nicht_aktiv BFD_SW2_STUFE2 nicht_aktiv PIN5_10_BFD nicht_aktiv PWM_ANSTEUERUNG_NSW wert_01 LOAD_DUMP_U_GR wert_01 LOAD_DUMP_TIME_OUT wert_01 LOAD_DUMP_PWM_BLK wert_01 LOAD_DUMP_EINVER wert_01 KL_50_FUNK_AKT aktiv LOAD_DUMP aktiv FL_KL_50 aktiv NSW_KL_50 aktiv LOAD_DUMP_AUSVER wert_01 WARMUEBERWACHUNG_BLK_HI aktiv LOAD_DUMP_KL58G aktiv LOAD_DUMP_P44_45 aktiv LOAD_DUMP_P20 aktiv LOAD_DUMP_P37 aktiv LOAD_DUMP_P38 aktiv LOAD_DUMP_P49 aktiv NACHREG_DYN_SLOW aktiv SP_BEWERT_OD_ALC_NSW_AUS aktiv TREIBER_STOP_OD_ALC_RE_OK aktiv LWR_INVERS_OD_ALC_6 wert_01 REF_LAUF_T1_OD_ALC_4 wert_01 BLST1_BLST3 nicht_aktiv BFD_ABS_STUFE3 nicht_aktiv BFD_STUFE3_TIMER wert_02 BFD_BLINK_EINZEIT wert_02 BFD_BLINK_AUSZEIT wert_02 BFD_SW2_STUFE3 nicht_aktiv BFD3_ASC_AKTIV nicht_aktiv TEST_OD_ST2_OHNE_NSW nicht_aktiv ALC_KLS_DISABLE nicht_aktiv ALC_LWR_DISABLE wert_01 CAN_11H aktiv LENK_UEBERSETZUNG_LO wert_03 V_LO_AENDER_LENK_UEBERS wert_02 V_HI_AENDER_LENK_UEBERS wert_02 V_LO_SW_NACH_INNEN wert_02 V_HI_SW_NACH_INNEN wert_02 Z_GRAD_NACH_INNEN_HI wert_02 SW_NULL_BEREICH wert_02 V_LO_SW_MITLENKEN wert_02 V_HI_SW_MITLENKEN wert_02 V_LO_REDUZIER_V_SCHWENK wert_02 V_HI_REDUZIER_V_SCHWENK wert_02 REDUZIERUNG_V_SCHWENK_HI wert_02 AEND_V_SCHWENK_N_AUSSEN wert_02 LICHTZ_R_L_FAKTOR wert_02 MAX_SW_SCHWENK_W_AUSSEN wert_02 MAX_SW_SCHWENK_V wert_02 MAX_SW_SCHWENK_W_INNEN wert_02 NORM_LEUCHTWEITE wert_02 MAX_DELTA_KEINE_VERR wert_02 MAX_VERRINGERUNG_V_SCHW wert_02 MIN_DELTA_MAX_VERR wert_02 REDUZ_KENNL_MAX_SCHWENK wert_02 V_HI_RED_SCHWENK_W wert_02 FZG_RADSTAND wert_02 T_FILTER_GIERRATE wert_02 V_LO_TAU_GIERRATE wert_02 V_HI_TAU_GIERRATE wert_02 TAU_ABSCHWAECHUNG wert_02 D_TAU_MITTEL_LENKW wert_02 D_TAU_MITTEL_GIERR wert_02 IN_RICHT_NULL_ABSCHW wert_02 ABSCHW_D_TAU_LO wert_02 V_LO_ABSCHW_D_TAU wert_02 ABSCHW_D_TAU_HI wert_02 V_HI_ABSCHW_D_TAU wert_02 T_FILTER_LENKWINKEL wert_02 ALC_LWR_VORZEICHEN nicht_aktiv ALC_LEUCHTWEITENREG_AUTOM aktiv ALC_LEUCHTWEITENREG_DYNAM aktiv ALC_AUSWERT_PROP_ABWEICH aktiv ALC_AUSWERT_GRADIENT aktiv ALC_KENNLIN_LWR_SENSOR_VO wert_02 ALC_KENNLIN_LWR_SENSOR_HI wert_02 ALC_DEF_LWR_SENSOR_HI wert_02 ALC_LWR_NEIGUNG_KONSTANTE wert_02 ALC_OFFSET_LWR wert_02 ALC_EPSILON_DELTA_AV wert_02 ALC_EPSILON_DELTA_A wert_02 ALC_ANHEBUNG_175_KM/H wert_02 ALC_ABSENKUNG_10_KM/H wert_02 ALC_VMAX_BESCHLEUNIGUNG wert_02 ALC_VMIN_BESCHLEUNIGUNG wert_02 ALC_VMAX_BREMSEN wert_02 ALC_VMIN_BREMSEN wert_02 ALC_SCHW_GRAD_BESCHLEUNIG wert_02 ALC_SCHW_GRAD_BREMSEN wert_02 ALC_SCHW_PROP_ABWEICHUNG wert_02 V_LO_RED_SCHWENK_W wert_02 ALC_DIFFERENZ_MSP_DYN_STA wert_02 ALC_DAUER_DYN_NACHFUEHR wert_02 ALC_ABTASTRATE_DYN wert_02 ALC_MITTELUNGSINTERV_DYN wert_02 ALC_MIN_STEIGUNG_VZ_WECHS wert_02 ALC_MITTELUNGSINT_VZ_WECH wert_02 ALC_MINDESTANZAHL_VZ_WECH wert_02 ALC_HOEHENWEG wert_02 ALC_ABTASTRATE_TREND wert_02 ALC_MITTELUNGSINTERV_TREN wert_02 ALC_SCHW_TREND wert_02 ALC_ABWEICHUNG_TREND wert_02 ALC_GRADIENT_SCHLECHTWEG nicht_aktiv ALC_NACHLAUF_SCHLECHTWEG wert_02 ALC_EINSCHALTBEDINGUNG wert_01 ALC_SAETT_TIMER_SCHLECHTW aktiv ALC_SCHW_GRAD_SCHLECHTWEG wert_01 ALC_SCHWENK_LATCH aktiv IK_BUS_TEILNEMER aktiv ALC_KLS_ENABLE aktiv AUTO_LWR_ENABLE aktiv DYNAM_LWR_ENABLE aktiv ERR_SCHWENK_L_IGNORIEREN nicht_aktiv ERR_SCHWENK_R_IGNORIEREN nicht_aktiv ERR_LWR_L_IGNORIEREN nicht_aktiv ERR_LWR_R_IGNORIEREN nicht_aktiv KEINE_L_R_SYNCHRONISATION nicht_aktiv MAX_SW_SCHWENK_V_HORIZ wert_02 MAX_SW_SCHWENK_V_VERTI wert_02 ABSTELLPOS_SMC aktiv ABSTELLPOS_CUSTOM nicht_aktiv C_METER_NACH_INNEN_HI wert_02 KENNL_MAX_UEBERST wert_02 KENNL_REDUZ_MAX_SCHWENK wert_02 T_FILTER_UEBERST wert_02 T_FILTER_V_VEH wert_02 ABSCHWAECH_D_TAU wert_02 V_REFERENZLAUF_EN wert_02 KLASSIF_LENKM_ENA aktiv KLASSIF_DRIFT_ENA aktiv KLASSIF_UEBERST_ENA aktiv OHNE_GIERRATE nicht_aktiv MIN_SW_SCHWENK_V_HORIZ wert_02 REDUZIERUNG_V_SCHWENK_LO wert_02 V_M_LO_REDUZIER_V_SCHWENK wert_02 T_F_GIERRATE_DEF wert_02 SCHW_TAU_LW_GR wert_02 DRIFT_INKR wert_02 DRIFT_DEKR wert_02 DRIFT_SCHWELLE