BavarianDiesel
Fuel Relay location 2000 320d
It's one of the outer two. The other is for the horn. They're interchangeable. Just pull one and see if the horn works or not. If, not, pull the other out instead. (The fact they're swapable is a good way to do a basic test too - does the horn work once you've swapped them? If so, the FPR is likely to be OK.)
