ROOKiE
Relocation Unit Part Numbers
RELOCATION UNIT PART NUMBERS -
Right, I had a nightmare trying to get a relocation unit from BMW. It took three orders to get this right, so I will try and clarify this for anybody that might want to get one.
There are two types, the 18mm (with individual switches) and the 16mm (with the long switch box).
The part number for those with individual switches (18mm) is
The part number for those with the long switch box (16mm) is
These part numbers are for the relocation units with the smokers package (ashtray and cigarette lighter in cubby hole).
is this the right one ?
The easiest way to tell which one you have is to measure the height of the section where the button sits, or to be really sure pop the unit out (it only takes a couple of minutes) and check if you have the bars (as seen in the first picture above) ot a clear section (as shown in picture 2).
If you have the bars it the 18mm one, if there are no bars you need the 16mm one.
The one in your picture looks like the 18mm version...
Cheers will wip it out after work. Is this the right unit to hold the climate controle unit though ?
Can't be 100% from that picture mate. However if it is the 18mm one you need they are only £30ish brand new from the dealer. I would get it from there personally :D
I think it's 16mm and am not paying £70 for a pice of plastic lol I'm just not sure what the diference is between the onenthat holds the air-con amd the sunglasses one
I agree i,m having the same trouble with my 1999 e46 328ci coupe , bmw parts department say the part number that i need is the 51168268894 but after reading this i think they have got it completely wrong cause i have the 16mm one piece switch and i,m trying to install my 8 inch carputer screen into my dash so i need to move my climate control panel lower where the sunglasses section used to be !
when you ring up they also say that it is a special order part so you will only get a credit note if it is the wrong part that is ordered which is really wrong when theres so many different part numbers i think !
its looking like i will be needing that 51167001411 thats stated on here , god i hope its right after all this messing about with the dealers :)
Weird Daz, mine was the same price (£30ish) either way (they ordered the wrong one but I could tell when I picked it up so got them to order the right one at no cost)... Got it from Stephen James Blackheath.
Got mine 4 years ago mind, might just be that they are running low on stock!
Hi All,
Just going through this process myself - I have a Pioneer AVIC F700BT which I intend to fit in my newly aquired 330ci. All my research points at the Hvac part number I need being 51 16 3 230 903 as pictured so helpfully by Rookie above. I have a printout from a BMW parts dept with the same number on it. My only worry is that both Rookie's picture and the BMW printout shows a LHD version and I will need the RHD one. Am I worrying unneccessarily?
Thanks,
John
is one of these the unit to buy if i have moved the heater unit in order to put nav in? i have just put a nav in and relocated the heater below but would like it to be flush
thanks
Adam
sorry to bump an old thread..
is the panel from a E46 that was fitted with a nav unit from factory the same as a "relocation panel" or are they different?
its just i can get my hands on a used one for much cheaper its the same!
its the 16mm version iv seen and thats what i need
cheers