wert_02 T_FILTER_TAU_LW wert_02 T_FILTER_DYN_LZ wert_02 RAUSCH wert_02 ZEITK_TRIGGER1 wert_02 MERKM_1_MAX wert_02 MERKM_1_BEGR wert_02 MERKM_1_INKR wert_02 MERKM_1_DEKR wert_02 V_M_HI_REDUZIER_V_SCHWENK wert_02 CHECK_FGN_SMC_ALC_OFF aktiv LWR_ABSTELLPOS wert_01 BLEND_CHECK_IST_WINKEL aktiv BLEND_CHECK_SOLL_WINKEL nicht_aktiv CKM_ALC wert_02 CKM_ALC_DEF wert_02 MIN_SW_SCHWENK_V_VERTI wert_02 PROGRAMMPARAM_ALC_SG_1 wert_01 PROGRAMMPARAM_ALC_SG_2 wert_01 PROGRAMMPARAM_ALC_SG_3 wert_01 PROGRAMMPARAM_ALC_SG_4 wert_01 PROGRAMMPARAM_ALC_SG_5 wert_01 CHECK_SMC_ERROR aktiv PROGRAMMPARAM_ALC_SG_6 wert_01 PROGRAMMPARAM_ALC_SG_7 wert_01 KL_ENABLE wert_02 KL_HS wert_02 KL_TEST wert_01 KL_HOCH_STROM wert_02 KL_HELLA_MES_SEN_ERR wert_01 KL_FLANKE_SEN_ERR wert_01 KL_TREIBER_ERR wert_01 KL_TREIBER_BEW wert_01 KL_REF2_MODE wert_02 KL_REF1_MODE wert_02 KL_SENS_INVERT_RE wert_02 KL_ACC_AUS wert_01 KL_POSIT_RECHTS_RE wert_02 KL_TIME_OUT wert_02 KL_SENSOR_AUSWERT wert_02 KL_KOMFORT wert_01 KL_SENSOR wert_01 KL_ANSCHLAG_OPT_RE wert_01 KL_ANSCHLAG_WEICH_RE wert_01 KL_MAX_WINKEL_MIN_RE wert_01 KL_MAX_WINKEL_PL_RE wert_01 KL_NUL_LAGE_SENSOR_RE wert_01 KL_ABST_POSIT_RE wert_01 KL_HS_GRAD_LOW wert_01 KL_HS_GRAD_WERT wert_01 KL_SCHRITT_ABST_REF2 wert_01 KL_PWM_SENS_MAX_PLUS_RE wert_01 KL_RAMP_BESCH wert_02 KL_RAMP_BREMS wert_02 KL_SIZE_RAMP_BESCH wert_01 KL_SIZE_RAMP_BREMS wert_01 LWR_ENABLE wert_02 LWR_HS wert_02 LWR_TEST wert_01 LWR_HOCH_STROM wert_02 LWR_TREIBER_ERR nicht_aktiv LWR_TREIBER_BEW nicht_aktiv LWR_REF2_MODE wert_02 LWR_REF1_MODE wert_02 LWR_TIME_OUT wert_02 LWR_ACC_AUS wert_01 LWR_POSIT_RECHTS_RE wert_01 LWR_ANSCHLAG_OPT wert_03 LWR_ANSCHLAG_WEICH wert_03 LWR_MAX_WINKEL_PL wert_03 LWR_MAX_WINKEL_MIN wert_03 LWR_HS_GRAD_LOW wert_03 LWR_HS_GRAD_WERT wert_03 LWR_MAX_WERT_START wert_01 LWR_RAMP_BESCH wert_02 LWR_RAMP_BREMS wert_02 LWR_SIZE_RAMP_BREMS wert_01 GESCHW_TAB_0 kennlinie_01 GESCHW_TAB_1 kennlinie_01 GESCHW_TAB_2 kennlinie_01 GESCHW_TAB_3 kennlinie_01 GESCHW_TAB_4 kennlinie_01 SPIKE_ERR wert_01 NOT_U_SENS wert_02 DEF_POSIT_LWR wert_01 OFFSET_FEHL_EINTR wert_01 BASE_FEHL_EINTR wert_01 KL_REF_SPEED wert_01 RAMPE_ZUS_0 kennlinie_1 RAMPE_ZUS_1 kennlinie_1 RAMPE_ZUS_2 kennlinie_1 RAMPE0_BL_0 kennlinie_01 RAMPE0_BL_1 kennlinie_01 RAMPE0_BL_2 kennlinie_01 RAMPE0_BL_3 kennlinie_01 RAMPE1_BL_0 kennlinie_01 RAMPE1_BL_1 kennlinie_01 RAMPE1_BL_2 kennlinie_01 RAMPE1_BL_3 kennlinie_01 RAMPE2_BL_0 kennlinie_01 RAMPE2_BL_1 kennlinie_01 RAMPE2_BL_2 kennlinie_01 RAMPE2_BL_3 kennlinie_01 RAMPE3_BL_1 kennlinie_01 RAMPE3_BL_2 kennlinie_01 RAMPE3_BL_3 kennlinie_01 KL_POSIT_RECHTS_LI wert_01 KL_SENS_INVERT_LI wert_02 KL_ANSCHLAG_OPT_LI wert_01 KL_ANSCHLAG_WEICH_LI wert_01 KL_MAX_WINKEL_MIN_LI wert_01 KL_MAX_WINKEL_PL_LI wert_01 KL_NUL_LAGE_SENSOR_LI wert_01 KL_ABST_POSIT_LI wert_01 KL_PWM_SENS_MAX_PLUS_LI wert_01 LWR_POSIT_RECHTS_LI wert_01 RAMPE3_BL_0 kennlinie_01 LWR_ABS_RECHTS_VERK wert_02 LWR_ABS_LINKS_VERK wert_02 AUT_SPIEGELVERSTELLUNG aktiv SPIEGELABKLAPPEN aktiv BEIKLAPPEN_B_KOMFORTSCHL nicht_aktiv MEMORY_SPIEGELABKLAPPEN nicht_aktiv SPIEGELHEIZUNG ptc_kl_15 SITZMEMORY_VERBAUT aktiv V_VAR_SPERRE_BEIKLAPPEN wert_01 ANZAHL_WANDLER 4_wandler TONGEBER_HINTEN gong TONGEBER_VORN gong NUR_EIN_TONGEBER nicht_aktiv PDC_SCHALTER nicht_aktiv RUECKFAHRGONG aktiv EINSCHALTVERZOEGERUNG aktiv FILTER_DETEKTION_WEIT nicht_aktiv PDC_EIN_BEI_KL15 nicht_aktiv PDC_AKTIV/DEAKTIV rueckwaertsgang EINSCHALTMELDUNG_BEI_1MAL nicht_aktiv EINSCHALTMELDUNG_IMMER nicht_aktiv ABSCHALTMELDUNG nicht_aktiv MELDUNG_TASTER nicht_aktiv NOTFUNKTION nicht_aktiv AKUSTIK_KONZEPT nicht_aktiv ANFANGSWERT_ECKE_HINTEN 100_prozent ANFANGSWERT_MITTE_HINTEN 100_prozent ANFANGSWERT_ECKE_VORN 100_prozent SKALIERUNG_ECKE_VORN 0.65 ANFANGSWERT_MITTE_VORN 100_prozent SKALIERUNG_MITTE_VORN 0.65 NUR_KL15_BETRIEB aktiv EIS_AUSBLENDEN aktiv REG wert_04 KEY_MEMORY_RADIO nicht_aktiv ANZAHL_ANTENNEN 4 ANZAHL_RAEDER_UEBERWACHT 4 RE_TELEGRAMME 3 DRUCK_OFFSET