jcjdavis1 Posted December 1, 2015 Report Share Posted December 1, 2015 Hi. Found my windows were constantly steamed up and taking ages to clear, so changed my pollen filter and the difference is great. Just a thought if anyone was having the same problem, worth a try. Jim Quote Link to comment Share on other sites More sharing options...
kirkynut Posted December 1, 2015 Report Share Posted December 1, 2015 Where did you get the new pollen filter and which brand please? We've been fighting with this on the Mrs 325i for a while and changing the pollen filter helped but not for long. Kirkynut Quote Link to comment Share on other sites More sharing options...
jcjdavis1 Posted December 2, 2015 Author Report Share Posted December 2, 2015 Hi. ECP, cost about a tenner, order on their web site and they will deliver to your door if you don't have a branch locally. Make sure no water is getting to the filter, mine was wet so presume that is the reason. Jim Quote Link to comment Share on other sites More sharing options...
momo Posted December 2, 2015 Report Share Posted December 2, 2015 Put your AC on? It'll clear the moisture in the car.. Quote Link to comment Share on other sites More sharing options...
jcjdavis1 Posted December 2, 2015 Author Report Share Posted December 2, 2015 58 minutes ago, momo said: Put your AC on? It'll clear the moisture in the car.. Hi. I use AC all the time, new pollen filter AC working better, clear windows. Jim Quote Link to comment Share on other sites More sharing options...
330CDT Posted December 2, 2015 Report Share Posted December 2, 2015 Stupid question I know, but is the pollen filter hard to access / fit? Quote Link to comment Share on other sites More sharing options...
ConRod Posted December 3, 2015 Report Share Posted December 3, 2015 7 hours ago, 330CDT said: Stupid question I know, but is the pollen filter hard to access / fit? Not at all..lift the bonnet and it's just two little spring screw clip things (push down and twist) located at the back of the engine on the scuttle panel :) 330CDT 1 Quote Link to comment Share on other sites More sharing options...
kirkynut Posted December 3, 2015 Report Share Posted December 3, 2015 I've replaced it with 2 from Eurocarparts and only the Bosch one fitted last time made a real difference. No leaks anywhere and door seals seem fine and with the Bosch one making a difference for some time I'm happy it's that. I might try a genuine one. Kirkynut Quote Link to comment Share on other sites More sharing options...
momo Posted December 3, 2015 Report Share Posted December 3, 2015 12 hours ago, jcjdavis1 said: Hi. I use AC all the time, new pollen filter AC working better, clear windows. Jim Have you had the AC regassed and cleaned? Even with loads of moisture it should clear the windows in max 90sec.. Mine steams up badly if i'm in and out of the car when it's raining a lot so obviously introducing lots of moisture to the climate system.. Clears up nicely when AC is on. Generally though i'm always cold so got it set to 32C most of the time.. That usually burns off any residual moisture left in the system.. My car usually smells like a tumble dryer after a long journey! lol Quote Link to comment Share on other sites More sharing options...
330CDT Posted December 3, 2015 Report Share Posted December 3, 2015 32! I have mine on 20 and only put it on for like 5 mins at a time haha! Quote Link to comment Share on other sites More sharing options...
X-Man Posted December 3, 2015 Report Share Posted December 3, 2015 32C Are you some sort of lizard? I can't have mine above 24 even on the coldest days and then only for a few minutes before it starts melting me Quote Link to comment Share on other sites More sharing options...
momo Posted December 3, 2015 Report Share Posted December 3, 2015 What can I say? I like it warm.. RichS 1 Quote Link to comment Share on other sites More sharing options...
ConRod Posted December 3, 2015 Report Share Posted December 3, 2015 1 hour ago, momo said: What can I say? I like it warm.. What have you got the heater control in the centre vent set to though? Quote Link to comment Share on other sites More sharing options...
momo Posted December 3, 2015 Report Share Posted December 3, 2015 Full hot ofcourse! lol Quote Link to comment Share on other sites More sharing options...
jcjdavis1 Posted December 3, 2015 Author Report Share Posted December 3, 2015 Hi. 20c is my favoured temp. on auto all the time and use the centre wheel if I want to cool it down. Jim Quote Link to comment Share on other sites More sharing options...
PeeBee Posted December 3, 2015 Report Share Posted December 3, 2015 You guys are too cold. I have mine on 16.5. That's just right. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
RichS Posted December 3, 2015 Report Share Posted December 3, 2015 25 when the roof is down or 21.5 for normal use. But heated seats a lot of the time:) Quote Link to comment Share on other sites More sharing options...
feva Posted December 3, 2015 Report Share Posted December 3, 2015 16 most of the time 18 in the winter. With shorts on [emoji1] Sent from my Note 4 using tapatalk Quote Link to comment Share on other sites More sharing options...
De Sisti Posted February 17, 2016 Report Share Posted February 17, 2016 The manual suggest a temp of 22 degrees Celsius. Quote Link to comment Share on other sites More sharing options...
330CDT Posted February 17, 2016 Report Share Posted February 17, 2016 The manual even suggests a temperature for our comfort? Lol Since this thread I've had a Bosch Carbon pollen filter and it seems to be working well. Noticeably less fog/steaming up on the windscreen. My rear window still steams up though... hmmm. Quote Link to comment Share on other sites More sharing options...
Tewkes Posted February 18, 2016 Report Share Posted February 18, 2016 Anyone got the correct part number for the Bosch one as there's 2 listed online for 320d saloon. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
PeeBee Posted February 19, 2016 Report Share Posted February 19, 2016 Quote Link to comment Share on other sites More sharing options...
Craig_09 Posted February 19, 2016 Report Share Posted February 19, 2016 12 minutes ago, PeeBee said: After reading this link I decided to have a look at my filter. Changed it today. Definitely needed it. Sent from my iPhone using Tapatalk Looks like you are replacing a carbon filter with a standard one? Quote Link to comment Share on other sites More sharing options...
Tewkes Posted February 19, 2016 Report Share Posted February 19, 2016 What's better, carbon or standard? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
avalaugh Posted February 19, 2016 Report Share Posted February 19, 2016 Just fit a new one every year, I just use standard never noticed any diffract from a carbon or standard Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
