TERKIN
Terkins Touring
last pic before i went full retard
and done. i have to say i love the colour but i want plasti dip dead,roof and arches will need redoing as they came out shat otherwise not to sad.
small wheels look so crap from behind
beasts back on
3 hours ago, simonlpearce said:
To be fair i have seen a lot worse! Think i might do something similar with the track car.
Where do you get the plastidip from and how much do you need?
yes its not bad,the paint before hand wasn't the best so it was worth a shot.
i used plasti dip on the test panel but the whole car was actually full dip which i ment to put. i bought 15 cans from http://matt-pack.co.uk/
came in at under 100quid and i only used 9 cans to get full coverage of about 5-6coats,i added a extra can after to the front to help with stonechips. then a couple more cans experimenting with repairs etc..  but depends what car your doing? need about 12-13L if your gunning it which i may do at a later date..
something like this worked well for over spray and reactivation for repairs,obviously you cant peel a light dusting of over spray
http://www.ebay.co.uk/itm/111501414524?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
and a decent spray wax is a must otherwise its marks so easy
On 7/28/2016 at 13:00, Stevej330 said:
Hope to see this at some point. the paint looks sweet and no doubt it is stupidly loud hehe :):):)
i go to the hospital up your way at least once a week surprised you haven't heard it :P its not actually yobtastic loud,the idle is really strange kind of jet sounding has a nice roar and plenty of whistle when going and lift off is still huge giggles :P
the paint will be sweet once i redo certain bits :)
On 7/28/2016 at 13:47, alan53 said:
can I ask how you connected the oil temp?
just in the sump easiest way i could think of as im not to bothered about it,just had to fill the extra slot :)
cheers nice and simple! i know some guys trying to hack into the engine management
Up Bupa?
Hopefully see it at some point then. :P
seems all my pics went missing :o
anyway fix that later,maybe. not updated in ages as i couldn't drive the car for a couple of months,tried to start it last week and bang first time again :P
decided to do a service before i started using again
one of these first
then did the coolant and oil bumper always has to come off for oil changes :(
found a vac leak
Edited by TERKIN
40 minutes ago, Stevej330 said:
not sure if you can remember back. when you had the style 32s what size tyres did you run?
 the rears were 235/35 slight rubbing
 the fronts were 225/35
i wouldn't go back to 35s though due to noise and ride,and not sure if its related to size but they gave me 2 blowouts in less than 6months :o
Terrific just what I wanted to hear....:'(
I've just purchased a set of style 32s. I'm looking at
Front 215/35
Rear 225/35
                      Quite a lot of stretch but hopefully look good.
Front 215/35
Rear 225/35
they arent that bad easy livable,i just find 40s a littler better
225 on a coupe should be zero rub.
stretch isint to bad either
ok mate nice one thanks for the reply.
Do you think the 35 will be too much stretch?
well the 235/35 tyres i had were stretched just enough to look good but attract zero attention
ive had 225 tyres on 9.5" rims with safe stretch so you should be fine.
i had two complete sidewall failures so thin tyres and stretch seem dodgy to me these days.could be completely unrelated and i just got unlucky. plus nothing better than getting sideways down the m2 :D