wert_01 FLC_SCHWELLWERT_SATZ wert_01 FLC_SCHWELLWERT_SATZ_2 wert_01 FLC_SCHWELLWERT_SATZ_3 wert_01 FLC_SCHWELLWERT_SATZ_4 wert_01 WISCHERMOTOR_RSK wert_02 SCHIEBEHEBEDACH_TIPP_AUF aktiv KOMFORTFUNK_BEREICH_HEB nicht_aktiv GLASDACH aktiv SCHIEBEHEBEDACH_TIPP_ZU aktiv SCHIEBEHEBEDACH_TIPP_HEB aktiv OPTIMIERTE_SCHLIESSFKT aktiv HERSTELLER bmw ANTI_DROEHN_STELLUNG nicht_aktiv AUSSENGEFUEHRTE_SHD nicht_aktiv SEITENTUEREN 4_tueren PANIC_CLOSE nicht_aktiv EEPROM_SHD nicht_aktiv KLEMMENSTATUS nicht_aktiv DACHTYP shd DATENSATZ_1 nicht_aktiv DATENSATZ_2 nicht_aktiv LAMPENCHECK_GESICHERT aktiv KLEMME_15_LIEGT_AM_SG_AN nicht_aktiv MEMORY_TIPP_BETRIEB aktiv PEGELPARAMETER_P_MSB/LSB wert_01 PEGELPARAMETER_I_MSB/LSB wert_01 PEGELPARAMETER_D_MSB/LSB wert_01 MOTORPOLE wert_01 VCO_CONFIG wert_01 BANDPASS_CONFIG wert_01 STROMUMRECHNUNG wert_01 P0_U_KL.30_MSB/LSB wert_01 P0_DREHZAHL_MSB/LSB wert_01 P1_U_KL.30_MSB/LSB wert_01 P1_DREHZAHL_MSB/LSB wert_01 BEDUG_1/2 wert_01 DREHZAHL/FOERDERKENNLINIE wert_01 MAX_MOTORSP._MSB/LSB wert_01 MIN_MOTORSP._MSB/LSB wert_01 MAX_MOTORSTROM._MSB/LSB wert_01 MIN_MOTORSTROM._MSB/LSB wert_01 KEIN_MOTORSTROM._MSB/LSB wert_01 MAX_POS_DREHZAHLDIFF wert_01 MAX_NEG_DREHZAHLDIFF wert_01 KEINE_DREHZAHL_MSB/LSB wert_01 MAX_SPANNUNG_KL15_MSB/LSB wert_01 MIN_SPANNUNG_KL15_MSB/LSB wert_01 MAX_SPANNUNG_KL30_MSB/LSB wert_01 MIN_SPANNUNG_KL30 wert_01 KEINE_SPANNUNG_KL30 wert_01 UEBERTEMP_LS/HS wert_01 NACHLAUFZEIT wert_03 ULF_EIN_AUS aktiv ANZAHL_STUFEN wert_03 KMH_STUFEN wert_03 KMH_HYSTERESE wert_02 GERAETENAME wert_01 HANDY_TYP nokia_3110 AMR_TYP typ_3 BMR_TYP typ_2 HYDR_BREMSKRAFTVERTEILUNG typ_3 LOGIK_HA_SPERRE nicht_aktiv REFERENZLAUF_LWR_KL15 nicht_aktiv MOTOR_ART_ASC wert_01 DV_OFFSET line3 DROSSEL nicht_aktiv HBA_SCHWELLANHEBUNG wert_01 HBA_VARIANTEN wert_01 DBC_MIN_AUSLOESEDRUCK wert_01 HBA_VARIANTEN_2 wert_04 HBA_SCHWELLANHEBUNG_2 wert_10 BAUART_MK60 coupe_s SPERRDIFFERENZREGELUNG aktiv TRAKTIONDIFFERENZREGELUNG aktiv DTC_LAMPE nicht_aktiv UNTERSTEUERUNGSALGORYTHM aktiv DYN_BREMS_UNTERSTUETZUNG aktiv MAX_BREMS_UNTERSTUETZUNG aktiv FUNKTION_DSC aktiv CODIERWERT_DSC5.7 wert_02 HILLDESC_DSC_5_7 nicht_aktiv EINSPURMODELLPARAMETER typ_8 DRUCKMODELLPARAMETER typ_0 DRUCKMODELL_HINTERACHSE typ_1 DRUCKMODELL_VORDERACHSE typ_0 REIFENDRUCKWARNSYSTEM nicht_aktiv VOLUMENDURCHFLUSSPARA_2 wert_02 SEQ_M_GETRIEBE nicht_aktiv UEBERSTEUERN_MUE_0 wert_02 UEBERSTEUERN_MUE_0_2 wert_02 UEBERSTEUERN_MUE_1 wert_02 UEBERSTEUERN_MUE_1_2 wert_02 UNTERSTEUERN_MUE_0 wert_01 UNTERSTEUERN_MUE_1 wert_01 GRADIENT_MM_ZUGABE wert_02 DELTA_PSI_BETA_LIMIT_KORR wert_01 DELTA_PSI_BETA_LIMITKORR2 wert_01 UNTERSTEUERSCHWELLE wert_01 UNTERSTEUERSCHWELLE_2 wert_10 GEARMOMENTREGLER_MAX_HA_2 wert_02 GEARMOMENTREGLER_MIN_HA_2 wert_02 UNTERSTEUERN_MUE_0_2 wert_01 UNTERSTEUERN_MUE_1_2 wert_01 LENKWINKELKENNLINIE_2 wert_02 CRASHPARAMETER_11 e46_c CRASHPARAMETER_12 e46_c CRASHPARAMETER_13 e46_c CRASHPARAMETER_14 e46_c CRASHPARAMETER_15 e46_c CRASHPARAMETER_21 e46_c CRASHPARAMETER_22 e46_c CRASHPARAMETER_23 e46_c CRASHPARAMETER_24 e46_c CRASHPARAMETER_25 e46_c CRASHPARAMETER_0 e46 CRASHPARAMETER_01 e46 CRASHPARAMETER_02 e46 CRASHPARAMETER_03 e46 CRASHPARAMETER_04 e46 CRASHPARAMETER_05 e46 CRASHPARAMETER_06 e46 CRASHPARAMETER_07 e46 CRASHPARAMETER_08 e46 CRASHPARAMETER_09 e46 CRASHPARAMETER_0A e46 CRASHPARAMETER_MRS4_0 e46 CRASHPARAMETER_MRS4_01 e46 CRASHPARAMETER_MRS4_02 e46 CRASHPARAMETER_MRS4_03 e46 CRASHPARAMETER_MRS4_04 e46 CRASHPARAMETER_MRS4_05 e46 CRASHPARAMETER_MRS4_06 e46 CRASHPARAMETER_MRS4_07 e46 CRASHPARAMETER_MRS4_08 e46 CRASHPARAMETER_MRS4_09 e46 CRASHPARAMETER_MRS4_0A e46 CRASHPARAMETER_MRS4_0B e46 CRASHPARAMETER_MRS4_0C e46 CRASHPARAMETER_MRS4_0D e46 CRASHPARAMETER_MRS4_0E e46 CRASHPARAMETER_MRS4_0F e46 CRASHPARAMETER_MRS4_10 e46 CRASHPARAMETER_MRS4_11 e46 CRASHPARAMETER_MRS4_12 e46 CRASHPARAMETER_MRS4_13 e46 CRASHPARAMETER_MRS4_14 e46 MRSAPARAMETER_0 e46 MRSAPARAMETER_01 e46 MRSAPARAMETER_02 