Lawyered07 Posted May 20, 2017 Report Share Posted May 20, 2017 I've bought a 320cd to replace the 330ci. Will be gutted to see the 330 go (if I can bring myself to sell it!) but needs must at the moment and it should help save to buy something proper next year or so (hopefully a 335). The car was pretty cheap but does have a few issues. One annoying one is that the central locking is a bit peculiar. I'm trying to figure out whether it's the GM5. It has locked and unlocked fine so far but the book won't open without the key and the alarm goes off if you lock it with the remote. Only picked it up this morning so I haven't got much experience to say whether it always locks and unlocks with the key but it's been ok the few times today which makes me think it isn't the GM5. Question then is what else could it be? Or maybe the boot and alarm aren't related? Is there any definitive way to diagnose the GM5? If it is that I need to sort it now while I can use the 330. thanks Quote Link to comment Share on other sites More sharing options...
TriggerFish Posted May 20, 2017 Report Share Posted May 20, 2017 If you arm/lock the car with the fob, then there's a setting that says that if the key blade is used (and not the fob) to open the car, that the alarm should sound. This can be disabled with PA Soft or NCS. If you open the driver's door with the key blade, it should set the alarm off too (disarm with the ignition). It could be a dodgy part in the boot locking mechanism itself? I think INPA lets you see what signals different parts of the central locking is sending/receiving which might help? Quote Link to comment Share on other sites More sharing options...
Lawyered07 Posted May 20, 2017 Author Report Share Posted May 20, 2017 Cool will have to look into getting inpa. tried the locking thing and the alarm did sound opening with the blade after locking with the remote. But the first problem was if I lock with the remote then 30 ish minutes later the alarm goes off. Very strange... Quote Link to comment Share on other sites More sharing options...
Lawyered07 Posted May 21, 2017 Author Report Share Posted May 21, 2017 (edited) Now I've had it a bit more I think the boot lock is the button press itself and the two issues are unrelated. The alarm goes off only after locking with the remote and without me doing anything else. ie I just lock it as normal and the alarm sounds after about 15 mins. If I lock with the blade then no alarm. The remote has actually worked every time for locking and unlocking. Anyone had this before? Edited May 21, 2017 by Lawyered07 Quote Link to comment Share on other sites More sharing options...
LV426 Posted May 25, 2017 Report Share Posted May 25, 2017 Is there a sensor in the boot confirming is shut, this is a complete guess, but people have had probs with bonnet closed sensors. Quote Link to comment Share on other sites More sharing options...
lozevans Posted May 25, 2017 Report Share Posted May 25, 2017 Could be a faulty bonnet alarm switch. It's located top left by the master cylinder. These are known for breaking, disconnect it, if alarms doesn't go off there's your problem, Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Lawyered07 Posted May 25, 2017 Author Report Share Posted May 25, 2017 It was indeed the bonnet switch. I've had it disconnected for a couple of days now and not a single sound. Quote Link to comment Share on other sites More sharing options...
momo Posted May 25, 2017 Report Share Posted May 25, 2017 Mine has started bleeping too.. Disconnected it, will probably not replace it for the £35-40 for a new one.. Quote Link to comment Share on other sites More sharing options...
