incredirog
6.25” to replace HK speakers
Just wanted to say after a lot of reading and buying some adapters. The HK speakers are already in a plastic adapter ring which will fit better than any piece of mdf or abs you can buy from eBay. I had not read this anywhere so wasted £6. Peel the tiny metal tabs back and remove, then orientate your speaker to suit your application pop a few pilot holes in and screw it down. I also used some foam tape in the sandwich but it’s probably not necessary, bmw used glue.
Interesting - so 6.25" speakers fit?
I've been tempted to replace my HK setup as I have some of the speakers starting to degrade and crackle at certain frequencies but the amp and speaker wiring put me off, though I suspect if I were to get a pinout of the HK amp I could just bridge some wiring to pass the speaker level output from my headunit straight to the speakers.
Additional question - are you replacing the HK amp or literally just wiring up to the existing speaker connections?
Do the speakers work/sound OK? I was always under the impression that the HK speakers were an odd resistance value and you'd need to replace the amp as well.
Sorry only just seen this question, I took the whole interior from an HK car, so door card speakers were HK. I looked at retro fitting the whole HK system but it’s a lot of work for not a lot of benefit so I went for aftermarket speakers and factory wiring. For the brief time I had HK speakers and standard stereo they seemed to work fine. I now have aftermarket speakers and android Chinese head unit with no external amp and it sounds better than the original HK setup.
Gotcha, I see. I might do some probing at some stage - my HK speakers are slowly but surely giving up the ghost, but if I can track back the door wiring to the HK amp in the back then I can de-pin the HK amp and use the factory wiring in an aftermarket amp with aftermarket speakers - that way I only have to run the RCA and power through the car.
Not sure if you'd know, but are all the speaker connections independent going back to the boot (I.e. 6 wires from each front door +/- for tweeter, mid bass, and midrange, 2 from each rear door, then 2 each for the subs?)
I guess I just need to stop being lazy and get my multimeter on continuity and do some probing.
I really can’t remember, they might be bridged within the door so two wires from the amp for each door then splits 3 ways. it all just went into a wrapped loom though so who knows! good luck with it and get some door card fasteners in advance, complete pain breaking a couple and having door card rattle with your new thumping bass!
