Bahnstormer
Speedo Not Working.....
Ok as above the speedo in my car isn't working. Also, the ABS and ASC lights are permanently lit. I've already tried new speed sensors, but still no joy. :( Does anyone know where all of the speed sensor connections are? Obviously I already know about the ones under the car, but I mean are there more in the car somewhere that I should check?
Or does anyone have any other suggestions? It's really starting to irritate me lol.
rear n/s sensor is the one the feeds the speedo
by 'new' sensors do you mean brand new or (new to you) used ones?
on my wife's 106 GTi a few years ago that was showing up with ABS faults, changed all the sensors, turned out to be the ABS pump & control unit
get a diagnostic done so you know what you are dealing with
As said passenger rear wheel sensor controls the speedo it runs to the abs module & is then sent via canBus to the instrument cluster.
There are 2 tyres of sensor so make sure you have used the right kind, presume you have checked your fuses?
My touring has this problem. Turns out it's a bent axle (was hoping it was just a wheel sensor)! I just ordered 2 off ebay for £110!
Hi guys ye mite be able to help my speedo is not working on my e46 320d got it pluged in all speedo sencers are working it could go up to 60 mph and stay there r go off the clock and stay there at times not moveing at all now if ye could help that would be great thanks in advance
