  • entries
    5
  • comments
    9
  • views
    7,131
BMW E-series CIC Retrofit by NCS-Expert
Dave1987
 Share
I have successfully done CIC retrofit on E89. (similar operation applies to all BMW E-series).
You need:
 cable (i used 2016 version with a switch)
working NCS EXPERT software
valid daten files for your car
bmw-inpa-k-dcan-cable
Model:
BMW E89
(this method applies to all BMW E series)
BMW CIC retrofit coding procedure:
connect the BMW K+Dcan cable to the car
read VO
program CAS and FRM/ NFRM for CIC retrofit
run NCS EXPERT software
select File-> Read Profile
select Expert mode
select-expert-mode
press F1 or click the VIN/ZSC/FA button
press F3 or click the ZSC/FA| ECU button
select CHASSIS: E89 for E9x models
select chassis e89
then select ECU: CAS
note: VO on CAS and FRM pr NFRM needs to be changed
select cas
then get the car details identified (CHASSIS, FG, FA)
press F2 or click the Enter FA button
select CHASSIS: E89
check VIN and click OK
enter vin
highlight old build date
e.g. #0607 add press delete
(keep note of your build date)
add build date #0909 for E9x CIC.
add 0909 for fa
later date needed for combox (possible #0910)
add &6VA and press OK
add 6va
press the BACK button
then press PROCESS ECU
note: avoid Process car as it programs every module (RISKY), and not needed
select ECU: CAS
press CHANGE JOB to: FA_WRITE)
check for FA_WRITE and EXCUTE JOB
FA-Write
press CHANGE ECU
select ECU: NFRM
note: FRM module or NFRM depending on model
EXCUTE JOB again to make sure FA_WRITE and correct module selected
excute job
coding done!!
now to make sure the coding went well in the new VO and the CAS, FRM/ NFRM
again, run NCS EXPERT software
select File-> Load Profile
select Expert mode
press VIN/ZSC/FA
press ZSC/FA| ECU
select CHASSIS: E89
select ECU: CAS
press ENTER FA
select CHASSIS: E89
!! check build date #0909 and &6VA you added just now
then press BACK
press ZCS/ FA f. ECU
select ECU: NFRM
press ENTER FA
select CHASSIS: E89
coding done & verified!
now to default coding the CIC unit to recognise your cars features, such as AS PDC, Bluetooth...
select Expert mode
press VIN/ZSC/FA
press ZSC/FA| ECU
select CHASSIS: E89
select ECU: CAS
press BACK
process ecu
press PROCESS ECU
select ECU: CIC
note:
CIC now should be displayed in the list of modules
select cic
press CHANGE JOB to make sure that SG-CODEREN is selected by JOBNAME
SG-CODEREN
check and press EXCUTE JOB
the CIC unit will reboot and load up with all of your options
cic reboot
note:
NAVI and VOICE/ DVD in motion have to be activated in other ways
 Share
1 Comment
Recommended Comments