e46 MRSAPARAMETER_03 e46 MRSAPARAMETER_04 e46 MRSAPARAMETER_05 e46 MRSAPARAMETER_06 e46 AIRBAG_FAHRER_1 aktiv AIRBAG_FAHRER_2 aktiv FAHRERBAG_STUFE2_1 aktiv FAHRERBAG_STUFE2_2 aktiv AIRBAG_BEIFAHRER_1 aktiv AIRBAG_BEIFAHRER_2 aktiv BEIFAHRERBAG_STUFE2_1 aktiv BEIFAHRERBAG_STUFE2_2 aktiv SIDEBAG_LINKS_1 aktiv SIDEBAG_RECHTS_1 aktiv SIDEBAG_LINKS_2 aktiv SIDEBAG_RECHTS_2 aktiv GURTSCHLOSS_STROMSS_1 nicht_aktiv GURTSCHLOSS_STROMSS_2 nicht_aktiv ITS_LINKS_1 aktiv ITS_RECHTS_1 aktiv ITS_LINKS_2 aktiv ITS_RECHTS_2 aktiv SIDEBAG_FOND_LINKS_1 nicht_aktiv SIDEBAG_FOND_RECHTS_1 nicht_aktiv SIDEBAG_FOND_LINKS_2 nicht_aktiv SIDEBAG_FOND_RECHTS_2 nicht_aktiv VERRIEGELN_SITZLEHNE_FA_1 nicht_aktiv VERRIEGELN_SITZLEHNE_FA_2 nicht_aktiv VERRIEGELN_SITZLEHNE_BF_1 nicht_aktiv VERRIEGELN_SITZLEHNE_BF_2 nicht_aktiv UEBER_ROLLSENSOR_1 nicht_aktiv UEBER_ROLLSENSOR_2 nicht_aktiv B_SATELLIT_1 aktiv B_SATELLIT_2 aktiv CODIERANFORDERUNG_0 e46 CODIERANFORDERUNG_1 e46 GURTSCHLOSS_FAHRER_1 nicht_aktiv GURTSCHLOSS_FAHRER_2 nicht_aktiv BPLUS_TRENNUNG1_1 aktiv BPLUS_TRENNUNG1_2 aktiv AUSLOESEKRITERIUM_1 ece AUSLOESEKRITERIUM_2 ece GURTSCHLOSS_BEIFAHRER_1 nicht_aktiv GURTSCHLOSS_BEIFAHRER_2 nicht_aktiv WISCHERINTERVALL 5_sec ENTSICHERN_CENTERLOCK nicht_aktiv QUIT_AKUST_SCHAERF_KLAPPE nicht_aktiv QUIT_AKUST_ENTSCH nicht_aktiv KALTUEBERWACHUNG_SL aktiv KALTUEBERWACHUNG_NSL aktiv FEHLER_STANDLICHT melden SL_VO_ANSTEUERUNG aktiv FERNLICHT_DRL nicht_aktiv EINZEIT_GED_BL wert_01 PERIODE_GED_BL wert_01 EINZEIT_DRL wert_01 PWM_ANSTEUERUNG_SL_VO_RE wert_01 PWM_ANSTEUERUNG_SL_VO_LI wert_01 BEGRENZUNGSLICHT_IN_PARK aktiv LAENDERVARIANTE_LSZ wert_01 KALTUEBERWACHUNG_SL_RE aktiv KALTUEBERWACHUNG_SL_LI aktiv WARMUEBERWACHUNG_SL_RE aktiv WARMUEBERWACHUNG_SL_LI aktiv CC_STANDLICHT_RECHTS aktiv CC_STANDLICHT_LINKS aktiv SIDEMARKER_US aktiv GEDIMMT_BLK_BEGRENZ_LICHT aktiv DRL_DIMMUNG wert_02 ZUENDSCHLUESSEL_WARNUNG nicht_aktiv AH_US_OPTION nicht_aktiv LEUCHTWEITENREGELUNG aktiv PIN_20_ALS_SIDEMARKER nicht_aktiv ALARM_OPT_FERNLICHT nicht_aktiv PANIK_MODUS nicht_aktiv MILANSTEUERUNG wert_01 VB_BATTERIE hinten PARK/NEUTRAL_EINGANG nicht_aktiv ABSCHALTDREHZAHL_ANLASSER 6_zylinder_benziner ZEITDAUER_BIS_ABSCHALTUNG benziner SCHALT_KRITERIUM_EWS_3 6_zylinder_benziner FGR_KENNDATEN e46_m43b19_66kw_man HARDTOP_ERKENNUNG nicht_aktiv CHECK_BLOCK_0 wert_01 FEHLER_V5GO nicht_aktiv PROGRAMMPARAMETER_CVM_1 wert_02 PROGRAMMPARAMETER_CVM_2 wert_02 CHECK_BLOCK_2 wert_02 FEHLER_V1KLAP nicht_aktiv VPUMPE_FEHLER nicht_aktiv CHECK_BLOCK_1 wert_02 SEGMENTGRENZEN_SB wert_02 AUSSENTEMP_BEWERT nicht_aktiv CHECK_BLOCK_4 wert_02 SCHEINWERFERREINIGUNG nicht_aktiv SENSOR_REGEN nicht_aktiv STANDRUECKSCHALTUNG aktiv HUB_VERZOEGERUNG_FH_VORN 500ms OHNE_SCHEIBENABSENKUNG nicht_aktiv FUNKTIONTUERSCHLOSS nicht_aktiv FERNBEDIENUNG_1 nicht_aktiv FERNBEDIENUNG_2 nicht_aktiv FERNBEDIENUNG_3 nicht_aktiv FERNBEDIENUNG_4 nicht_aktiv FH_ABSCHALTKRITERIUM us FH_ABSENKUNG_SPERREN nicht_aktiv FUNKTION_CABRIO nicht_aktiv KOMFORTOEFFNUNG_FB aktiv FH_ABSENKEN_VERDECK_OEFF nicht_aktiv AUSSTELLFENSTER aktiv FENSTERHEBER_HINTEN aktiv EINKLEMMSCH_VORNE aktiv EINKLEMMSCH_HINTEN nicht_aktiv EINKLEMMSCH_REVERSIEREN lang EINKLEMMSCH_REVERSIER_SHD kurz FH_FAHRERTUER_TIPP_ZU aktiv MAUT_NUR_BEI_KL15EIN nicht_aktiv FH_BEIFAHRERTUER_TIPP_ZU aktiv FH_TUEREN_HINTEN_TIPP_ZU nicht_aktiv ZV_SELEKTIV nicht_aktiv FUNKTIONEN_TOURING nicht_aktiv HECKSCHEIBE_ENTR_SENDER_1 nicht_aktiv HECKSCHEIBE_ENTR_SENDER_2 nicht_aktiv HECKSCHEIBE_ENTR_SENDER_3 nicht_aktiv HECKSCHEIBE_ENTR_SENDER_4 nicht_aktiv HECKSCHEIBE_ENTRI_INNEN nicht_aktiv KOMFORTSCHLIE_FB_O_FH_HI aktiv MAUT_ZU_STOP_N_TUER_AUF aktiv DWA aktiv NEIGUNGSGEBER aktiv FUNK_INNENRAUMSCHUTZ aktiv QUITIMP_SICHERN/ENTSICHER aktiv SCHAERFEN/ENTSCHAERFEN nur_mit_fernbedienung ALARM_AKUSTISCH intervallton ALARM_AKUSTISCH_LANG aktiv ALARM_OPT_WARNBLINKER aktiv DWA_HEKKLEPPENKONTAKT aktiv MIT_OPT_ALARM aktiv DWA_HEKSCHEIBENKONTAKT nicht_aktiv