e46 330ci vert Posted June 9, 2013 Report Share Posted June 9, 2013 bulbs was faulty,i simply replaced them From what I've read it seems the flicker problem is pretty much inevitable when fitting hid lights... you then need to buy more stuff to fix it after - like the bits you've listed. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
twoblacklines Posted October 19, 2014 Report Share Posted October 19, 2014 I was out last night and noticed how terrible the headlights are in projector halogens. So much so I had my fog/driver lights on just to see where the road had flooded! Where do I get H7 HID kit from and which place is best, hids4u or hids-direct or elsewhere? I wouldn't fit them to reflectors however my car has projectors so no issue. I had a set of 35w 6000k in a passat b5.5 (picture below) which were also projectors and great but I think I am going to go for 5000k this time. Link to comment Share on other sites More sharing options...
twoblacklines Posted October 19, 2014 Report Share Posted October 19, 2014 it could of been a dodgy hid kit im thinking so il try my new kit when it arrives. 2 things that help when you have the flicker problems are: 1,fit error cancelling anti-flicker capacitors 2,fit a relay wired hid loom ive ordered both the above to make sure i get the system running as it should Where did you get the relay from? In 3 series' the battery is in the boot so the cable is not long enough? Link to comment Share on other sites More sharing options...
e46 330ci vert Posted October 19, 2014 Report Share Posted October 19, 2014 the relay kit uses existing wiring.all it needs is a poss supply to work.http://www.ebay.co.uk/itm/HID-KIT-Wiring-Harness-dual-H7-H1-H3-Xenon-Loom-Car-/171034341036?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27d270eeacI never use mine in the endmy hid kits still running perfect twoblacklines 1 Link to comment Share on other sites More sharing options...
clippz Posted November 15, 2015 Report Share Posted November 15, 2015 Has anyone bought the projectors from here? http://www.bmstyling.com/category/products/bmw3-series/e46/ Link to comment Share on other sites More sharing options...
Ruben330ci Posted November 15, 2015 Report Share Posted November 15, 2015 I'm selling genuine xenon headlights bud Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