ALARM_OPT_ABBLENDLICHT nicht_aktiv QUIT_OPT_SCHAERF nicht_aktiv QUIT_OPT_SCHAERF_KLAPPE aktiv QUIT_OPT_ENTSCH nicht_aktiv FUNKINNENRAUMSCHUTZ_HI nicht_aktiv DWA_HANDSCHUHFACHKONTAKT nicht_aktiv FERNBEDIENUNG aktiv OHNE_FERNBEDIENUNG_0 nicht_aktiv KOMFORTSCHLIESSUNG_FB aktiv IR_FERNBEDIENUNG nicht_aktiv SEL_ZV_SENDER_1 nicht_aktiv SEL_ZV_SENDER_2 nicht_aktiv SEL_ZV_SENDER_3 nicht_aktiv SEL_ZV_SENDER_4 nicht_aktiv TAKTUNG_IB nicht_aktiv TAKTUNG_VERBRAUCHERABSCHA nicht_aktiv TAKTUNG_VA1 nicht_aktiv FH_INIT_TRANSPORTMODE aktiv ASF_PARAMETER_VARIANTE nicht_aktiv TAB_WIEDERHOLSPERRE_ASF_2 nicht_aktiv TAB_ANSTEURN_ASF_2 nicht_aktiv KOMFOEFFNEN_SPERRE_KEY_IN aktiv TUER_HINTEN nicht_aktiv RECHTSLENKER aktiv SITZMEMORY_VERBAUT_GM nicht_aktiv MIT_LIN nicht_aktiv SPIEGELABKLAPPEN_GM nicht_aktiv INDIVIDUALISIERUNG nicht_aktiv V_VAR_SPERRE_BEIKLAPP_GM klemme_r SPIEGELHEIZUNG_VERBAUT_GM nicht_aktiv BEIKLAPP_B_KOMFORTSCHL_GM nicht_aktiv BEIKLAPPEN_GM nicht_aktiv BEDIENSTELLE_BFT nicht_aktiv LAENDERVARIANTE_GT ece MULTIFUNCTION_1 great_britain MULTIFUNCTION_2 great_britain BAUART coupe WIDESCREEN_MODI wert_00 AUTOMATISCHER_NOTRUF nicht_aktiv TELEMATIK nicht_aktiv WAKEUP_BY_E-CALL no_wakeup NON-TELEMATIC_E-CALL nicht_aktiv AIRBAG_TRIGGERED_E-CALL nicht_aktiv TELEMATIK_ENABLED nicht_aktiv E-CALL_HARDKEY_FITTED nicht_aktiv SECOND_HARDKEY nicht_aktiv CUSTOMER_CALLS_OVER_GMIN nicht_aktiv TCU_TYPE ibus_ece BLUETOOTH bt_operation US_CALL_SERVICE_CENTER nicht_aktiv GPS_ON/OFF gps_off US_BUSINESS/PROF_VARIANT business_model WHEEL_CIRCUMFERENCE e46 TRACK_WIDTH e46_coupe WHEEL_BASE e46 DRIVE_WHEELS rear_wheel ZUHEIZER konventionell AUTOM_UMLUFT_CONTROL aktiv UMLUFT_MEMORY nicht_aktiv ZUHEIZ_RELAIS nicht_aktiv BORDMONITOR nicht_aktiv ZYLINDER_ZAHL 6_zylinder MOTOR_ART benziner GEREGELTER_KOMPRESSOR gross SOLARSENSOR aktiv SOLARSENSOR_GEBL_BALKEN aktiv ZUSATZWASSERPUMPE nicht_aktiv EL_DURCHLAUFERHITZER nicht_aktiv FUSSRAUMKLAPPE_SCHLIES_1 nicht_aktiv ENTFROSTKLAPPE_SCHLIES_1 nicht_aktiv KENNLINIE_AUTO_GEBLAESE_1 nicht_aktiv FUSSRAUMKLAPPE_SCHLIES_2 nicht_aktiv ENTFROSTKLAPPE_SCHLIES_2 nicht_aktiv KENNLINIE_AUTO_GEBLAESE_2 nicht_aktiv FUSSRAUMKLAPPE_SCHLIES_3 nicht_aktiv ENTFROSTKLAPPE_SCHLIES_3 nicht_aktiv KENNLINIE_AUTO_GEBLAESE_3 nicht_aktiv FUSSRAUMKLAPPE_SCHLIES_4 nicht_aktiv ENTFROSTKLAPPE_SCHLIES_4 nicht_aktiv KENNLINIE_AUTO_GEBLAESE_4 nicht_aktiv EINSCHALTSCHW_AUTO_UMLUFT wert_01 AUSSCHALTSCHW_AUTO_UMLUFT wert_01 AUTO_UMLUFT_ZEIT wert_01 ZUHEIZER_ELEKTR_BUS_EIN wert_01 ZUHEIZER_ELEKTR_BUS_AUS wert_01 ZUHEIZER_ELEKTR_LTG_EIN wert_01 ZUHEIZER_ELEKTR_LTG_AUS wert_01 KENNLINIE_HEIZZEIT_HHS kennlinie_01 HHS_AUTOMATIK nicht_aktiv K_ZAHL_TACHO 4961_imp/km K_ZAHL_TACHO_KOMPL 4961_imp/km K_ZAHL_WEG 4912_imp/km K_ZAHL_WEG_KOMPL 4912_imp/km LITER_SERVICE_INTERVALL m54b25_man_coup SIA_LITER_GRENZE m54b25_man_coup KM_SERVICE_INTERVALL 25.000_km NG_MOTORVARIANTEN nicht_aktiv SCHWELLEN m54b25 CAN_FGR aktiv MOTOR_KENNFELD wert_07 GENERATOR_UEBER_CAN nicht_aktiv TOG_UEBER_CAN nicht_aktiv MOTOR_ART_DSC m54b25 MOTOR_ART_DSC_2 m54b25 SPRACHE englisch WEG_EINHEIT mls WEG_DURCHSCHNITT mph WEG_REICHWEITE mls WEG_LIMIT mls ZEIT_EINHEIT 12_stunden TEMPERATUR_EINHEIT grad_c VERBRAUCH_D1 mpg_uk WARNUNG_GESCHW_LIMIT nicht_aktiv GURTWARNUNG ohne_gurtschlosskontakt AKUSTIK_GURT_WARN nicht_aktiv ANZEIGE_SITZLEHNE_VER nicht_aktiv AUSSENTEMP_SENSOR aktiv CC_AUSSENTEMPERATUR aktiv BC aktiv AUSSENTEMP_WARN_AKUSTIK aktiv QUITT_A_TEMP_WARNUNG_LSS aktiv RDKS nicht_aktiv AKUSTIK_RDKS nicht_aktiv LENKSTOCKSCHALTER_KLR aktiv OELNIVEAU_M3 nicht_aktiv ANZEIGE_HOCHLADEN nicht_aktiv AKUST_WARNUNG_OELVERL nicht_aktiv AKUST_WARNUNG_OELVERBR nicht_aktiv LL/RL rechtslenker LENKSEITE_1 rechtslenker LENKSEITE_2 rechtslenker GETRIEBE_ANZEIGE_GANG nicht_aktiv SEQ_SCHALTGETRIEBE nicht_aktiv GETRIEBEART handschaltung SMG_ALT_NEU nicht_aktiv SMG_D_C_ANZ nicht_aktiv RUECKWAERTSGANG_WARN_MED piezo RUECKWAERTSGANG_WARNUNG nicht_aktiv GETRIEBE handschaltung SIA_ANZEIGEPARAMETER mit_zeitinspektion SI_ZEITZAEHLUNG mit_zeitinspektion SIA_GRENZE_ZEIT 716_tage AUSBL_DREHZAHL wert_01 NAVI_DIST_TO_JUNCTION nicht_aktiv GURTKONTAKT_MELDUNG_UEBER k_bus HBA aktiv BC_V_KORREKTUR nicht_aktiv AKUSTIK_ASC aktiv CAN_RDC nicht_aktiv ANZEIGE_CFC nicht_aktiv SULEV_GATEWAY nicht_aktiv TANK_ZERO_EVAP nicht_aktiv TANK_KENNLINIE 60_l_literskala TANK_ANZEIGEWINKEL kennlinie_01 FZG_VERZOEGERUNG nicht_aktiv ASC_REGELUNG_AUF_KBUS nicht_aktiv GRENZWERT_VERZ_SCHWELLE nicht_aktiv HYSTERESE_VERZOEGERUNG nicht_aktiv GRENZWERT_GRUND_SCHWELLE nicht_aktiv GRENZWERT_VERZ_SCHWELLE_1 nicht_aktiv GRENZWERT_VERZ_SCHWELLE_2 nicht_aktiv CAN_BREMSFLUESSIGKEIT aktiv DBC_PREDRIVE aktiv ANZEIGE_OELSTAND_PREDRIVE aktiv CAN_OELDRUCKSCHALTER nicht_aktiv HEIMLEUCHTEN_KL58G nicht_aktiv TAXI_ENABLE nicht_aktiv FEHLER_NSL_LINKS nicht_melden FEHLER_NSL_RECHTS melden RECHTS_LINKS aktiv WINKEL_BLENDUNG wert_01 TAGFAHRLICHT nicht_aktiv TAGFAHRLICHT_ECE aktiv GED_FL_ALS_DRL nicht_aktiv VARIANTE_LSZ wert_02 LENKSEITE_LSZ wert_02 PROGRAMMPARAMETER_LSZ_1 ece PROGRAMMPARAMETER_LSZ_2 ece PROGRAMMPARAMETER_LSZ_3 ece PROGRAMMPARAMETER_LSZ_4 ece PROGRAMMPARAMETER_LSZ_5 ece PROGRAMMPARAMETER_LSZ_6 ece PROGRAMMPARAMETER_LSZ_7 ece PROGRAMMPARAMETER_LSZ_8 ece PROGRAMMPARAMETER_LSZ_9 ece PROGRAMMPARAMETER_LSZ_10 ece PROGRAMMPARAMETER_LSZ_11 ece PROGRAMMPARAMETER_LSZ_12 ece PROGRAMMPARAMETER_LSZ_13 ece SCHRITTE_STELLUNG_1 wert_01 SCHRITTE_STELLUNG_2 wert_01 ABS_MIN_STELLUNG_2 wert_01 KALTUEBERWACHUNG_AL nicht_aktiv SCHRITTE_STELLUNG_0 wert_01 HYSTERESE_STARTBEDINGUNG wert_01 ABSTAND_HOLD_NORMAL_MODE wert_01 PWM_ANSTEUERUNG_AL wert_01 LEUCHTWEITENREG_AUTOM nicht_aktiv XENON_TEST nicht_aktiv LEUCHTWEITENREG_DYNAM nicht_aktiv BI_XENON nicht_aktiv HALB/VOLLSCHRITT vollschritt PWM_WERT2_FL_BIXENON wert_01 FL_UND_NSW_NICHT_GLEICHZ nicht_aktiv FEHLER_SCHALTER_BREMSL nicht_melden BLS_PRUEFEN nicht_aktiv LWR_VORZEICHEN nicht_aktiv PIN29_30_BFD nicht_aktiv FLC_LED_AKTIV nicht_aktiv ALC_DEF_AKTIV nicht_aktiv ALC_BLK_PER wert_02 KENNLINIE_LWR_SENSOR_VO wert_01 KENNLINIE_LWR_SENSOR_HI wert_01 VMAX_BESCHLEUNIGUNG wert_04 VMIN_BESCHLEUNIGUNG wert_04 DEF_LWR_SENSOR_HI wert_01 OFFSET_LWR wert_01 PWM_ANSTEUERUNG_SL3_LI_HI wert_04 PWM_ANSTEUERUNG_SL3_RE_HI wert_03 PWM_ANSTEUERUNG_SL2_RE_HI wert_01 KALTUEBERWACHUNG_RL_3_LI nicht_aktiv KALTUEBERWACHUNG_RL_3_RE nicht_aktiv WARMUEBERWACHUNG_RL_3_LI nicht_aktiv WARMUEBERWACHUNG_RL_3_RE nicht_aktiv WARMUEBERWACHUNG_RL_2_RE nicht_aktiv CC_RUECKLICHT_3_LINKS nicht_aktiv CC_RUECKLICHT_3_RECHTS nicht_aktiv NSL_ALS_STANDLICHT nicht_aktiv PIN_37_ALS_SL_RE_2 nicht_aktiv SL_X_3_ERSETZT_DEFEKT_BL nicht_aktiv SL_3_ERSETZT_DEFEKT_BLK nicht_aktiv KALTUEBERWACHUNG_RL_2_RE nicht_aktiv CC_RUECKLICHT_2_RECHTS nicht_aktiv PIN_20_ALS_SL_LI_3_ANSTEU nicht_aktiv PIN_38_ALS_SL_RE_3 nicht_aktiv KALTUEBERWACHUNG_NSL_LI aktiv WARMUEBERWACHUNG_NSL_LI aktiv DEF_PIN_5_10_DEFEKTBLK aktiv DEF_PIN_5_10_DEFEKT_SL nicht_aktiv P_10_5_ALS_BL_FUNKTION aktiv BL_ERSETZ_DEFEKT_SL nicht_aktiv PWM_WERT2_BLK_ZUSATZFKT wert_01 DEF_PIN_29_30_DEFEKT_BL nicht_aktiv DEF_PIN_29_30_DEFEKT_SL aktiv STANDLICHT_ALS_BREMSLICHT nicht_aktiv PWM_WERT2_SL3_ZUSATZFKT wert_01 BREMSLICHT_ALS_STANDLICHT nicht_aktiv PIN_20_ALS_NSL aktiv BLK_DIMMEN nicht_aktiv INTERM_FL nicht_aktiv SCHALTER2_BL nicht_aktiv GEDIMMT_BL__BEGRENZ_LICHT nicht_aktiv PWM_ANSTEUERUNG_SL_LI_HI wert_03 PWM_ANSTEUERUNG_SL_RE_HI wert_03 PWM_ANSTEUERUNG_KZL wert_01 KALTUEBERWACHUNG_RL_LI nicht_aktiv KALTUEBERWACHUNG_RL_RE nicht_aktiv KALTUEBERWACH_ZUSATZ_BLK nicht_aktiv WARMUEBERWACHUNG_BL nicht_aktiv WARMUEBERWACHUNG_RL_LI nicht_aktiv WARMUEBERWACHUNG_RL_RE nicht_aktiv CC_RUECKLICHT_LINKS nicht_aktiv CC_RUECKLICHT_RECHTS nicht_aktiv CC_BREMSLICHT nicht_aktiv CC_BLINKER_HINTEN nicht_aktiv PWM_WERT2_ALS_BL_AUSGANG wert_02 KALTUEBERWACHUNG_BL nicht_aktiv KALTUEBERWACHUNG_BLK_HI nicht_aktiv PWM_WERT2_ALS_SL_AUSGANG wert_03 NSL_ERSETZT_DEFEKT_BL nicht_aktiv BL_ERSETZT_DEFEKT_BLK aktiv SL_ERSETZT_DEFEKT_BLK nicht_aktiv STANDLICHT_ALS_NSL_LINKS nicht_aktiv STANDLICHT_ALS_NSL_RECHTS nicht_aktiv FO_ME_HOME_SL2 nicht_aktiv PIN37_49_PARKL nicht_aktiv PIN38_20_PARK nicht_aktiv HEIMLEUCHTEN_SL3_H nicht_aktiv PIN29_30_PARK aktiv HEIMLEUCHTEN_SL_H aktiv HEIMLEUCHTEN_SL_V aktiv BFD_MINDEST_GESCHW wert_02 BFD_STUFE_2_VERZOEG wert_02 BFD_STUFE_2_MAX_EIN wert_02 BFD_SW1_STUFE2 nicht_aktiv BFD_ABS_STUFE2 nicht_aktiv BFD_STUFE2_TIMER wert_02 BFD3_ASC_TIMER wert_02 PIN49_37_BFD nicht_aktiv PIN38_20_BFD nicht_aktiv M_TELEGRAM nicht_aktiv M_TELEGRAM_OD_ALC_5 nicht_aktiv PWM_ANSTEUERUNG_BL wert_03 PWM_ANSTEUERUNG_BLK_HI wert_03 SL_ERSETZT_DEFEKT_BL nicht_aktiv AL_KL_50 aktiv LOAD_DUMP_P5_10 nicht_aktiv LOAD_DUMP_P30_29 aktiv SP_F_EINTR_OD_ALC_NSW_PIC aktiv TR_F_EINTR_OD_ALC_AL_FPIC aktiv U_POTI_0_OD_FAILSAFE_ON wert_01 U_POTI_1_OD_DAEMMERSTUFE wert_01 U_POTI_2_OD_ALC_PARA_01 wert_01 SCHRITT_GRENZE_OD_ALC_IO wert_01 TEMP_GRENZE_OD_ALC_NIO wert_01 REF_LAUF_STEP_OD_ALC_2 wert_01 REF_LAUF_ZAHL_OD_ALC_1 wert_01 REF_LAUF_T2_OD_ALC_3 wert_01 TEMP_RAMPE_OD_ALC_8 aktiv PROGRAMMPARAMETER_LCM_1 wert_01 PROGRAMMPARAMETER_LCM_2 wert_01 PROGRAMMPARAMETER_LCM_3 wert_01 PROGRAMMPARAMETER_LCM_4 wert_01 PROGRAMMPARAMETER_LCM_5 wert_01 PROGRAMMPARAMETER_LCM_6 wert_01 PROGRAMMPARAMETER_LCM_7 wert_01 PROGRAMMPARAMETER_LCM_8 wert_01 PROGRAMMPARAMETER_LCM_9 wert_01 SCHRITTABSTAND_STARTPHASE kennlinie_01 SCHRITTE_0_OD_ALC_AKTIV_0 wert_01 HYSTERESE_OD_AL_XENON_IO wert_01 T_STROM_OD_ALC_PARA_02 wert_01 SCHRITTE_1_OD_ALC_AKTIV_1 wert_01 SCHRITTE_2_OD_ALC_AKTIV_2 wert_01 ABS_MIN_2_OD_ALC_AKTIV_3 wert_01 S_MOTORWEG_OD_ALC_7 wert_01 LINKSVERKEHR aktiv RECHTSVERKEHR nicht_aktiv KLS_BEI_AL_AKTIV aktiv SCHALTER_R_GANG aktiv LENK_UEBERSETZUNG wert_02 LWS5_KENNFELD_0 e46 LWS5_KENNFELD_1 e46 LWS5_KENNFELD_2 e46 LWS5_KENNFELD_3 e46 LWS5_KENNFELD_4 e46 LWS5_KENNFELD_5 e46 LWS5_KENNFELD_6 e46 MESSBEREICHE_WANDLER e46/2 MESSBEREICH_HECKKL_ECKE e46/2 MESSBEREICH_HECKKL_MITTE e46/2 LAUTSTAERKE_HINTEN wert_06 LAUTSTAERKE_VORN e46/2 EINSCHALT_GESCHWINDIGKEIT e46/2 ABSCHALT_GESCHWINDIGKEIT e46/2 ABSCHALTWEG e46/2 WEGKENNZAHL e46/2 LAUTSTAERKE_TONGEBER e46/2 VERZOEG_RUECKFAHRGONG e46/2 DAUERTON_MESSBEREICH e46/2 AHK_ABSTAND e46/2_716 OFFSET_MESSBEREICH e46/2_716 ECHOSCHWELLWERTE_ECKE_HI e46/2_716 ECHOSCHWELLWERTE_MITTE_HI e46/2_716 ECHOSCHWELLWERTE_ECKE_VO e46/2 ECHOSCHWELLWERTE_MITTE_VO e46/2 SKALIERUNG_ECKE_HINTEN 0.65 SKALIERUNG_MITTE_HINTEN 0.65 ABSTAND_EINBAU_WANDLER e46/2_716 ANHAENGERKUPPLUNG nicht_aktiv TYP_FRONTSCHEIBE serienscheibe HECKKLAPPE aktiv SCHIEBEHEBEDACH_TIPP_SENK aktiv EINKLEMMSCH_SHD_HEBEN aktiv EINKLEMMSCH_SHD_ZU aktiv AUT_SITZVERSTELLUNG nicht_aktiv SPIEGELHEIZUNG_VERBAUT aktiv ABKLAPPWERT wert_02 ANZAHL_RAEDER_VERBAUT 4 LAENDERVARIANTE_RADIO ece TP_FUNKTION tp GAL wert_03 RDS-AF_SWITCHING rds_on/af_auto PTY_TABELLE ece TP_MINIMAL_VOLUME wert_00 SPRACHERKENNUNG_EIN_AUS nicht_aktiv AD_GAIN wert_03 AD_GAIN_1 wert_03 AD_OGAIN wert_03 AD_OGAIN_1 wert_03 HD_HYBRID_AVE wert_03 HD_I2TX_TXSN wert_03 HD_I2RX_RXSN wert_03 HD_TX2RX_RXSN wert_03 HD_TX2DT_RXSN wert_03 HD_DT_ERLE wert_03 HD_HYBRID_AVE_NOTCH wert_03 HD_I2DT_TXBSN wert_03 HD_I2DT_RXBSN wert_03 HD_TX2DT_TXBSN wert_03 HD_TX2DT_RXBSN wert_03 HD_RX2DT_TXBSN wert_03 HD_RX2DT_RXBSN wert_03 HD_AC_MARGIN_W_AEC wert_03 HD_AC_MARGIN_BOOST wert_03 HD_LES_MAX wert_03 HD_LES_MIN wert_03 HD_RX2DT_RXSN wert_03 HD_AC_AVE_THR wert_03 HD_DT_LOSS_SHIFT wert_03 HD_DT_LOSS_BIAS wert_03 HD_ERLE_2_UPD_LMS wert_03 HD_ERLE_2_UPD_AE wert_03 HD_LEC_ERLE_MARGIN wert_03 HD_RX_CLIP_THR wert_03 HD_DT_CLIP_THR wert_03 HD_INC_H wert_03 HD_I2TX_TXE wert_03 HD_HYB_MARGIN_WO_LEC wert_03 HD_I2RX_RXE wert_03 HD_TX2RX_RXE wert_03 HD_TX2DT_RXE wert_03 HD_TX_HOLD wert_03 HD_RX_HOLD wert_03 HD_DT_HOLD wert_03 HD_LSW_MIN wert_03 HD_HYBRID_AVE_LEC wert_03 V_SNS_LWR_GAIN_BND_D_N wert_03 HD_DO_LEC_ERLE wert_03 HD_TX2RX_HOLD wert_03 HD_LOOP_MARGIN wert_03 HD_AC_MARGIN_WO_AEC wert_03 HD_HYBRID_MARGIN_W_LEC wert_03 HD_LSW_MAX wert_03 HD_LLES_MIN wert_03 HD_LLES_MAX wert_03 HD_DO_NOTCH wert_03 P_LPF_CLIP wert_03 HD_CC_SUPPRESSION wert_03 EC_LMSSTEPSIZE wert_03 EC_AUXLMSSTEPSIZE wert_03 F_250 wert_03 F_500 wert_03 F_750 wert_03 F_1000 wert_03 F_1250 wert_03 F_1500 wert_03 F_1750 wert_03 F_2000 wert_03 F_2250 wert_03 F_2500 wert_03 F_2750 wert_03 F_3000 wert_03 F_3250 wert_03 F_3500 wert_03 F_3750 wert_03 CENT_LOCK_N_MGL_VERD_AUF nicht_aktiv CHECKSUM_1 wert_02 CHECKSUM_2 grundcode_var UNTER_KORREKT_WERT wert_03 WARN_GRENZ wert_03 ANZ_SCHEIBEN_AB wert_02 BUSSYSTEM wert_02 CHECKSUM_0 wert_07 CHECKSUM_3 grundcode_var CHECKSUM_4 grundcode_var DIAG_OUTPUTS nicht_aktiv DWG_KURZ_MASSE wert_02 DWG_KURZ_UBATT wert_02 ERROR_HS nicht_aktiv ERROR_MAK_PUMPE nicht_aktiv ERROR_MAS_V4 nicht_aktiv ERROR_SB nicht_aktiv ERROR_SCHEIBE_AB_HHS nicht_aktiv ERROR_SCHEIBE_AUF_V5 aktiv ERROR_SWBUNT nicht_aktiv ERROR_V1 nicht_aktiv ERROR_V2 nicht_aktiv ERROR_V3 nicht_aktiv ERROR_VOEFF nicht_aktiv ERROR_VSCHL nicht_aktiv ERROR_VSW12 nicht_aktiv ERROR_VSW41 nicht_aktiv ERROR_VSW42 nicht_aktiv ERROR_VSW71 nicht_aktiv ERROR_VSW72 nicht_aktiv ERROR_VSW91_8 aktiv ERROR_VSW92_HTOP nicht_aktiv ERROR_VSWSUNT_RESERVE aktiv ERROR_WINDLAUF nicht_aktiv FAHRZEUG_TYP wert_02 GESCHWINDIGKEIT wert_02 GESCHWINDIGKEIT_FEHLER wert_02 HALLSENSOR_VSW91_8 nicht_aktiv HALTEZEIT wert_02 HYSTERESE_KL30 wert_02 KEIN_NETWORK aktiv KEIN_SENDEN_STATUS nicht_aktiv KEINE_ANFRAGE_SCHEIBEN aktiv LED_HARDWARE aktiv LED2_ROT nicht_aktiv LOGIK_VSW91_8 nicht_aktiv LOGIK_VSW92_HTOP nicht_aktiv LOGIK_VSWSUNT_RESERVE nicht_aktiv MIN_TEMPERATUR wert_02 MIN_UNTERSPANNUNG wert_02 NOTLAUF nicht_aktiv OHNE_GESCHWINDIGKEIT nicht_aktiv OHNE_HECKKLAPPE nicht_aktiv OHNE_KLEMME_R nicht_aktiv OHNE_KOMFORT_OEFF nicht_aktiv OHNE_KOMFORT_OEFF_FBD nicht_aktiv OHNE_KOMFORT_SCHL nicht_aktiv OHNE_KOMFORT_SCHL_FBD nicht_aktiv OHNE_SEITENSCHEIBEN nicht_aktiv OHNE_TEMPERATUR aktiv OHNE_UEBERSPANNUNG nicht_aktiv OHNE_UNTERSPANNUNG nicht_aktiv POS_SCHEIBE_OBEN wert_02 PUMPE_ALARM wert_01 PUMPE_PREALARM wert_01 RICHTUNG_WLM nicht_aktiv SCHEIBE_AB_OHNE_HALL nicht_aktiv SCHEIBE_AUF_MIT_TIMEOUT nicht_aktiv SCHEIBE_AUF_POSITION nicht_aktiv SCHWELLE_KL15 wert_01 SEGMENTGRENZEN_HALLS wert_01 SICHERN_VERDECKLAPPE nicht_aktiv VENTIL_V5GO nicht_aktiv ZEIT_PAUSE_PUMPE wert_02 ZEIT_SCHEIBEN_AUF wert_02 ZEIT_SLEEP wert_02 SCHEIBENABSENK_REVERS nicht_aktiv SPRITZDUESEN_HZG nicht_aktiv TRA_SCHEIBENABSENKUNG aktiv KLIMA_EIN_MIT_AUTO_EIN_1 nicht_aktiv KLIMA_EIN_MIT_AUTO_EIN_2 nicht_aktiv KLIMA_EIN_MIT_AUTO_EIN_3 nicht_aktiv KLIMA_EIN_MIT_AUTO_EIN_4 nicht_aktiv TRA_ER_HECKKLAPPE aktiv TRA_FH_BF_HINTEN aktiv TRA_FH_BF_VORNE aktiv TRA_FH_FA_HINTEN aktiv TRA_FRONTSCH_REINIGUNG aktiv TRA_SRA_1 aktiv PORTABLE_BT nicht_aktiv Link to comment Share on other sites More sharing options...
TriggerFish Posted June 10, 2013 Author Report Share Posted June 10, 2013 (edited) Not all of those options are for an LCM, there's at least codes for a GM5 in there too. That said, whatever that is does include the right codes for the BFD. LED_HARDWARE aktiv suggests that it's been coded properly for LEDs too, although I'm not 100% on that. To attach a file, it's found under 'more reply options'. Also, an easy way to find the CO of a module is via INPA - there's a screen in there which tells you about it all. Edited June 10, 2013 by TriggerFish Quiksilver_TR 1 Link to comment Share on other sites More sharing options...
Quiksilver_TR Posted June 11, 2013 Report Share Posted June 11, 2013 Nice one, thanks When I get the car back from the bodyshop Ill have a play and get the right files etc . Link to comment Share on other sites More sharing options...
Jabol Posted October 9, 2013 Report Share Posted October 9, 2013 Hello. I have done everything like in post no.7 and its only working third stop light. Where did I go wrong? Link to comment Share on other sites More sharing options...
